Toshiba estudio520 cb80 error
What is this error? Can I reset the machine to complete print task.
  • agermag Oct 24, 2008
    i have same problem
  • Wildebeest83 Jan 02, 2009
    Same problem here. The California Service Office is closed today, so I called our Sales Rep. He told me that CB80 means there's an electrical problem with the finisher - yikes. We put in a service request and we're hoping to get it fixed on Monday.
Why can't I scan, print or do anything? There is no error code.
Patti, you may have to do a hard reset.
1) Disconnect the USB cable from your computer
2) Remove the ink cartridges
3) Unplug the power cord. Wait for a couple minutes. Plug the unit back in,hit power button if needed.
4) Wait for the "Insert Cartridges" message, reinstall the cartridges
5) Close printers doors
6) If you get a recalibration message, allow the printer to complete this task
7) Reconnect printer to USB cable
8) Try your printing again.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Re How to perform Hard Reset
hp officejet 6500 error general printer error
HP Multifunction Printer Resets HP Officejet 6500
General Printer error with no alphanumerical code in Mac Control panel for...
Mar 31, 2016 | General Office Equipment & Supplies
What is error c440 of toshiba photocopier
Toshiba e-studio Error code c440 is just problem with Fuser Unit after warm up time . 200L/ 202L/ 230/ 232/ 280/ 282/ 283/ 233
PROBLEM:
Fuser unit problem,
SOLUTION:
Try to reset it:
1. Hold down "0" and "8" keys while turn on the power.
2. Enter 400 press Start.
3. Enter 0 press Set or Enter.
Hope this helps
you can find more info at this link
Apr 28, 2014 | Toshiba E-studio 352 Digital...
Resetting the counter on a Toshiba e studio 2500c
I reached the total print counter 109219 and want to re set.
Oct 23, 2012 | Toshiba E-studio 2500 cbc939390, Copier,...
How to reset error code c21 in the Toshiba e studio 166?
how can to reset error code c21 my toshiba e-studio 166 printer
Feb 28, 2011 | Toshiba e-STUDIO166 Printer
Fatal error msi hp photosmart essential
Ok this is one of the critical issue in this printer when you try to uninstall it and the issue can be resolved in just 10 mins .
At the desktop screen you will see there is taskbar right click on that and select Task Manager in the task manager window select 'Processes Tab' and there You will find hpzstub select that and end that process >> exit out of the task manager window the installation will be completed automatically without any problem
....Happy Printing
Nov 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Printing problem with Toshiba Estudio160
U need to make sure the cable is connected properly and working.
Try to reinstall the driver also.
If still cannot, u can try reset the machine by pressing *+1+3 and ON the machine.
Nov 28, 2008 | Toshiba E-Studio 160 All-In-One Laser...
A window appears with the following message. Time Machine Error Unable to complete backup. An error occurred while copying files to the backup volume.
It appears to be a scheduled backup task not being completed.
You can disable the task by going to the backup software and removing the backup schedule.
I can't tell you the exact procedure since i don't know anything about your system.
Aug 01, 2008 | Computers & Internet
Hard Drive error No. F105
F105 is "other HDD error" . Start the copier holding 0 and 8, it goes in a test mode, then punch 690 and presss start key. Restart the copier. If does not work you might have to replace the HDD and reinstall the firmware. Let me know.
Dec 30, 2007 | Toshiba e-Studio 350 Copier
347 people viewed this question
k24674
jasbo
jasbo
