Question about Dell Latitude D820 Notebook
The screen flickers, have to reboot it
Sometimes in the middle of any process my screen just went crazy, the contents flickers - they scroll over and over the screen. The only way to solve it is to reboot it. A friend indicated that the resolution might be the issue. However, after I reduced the resolution it still happens, just less frequently.
    Genius:
  • 2,028 Answers
Start by checking Dell's support site for updated video drivers, then uninstall the drivers for the screen from the device manager, then reboot. It will find and reinstall them. If this doesn't cure it, then this is going to be a hardware issue. Start by checking the screen connections, they sometimes work loose. If the connections are good and the problem persists, it's going to be the inverter or screen, and unfortunately, replacement is your only option.
Posted on Jun 28, 2008
HOW TO REBOOT A SAMSUNG TABLET?
keep the on/of switch pressed for about 3 seconds, there will be three lines showing # power off # reboot # airplane mode. press the reboot and wait, action completed
Mar 02, 2015 | Samsung Galaxy Tab 3 7.0" - White...
What could cause my VIDEO CARD to fail?
This could be a simple failure of your video card. However, I had this happen and found out it was a heat sink that had come loose from my motherboard. (Heat sinks are the aluminum blocks, with fins, on top of CPUs on your motherboard, or on advanced graphic cards.)
Mar 17, 2014 | ATI Computers & Internet
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
Nov 26, 2011 | Philips 47 in. LCD HDTV
Hai, I have a problem to change language to Arabic to English on Samsung B7320
Yep I think I can help you. Through a process of elimination, counting menu options and downloading the Advanced User Guide from http://downloadcenter.samsung.com/content/UM/200911/20091103173453156/GT-I8000_EUG_Open_Eng_Rev.1.0_091103.pdf you can manage to switch the language
1. Power up the phone (of course)
2. Once the main screen has appeared press the "cube" button.
3. Select the blue and silver cog icon (Settings) at bottom right of screen
4. Select the General Settings Icon, third option down (displayed as a puzzle and cog icon)
5. Scroll down to the last but one option. (Samsung TouchWiz UI is the final option).
6. Three Arabic options are displayed. Select the middle option (English).
7. Select the Arabic option at the bottom left of screen (if the following message doesn't appear then I got it mixed up and it should have been the right).
8. You should get an English message asking if you are sure you want to change the setting.
9. Phone reboots and bingo it should be English.
Mar 12, 2011 | Samsung Computers & Internet
Screen flickering, dim, lines moving up the screen
If it was new in 2006, it probably is not worth repairing.
Jan 06, 2018 | Toshiba 72HM195 72" HDTV
My NC-10 screen just went crazy. I can tap on the
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 29, 2009 | Samsung Computers & Internet
Nothing works!!
If your Zen is not responding or in a "reboot loop" the following information from creative explains how to access the players recovery mode
Hope this helps, and good luck.
Zen V Plus and Zen V
1.
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All)
Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware
Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Aug 10, 2008 | Creative Labs ZEN V Plus MP3 Player
It boots.. but doesnt
Author solved his own problem. He can't get credit for solving it, so I will!
May 29, 2007 | Acer TravelMate 290 Notebook
Video card is giving me problems
Make sure the videocard is set in the slot. You should remove and reseat the videocard. Then go to: http://www.nvidia.com/content/drivers/drivers.asp and download the latest video drivers from here and try installing them again. Old video driver can kill!!! Let me know what happens. Good Luck. Tim
Mar 15, 2007 | XFX GeForce4 Mx440 (64 MB) Graphic Card
Dell Latitude D820 Notebook Logo
325 people viewed this question
Alun Cox
