VCR does not eject tape correctly
An older RCA VCR, used primarily for dubbing, damages tape upon ejecting
    Scholar:
  • 167 Answers
Hello. it's sound's like that the idler cam wheel that turn's the tape has a problem. it could be that .the wheel if made of rubber is slipping. or it has a belt on the bottem of it that is ***** out. check those two thing's .and let mre know if it has a rubber wheel .? or teeath that turn a gear. and if the belt on the bottem of it is not tight on the two wheel's on the bottem of it. let me know.ok "good luck"
Posted on Jul 03, 2008
Broken tape. Cassette will not eject. How can I correct?
With power off, you will have to disassemble the player to get access to the tape mechanism. You will find tape is preventing the cassette door from closing to allow ejection. Remove damaged tape. Apply power and press EJECT. Turn power off and inspect the mechanism to be sure all tape debris has been removed, then reassemble the player.
Apr 12, 2016 | Sanyo DVW-6100 DVD Player/VCR
How to fix an rca vcr that auto. inserts a tape & then ejects it within seconds
There is somewhere some damage to the mechanism. It could be the carriage itself (the holds the tape) that has a fault on it, or something else in the transport mechanism of the tape. This could have sent the system out of position for the correct loading of a tape.
Aug 21, 2015 | RCA VR646HF 4-Head Hi-Fi VCR
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
MY RCA VCR - TIMER LIGHT ALWAYS FLASHES. WHEN i TRY TO RECORD OR TURN OFF VCR IT EJECTS TAPE.
If it plays a tape OK, then it could be that you have a timer set. In which case clear it! Or that you are using a blank tape where the slot at the back is open. If you are using a blank tape which is good and it still ejects the tape after setting the recording. Then it's likely the recording tab sensor - that detects the slot at the back of the tape - is either bent or broken.
Feb 22, 2013 | RCA Televison & Video
TAPE WENT IN AND TROUBLE TO GET OUT, WHEN OUT, STILL ACTING LIKE IT HAS A TAPE IT IN IT IS TRYING TO EJECT. KEEPS SAYING 'STOP' 'EJECT' AND THE TV WILL NOT STAY OFF~~
If you "helped" the tape out in any way, that action most likely caused more damage. When a qualified technician sees an item before "customer induced damage" their job is easier and no "unusual" parts are broken which puts them in a good frame of mind and translates into a repair that you can be happy about.
However, if only the "eject" button was used to get the tape out, this is a fairly common symptom and worth taking to an experienced professional.
Sep 05, 2009 | RCA B27TF680 27 in. TV/VCR/DVD Combo
TAPE WILL NOT EJECT
Try unplugging the player from electrical power for several minutes. Plug the player back in and try to eject the tape.
Feb 26, 2009 | RCA VR639HF VHS VCR
Tape keeps getting ejected
This unit requires the rubber parts to be replaced. The loading sequence is not completing properly. The VCR will eject the tape when the sequence fails as a safety measure to prevent damage to either the VCR or the tape.
Parts cost for this should not be more than $10.
Dan
Feb 03, 2009 | RCA VR639HF VHS VCR
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
Tape ejects just after insertion
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
Dec 19, 2006 | Mitsubishi HS-U760 S-VHS VCR
RCA VCR ejecting problem
TRY REBOOT -- UNPLUG CORD -- REPLUG -- GOOD LUCK !
Oct 31, 2006 | RCA VR639HF VHS VCR
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
