Question about RCA HD52W58 52" TV
Tv picture Hello my name is Jose my tv has a bend that goes to the center and it has a double picture
  • KIPPER1614 Aug 07, 2008
    The picture curves to the center, with over laying shadows
  • Anonymous Aug 28, 2008
    replaced yellow video cable
  • 70 Answers
Convergence i.c.s are defective.
Posted on Jul 09, 2008
Tv goes to straight line in center of picture then
It happens when Vertical deflection stops as Vertical Out IC becomes hot or does not get vertical signal.
Please check electrolytic capacitors and dry solder joints in vertical out section in TV.
Aug 12, 2009 | Sanyo Televison & Video
Pictures goes to distorded wavy lines.
This could be attributed to tuning reception of your tv. If your using antenna only, it is most probable. If cable, check your line.
If this is a crt type, moving that tv with that size could somehow bend its circuit board. Loose connection is a probability. Could be some minor component is detached from solder. This can be attributed to tuner and vertical IC.
Just for an input.
Apr 20, 2009 | Sanyo DS27910 27" TV
Distorted picture on my 32" Proscan TV...(about 15 years old)
The RCA GE sets have a problem with bad solder connections in the tuner unit which also causes numerous symptoms including poor regulation, no vertical deflection, low audio or dead set.
Pulling in from the sides is either poor regulation or a bad eeprom/solder join issue
Mar 13, 2009 | Proscan PS36123 TV
Picture beginning to fail
There are some components it the vertical deflection amplifier area that are becoming thermo sensitive with age. It is also possible that there will be parts going off value in the power supply and other areas.
These problems are typical in these sets when they are aged. The cost of the repair may not be worth the investment.
You should take the set in to a service center for an estimate.
Jerry G.
Jun 12, 2008 | Philips Magnavox 20MS233S 20" TV
Hatchi 50V500A LCD rear projection tv.
IF IS CIRCULE BLUE A RAUND A IN CENTER THE PICTURE OK YOU TV IS DLP NOT LCD CHECK IS IF HAVE CIRCULE IN CENTER THE PROBLEM IS SERIUS COST THE NAME PART DAMEGED IS THE LENS MACHINE OPTICAL COST TO MUCHS NO COST EFECTIVE
Sep 24, 2007 | Philips 28PW9536 28" TV
Bending Picture
Convergence issues can be one or more of three different boards...in this case i would think it might be what is known as covergence power board.+ convergence amp board. both items very fixable and easy to replace. It would be difficult to determine however because if its the ssb board... then much more difficult to replace.
Sep 08, 2007 | RCA HD52W58 52" TV
Hello im having problems with my sony wega
It sounds like you have a loss of green. This could be caused by the green gun in the picture tube opening up or the drive circuit for the green gun gone bad. Stargazer
Aug 10, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Remote wont work TV goes off by itself
Hello, please take the batteries out from the remote. Best regards, Arpi
Jun 23, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Bowlike effect convergence all screwwed up
I suspect you originally had an intermittent solder connection on the convergence circuit board. This may have damaged the convergence IC's on that board by now if repairing those connections doesn't fix the set.
Mar 10, 2007 | Mitsubishi WS-65819 TV
SONY KP-61HS30
When one or all the colors are bending severly, then the convergence circuit is not functioning correctly and must be repaired. Only one color bending means just the convergence ICs and all colors bending means convergence ICs and voltage supplies. Convergence issues are the most common problem with rear projection (w/picture tubes) televisions. The cure is replacing the convergence IC's. Sometimes the pico fuses need replaced as well. If you have the experience to use a soldering iron and a basic understanding of electronics, then, you may be able to do this job. If not then call a servicer in your area. Go to the Sony website, Sony.com, and you can locate one in your area.
Jan 07, 2007 | Sony KP-61HS30 TV
RCA HD52W58 52" TV Logo
41 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
