Washer Adgitator The bolt in the center of the adgitator in my washer keeps coming unscrewed. I noticed that the rubber washer around the bolt has broken but cant see where that would cause it to come unscrewed during a cycle. Is this the reason or could it be something else?
  • 246 Answers
To answer your question, both. It could be the reason as your washer agitates, it is moving back and forth in short increments. This can cause the bolt to back out. However, the rubber washer is not the only thing to hold the bolt in. When the bolts are installed in the factory (and also replacment bolts from the manufactuer) they come not only with a rubber seal that helps keep the bolt from turning, but also the shaft of the bolt is coated in a thread-loc substance. I would recomend adding some thread lock to it (availible in hardware stores, auto parts stores, and even in wal-mart). If your bolt still persists in coming out, I would visit my local appliance parts store with my model number (located under the lid towards the rear) and purchase a replacment agitator bolt. These are fairly inexpensive. It will come with fresh thread, thread -loc and a new rubber washer, all of which will help to hold it in correctly. If you have any more troubles, send me a message back.
Posted on Jun 28, 2008
Washer will not adgitate during wash cycle. what may i look for to try and fix ?
What is the model and model number of the unit? It could be the transmission or the coupling between the motor and transmission. On some models it can even be the lid switch
Jan 04, 2015 | Washing Machines
How do i remove the agitator on my kenmore elite washer
See if the top of the adgitator is removable, there is a bolt way down under the liquid fabric softener and top lid. And possibly a top sealed cover as well...
Aug 02, 2014 | Kenmore 4.3 cu. ft. High-Efficiency...
SOUNDS LIKE LOOSE CHANGE UNDER DRUM.CAN DRUM BE REMOVED TO GET CHANGE OUT.
Yes, First pop the lid up with a flathead screwdriver. You'll see two clips between the body and the lid panel. Once you get the lid up take the tub cover off. It just snaps on to the tub. There is a plasctic cap on the top of the adgitator that covres ther adgitator bolt. Remove it and remove the bolt, and take off the adgitator. This will expose the 6 bolts that hold the basket on. Remove them and the basket will come off, and you can get to anything in the tub.
Jan 30, 2011 | Maytag Bravos MTW6600T Top Load Washer
How do you remove the adgitator?
On the base of the agitator shaft below the cork-screw section you will find a small circular recess. In the center of that circular opening is a 1/4 head screw that you need to remove and this will allow you to pull the agitator out of the washer.
Jun 14, 2010 | Maytag LAT3600A Top Load Washer
Adgitator removal
Just follow these steps:
1. Remove the center dispenser from the top of the agitator. It should just pop off.
2. Locate the white plastic cap underneath and pull straight up to remove.
3. Locate the agitator bolt underneath and remove using a socket and ratchet (can't remember the size). Hold the agitator still with one hand in order to loosen the bolt.
4. With the bolt removed, grasp the agitator by the bottom flanges and pull straight up. It should lift off the center post.
NOTE: Sometimes these agitators will stick due to years of detergent accumulation. You may have to wobble it back and forth to get it loose.
If you have questions, please let me know. I hope this helps you.
May 03, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Need to replace the adgitator dogs
Nothing else needs to be removed. place the agitator on the floor, step on the sides of the bottom of the agitator, grab the top section of the agitator and pull, the sections will separate. hope this helps.
Aug 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine not draining
If you are confident you can do it pull your pump off washing machine and pull the pump houseing apart most will come apart and make sure there is nothing in the pump maybe a small piece of plastic or other item in it. you could also try taking the hoses off the pump and just flush water through it backwards this will also sometimes work I have come across this a lot and normally it is something in the pump interupting the water flow. There may also be sand or small pebbles in the drain holes under the adgitator if flushing the pump doesn't help check under the adgitator for something in the holes. Hope this helps
Jul 21, 2008 | Whirlpool LBR4132JQ Top Load Washer
Grinding during adgitating
remove that bolt again remove upper part of agitator ckd the "dogs" if worn replace part#80040
Jun 06, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Kenmore 70 series washer
check securing bolt on adgitator sometimes the bolt will strip out in main stem may need to tap out and fit new bolt
Mar 14, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
