posted by cam1613 on Jun 28, 2008
what wires are used and where and how does the reciever hook up to the stereo
Solution #1
posted on Jul 05, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
That's a very generic question, but generally you should find on the back of your speakers a pair of connectors either marked (+) and (-) or colored in Red and Black (or both designations). Similarly in the back of your receiver you'll find two sets of these, one for the Right channel and the other for Left. All you need to do is to hook up your Left speaker to the Left Channel in the receiver with proper polarity (red to red and black to black, or (+) to (+) and (-) to (-)) and do the same for Left.
Now you can use speciallized speaker cable (available from Radio Shack etc.) or simple flexible stranded copper electrical cable from a Hardware store. The gauge (size) of cable depends on your receiver's / speaker's maximum output power (watts) and the estimated length of cable run depending on the positions of your equipment. Generally : a 100W set with a run of 20 meters (60ft) at 8 ohms will need no more than 12AWG (4 sq.mm.) cable. But you can supply your exact info and we'll do the calc. for you.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Jensen JW250 Main / Stereo Speaker
Email this problem
Email this problem
Can you Help with these Home Theater Speakers and Subwoofers problems?
remote required
remote required
I have a sansui subwoofer amp... Answer This...
bose cinemate with...
how do i wire it in with my... Answer This...
Problem with sub-woofer
I Disconnected the system to... Answer This...
Repair Service
Find Home Theater Spe. Repairman Near You:
