Question about Sansui DTV2760 27" TV
Sansui TV/VCR/DVD combo
I have Sansui DVD/VCR/TV Combo Model number TDC2075A That My 11 year old son Locked the Parental control ratings so we can't play/watch DVD's and he doesn't know what code he put in. I would like to give it to my Daughter As it has Been sitting in the Barn Since It was locked out. He also lost the manual, and I just recently discovered where to get maunal, realizing made by different manufacter than Sansui.... Orion.
Could some one please send the univ. code to me if they know one?
Dale
  • Sansui Master
  • 13,433 Answers
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Posted on Jun 28, 2008
  • Ekse Jun 28, 2008
    If noting here works repost your problem for more assistance from other experts.
    Genius:
  • 1,142 Answers
You Should have the original remote. Press and hold the power button for 6 to 10 seconds.
  • Maanita Chadha
    Maanita Chadha Jun 28, 2008
    premtech
    Has the magic
  • Maanita Chadha
    Child Lock
    Combos
    If
    If
    OR TRY THIS..
    Press
    CONTROLS
    CTC169AU
    The
    1. Repeatedly press
    CTC185's
    off.
    CTC203's
    TX808 Chassis
    The
    Genius:
  • 1,665 Answers
Choose in the menu the auto mode and you can play any system you want.
http://www.crestelec.com.au/files/support/remote_controls-Crest/RCS4--Manual.pdf
Sansui code: 0082
  • 6,487 Answers
This should do the trick:
If you forget your password, simultaneously press and hold VOL - on the front
panel and VOL - on the remote for 3 seconds. Nothing appears on the screen,
Parental Controls simply unlock and you can re-enter a password via Lock
Parental Controls
Hope that helps............
Parental controls
try giving the reset ...........
Jun 29, 2008 | Sansui DTV2760 27" TV
Have Sansui @0" tv/dvd/vcr combo that my son locked the parentals control
yes..but you'll need to have a service professional do a firmware reset on this unless you can gain access through the service and support menu..
is this a new form of Child Protection and control?
Mar 20, 2008 | Sansui DTV2760 27" TV
Need remote code for (2004)sansui-20in.(tv-vcr-dvd-combo)mod.#tdc2075a
http://www.remotecentral.com/                     this is a website that has remote codes for any and all
Jan 21, 2011 | Televison & Video
I cant find a remote for this tv anywhere.
If your willing to spend $20, call the manufacturer. 800 289 0980.
Mar 18, 2009 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
Philips remote code for a sanui
Depends on the type of Sansui device. Here is the info I have:
0632 for tv/vcr
0041 for a TV/DVD combo or DVD/VCR combo or DVD or VCR
many for CD players - 0268, 0072, 0973, 0075
0015 or 0632 for any TV
if these fail, the universal is usually 0711
If this fails, I have the Philips digit grid - reply thru FixYa, not my personal e-mail. Make sure to rate me.
-Tha Mp3 Doctor
Feb 04, 2008 | Philips PM435S Remote Control
Lost program codes
Here ya go: Emerson 0154 0236 0463 0180 0178 0171 0623 Need more of them?? Cable Americast 0899 Cable Bell South 0900 Cable Director 0476 Cable General Instrument 0476 0810 0276 Cable GoldStar 0144 Cable Hamlin 0009 Cable Jerrold 0476 0810 0276 Cable Memorex 0000 Cable Motorola 0476 0810 0276 Cable Pace 0237 Cable Panasonic 0000 0107 Cable Paragon 0000 Cable Philips 0305 0317 Cable Pioneer 0877 1877 0144 0533 Cable Pulsar 0000 Cable Quasar 0000 Cable Runco 0000 Cable Samsung 0144 Cable Scientific Atlanta 0877 1877 0477 Cable Sony 1006 Cable Supercable 0276 Cable Toshiba 0000 Cable Zenith 0000 0525 0899 DVD Apex Digital 0672 0717 0794 1056 0755 0797 1100 0796 1061 DVD Axion 1072 DVD Blaupunkt 0717 DVD Blue Parade 0571 DVD CineVision 0876 DVD Curtis Mathes 1087 DVD CyberHome 1024 1023 0816 DVD Daewoo 0784 DVD Denon 0490 DVD Dual 1068 DVD DVD2000 0521 DVD Emerson 0591 0675 DVD Enterprise 0591 DVD Fisher 0670 DVD Funai 0675 DVD GE 0522 0815 0717 DVD Go Video 0744 0715 0783 DVD GPX 0699 DVD Greenhill 0717 DVD Hitachi 0573 DVD Hiteker 0672 DVD JVC 0558 0623 DVD Kenwood 0490 0534 DVD KLH 0717 1020 DVD Koss 0651 DVD Lasonic 0798 DVD Magnavox 0503 0675 DVD Marantz 0539 DVD Microsoft 0522 DVD Mintek 0839 0717 DVD Mitsubishi 0521 1521 DVD Nesa 0717 DVD Norcent 1003 DVD Onkyo 0503 DVD Oritron 0651 DVD Panasonic 0490 1762 DVD Philips 0503 0539 0646 DVD Pioneer 0525 0571 DVD Polk Audio 0539 DVD Proscan 0522 DVD Qwestar 0651 DVD RCA 0522 0571 0717 DVD Rotel 0623 DVD Rowa 0823 DVD Samsung 0573 1075 0820 DVD Sanyo 0670 DVD Shinsonic 0533 0839 DVD Sony 0533 1533 0864 1033 DVD Sylvania 0675 DVD Symphonic 0675 DVD Technics 0490 DVD Theta Digital 0571 DVD Toshiba 0503 DVD Tredex 0799 DVD Urban Concepts 0503 DVD Xbox 0522 DVD Yamaha 0490 0539 0545 DVD Zenith 0503 0591 Satellite AlphaStar 0772 Satellite DirecTV 0392 0566 0639 0247 0749 1749 0724 0819 1856 Satellite Dish Network System 1005 0775 Satellite Dishpro 1005 0775 Satellite Echostar 1005 0775 Satellite Expressvu 0775 Satellite GE 0566 Satellite General Instrument 0869 Satellite GOI 0775 Satellite Hitachi 0819 Satellite HTS 0775 Satellite Hughes Network Systems "0749, 1749" Satellite JVC 0775 Satellite Magnavox 0724 0722 Satellite Memorex 0724 Satellite Mitsubishi 0749 Satellite Motorola 0869 Satellite Next Level 0869 Satellite Panasonic 0247 0701 Satellite Paysat 0724 Satellite Philips 0749 1749 0724 0722 Satellite Proscan 0392 0566 Satellite RadioShack 0869 Satellite RCA 0392 0566 0855 0143 Satellite Samsung 1276 Satellite SKY 0856 Satellite Sony 0639 1639 Satellite Star Choice 0869 Satellite Toshiba 0749 1749 0790 1285 Satellite UltimateTV 0392 0639 Satellite Uniden 0724 0722 Satellite Zenith 0856 1856 TV AOC 0030 TV Admiral 0093 0463 TV Advent 0761 0842 TV Aiko 0092 TV Akai 0702 0030 0672 0812 TV Alfide 0672 TV America Action 0180 TV Anam 0180 TV Apex Digital 0748 0765 0767 TV Audiovox 0451 0180 0092 0623 TV Baysonic 0180 TV Bell & Howell 0154 TV Bradford 0180 TV Broksonic 0236 0463 TV CXC 0180 TV Candle 0030 TV Carnivale 0030 TV Carver 0054 TV Celebrity 0000 TV Celera 0765 TV Changhong 0765 TV Cineral 0451 0092 TV Citizen 0060 0030 0092 TV Clarion 0180 TV Contec 0180 TV Craig 0180 TV Crosley 0054 TV Crown 0180 0672 TV Crown Mustang 0672 TV Curtis Mathes 0047 0054 0154 0451 0093 0060 0702 0030 0145 0166 1147 1347 TV Daewoo 0451 1661 0092 0672 0623 TV Denon 0145 TV Dumont 0017 TV Durabrand 0003 0171 0178 0180 0463 1034 TV Electroband 0000 TV Emerson 0154 0236 0463 0180 0178 0171 0623 TV Envision 0030 TV Fisher 0154 TV Fujitsu 0683 0809 TV Funai 0180 0171 TV Futuretech 0180 TV GE 0047 0051 0451 0178 1147 1347 TV Gateway 1755 1756 TV Gibralter 0017 0030 TV GoldStar 0030 0178 TV Gradiente 0053 TV Grundig 0672 TV Grunpy 0180 TV Hallmark 0178 TV Harman/Kardon 0054 TV Harvard 0180 TV Havermy 0093 TV Hello Kitty 0451 TV Hitachi 0145 1145 TV Infinity 0054 TV Inteq 0017 TV JBL 0054 TV JCB 0000 TV JVC 0463 0053 TV Jensen 0761 TV KEC 0180 TV KLH 0765 0767 TV KTV 0180 0030 TV Kenwood 0030 TV Kioto 0706 TV LXI 0047 0054 0154 0156 0178 TV MGA 0150 0030 0178 TV MTC 0060 0030 TV Magnavox 0054 0706 0030 1454 1254 TV Marantz 0054 0030 TV Matsushita 0250 0650 TV Megatron 0178 0145 TV Memorex 0154 0250 0463 0150 0178 TV Midland 0047 0017 0051 TV Mitsubishi 0093 0150 1250 0178 0836 TV Motorola 0093 TV Multitech 0180 TV NAD 0156 0178 0866 TV NEC 0030 1704 0704 TV NTC 0092 TV Nikko 0030 0178 0092 TV Norcent 0748 0824 TV Onwa 0180 TV Optimus 0154 0250 0166 0650 TV Optonica 0093 TV Orion 0236 0463 TV Panasonic 0051 0250 0650 TV Penney 0047 0156 0051 0060 0030 0178 1347 TV Philco 0054 1661 0463 0030 0145 TV Philips 0054 1454 0690 TV Pilot 0030 TV Pioneer 0166 0866 TV Portland 0092 TV Prima 0761 TV Prism 0051 TV Proscan 0047 TV Proton 0178 TV Pulsar 0017 TV Quasar 0051 0250 0650 TV RCA 0047 1047 1147 1247 1347 1447 1547 TV RadioShack 0047 0154 0180 0030 0178 TV Realistic 0154 0180 0030 0178 TV Runco 0017 0030 TV SSS 0180 TV Sampo 0030 1755 TV Samsung 0060 0702 0030 0178 0812 TV Sansei 0451 TV Sansui 0463 TV Sanyo 0154 TV Scotch 0178 TV Scott 0236 0180 0178 TV Sears 0047 0054 0154 0156 0178 0171 TV Semivox 0180 TV Semp 0156 TV Sharp 0093 TV Sheng Chia 0093 TV Sony 0000 1100 0810 TV Soundesign 0180 0178 TV Squareview 0171 TV Starlite 0180 TV Supreme 0000 TV Sylvania 0054 0030 0171 TV Symphonic 0180 0171 TV TMK 0178 TV TNCi 0017 TV TVS 0463 TV Tandy 0093 TV Technics 0051 0250 TV Techwood 0051 TV Teknika 0054 0180 0150 0060 0092 TV Telefunken 0702 TV Toshiba 0154 0156 0060 1356 1656 1704 0650 TV Toshiba 1256 TV Vector Research 0030 TV Victor 0053 TV Vidikron 0054 TV Vidtech 0178 TV ViewSonic 1755 TV Wards 0054 0030 0178 0866 TV Waycon 0156 TV White Westinghouse 0463 0623 TV Yamaha 0030 TV Zenith 0017 0463 0178 0092 TV DVD Combo Sylvania 0675 TV VCR Combo America Action 0278 TV VCR Combo Audiovox 0278 TV VCR Combo Broksonic 0479 1479 TV VCR Combo Citizen 1278 TV VCR Combo Colt 0072 TV VCR Combo Curtis Mathes 1035 TV VCR Combo Daewoo 1278 TV VCR Combo Emerson 0479 1479 1278 TV VCR Combo Funai 0000 TV VCR Combo GE 0240 1035 0807 1060 TV VCR Combo GoldStar 1237 TV VCR Combo Harley Davidson 0000 TV VCR Combo Hitachi 0000 TV VCR Combo Lloyd's 0000 TV VCR Combo Magnasonic 1278 TV VCR Combo Magnavox 0000 1781 TV VCR Combo Magnin 0240 TV VCR Combo Memorex 0162 1237 TV VCR Combo MGA 0240 TV VCR Combo Mitsubishi 0807 TV VCR Combo Optimus 0162 TV VCR Combo Orion 1479 0479 TV VCR Combo Panasonic 0162 1035 TV VCR Combo Penney 0240 1035 1237 TV VCR Combo Quasar 0162 1035 TV VCR Combo RadioShack 0000 TV VCR Combo RCA 0240 0807 1060 1035 TV VCR Combo Samsung 1014 TV VCR Combo Sansui 0000 1479 0479 TV VCR Combo Sanyo 0240 TV VCR Combo Sears 0000 1237 TV VCR Combo Sony 0000 1232 TV VCR Combo Sylvania 1781 TV VCR Combo Symphonic 0000 TV VCR Combo Thomas 0000 TV VCR Combo Toshiba 1145 0845 TV VCR Combo Zenith 0000 1479 0479 VCR ABS 1972 VCR Admiral 0048 0209 VCR Adventura 0000 VCR Aiko 0278 VCR Aiwa 0037 0000 VCR Akai 0041 VCR Alienware 1972 VCR America Action 0278 VCR American High 0035 VCR Asha 0240 VCR Audiovox 0037 0278 VCR Beaumark 0240 VCR Bell & Howell 0104 VCR Broksonic 0184 0121 0209 1479 0479 VCR Calix 0037 VCR Canon 0035 VCR Carver 0081 VCR CCE 0072 0278 VCR Citizen 0037 0278 1278 VCR Colt 0072 VCR Craig 0037 0047 0240 0072 VCR Curtis Mathes 0060 0035 0162 0041 1035 VCR Cybernex 0240 VCR CyberPower 1972 VCR Daewoo 0045 0278 1278 VCR Denon 0042 VCR Durabrand 0038 0039 VCR Dynatech 0000 VCR Electrohome 0037 VCR Electrophonic 0037 VCR Emerex 0032 VCR Emerson 0037 0184 0000 0121 0043 0209 0278 0479 1479 1278 VCR Fisher 0047 0104 VCR Fuji 0035 0033 VCR Funai 0000 VCR Garrard 0000 VCR Gateway 1972 VCR GE 0060 0035 0240 0807 1060 1035 VCR Go Video 0432 VCR GoldStar 0037 0038 1237 VCR Gradiente 0000 VCR Harley Davidson 0000 VCR Harman/Kardon 0081 0038 VCR Harwood 0072 VCR Hewlett Packard 1972 VCR HI-Q 0047 VCR Hitachi 0000 0042 0041 VCR Hughes Network Systems 0042 VCR iBUYPOWER 1972 VCR Jensen 0041 VCR JVC 0067 0041 VCR KEC 0037 0278 VCR Kenwood 0067 0041 0038 VCR KLH 0072 VCR Kodak 0035 0037 VCR Lloyd's 0000 VCR Logik 0072 VCR LXI 0037 VCR Magnasonic 1278 VCR Magnavox 0035 0039 0081 0000 1781 VCR Magnin 0240 VCR Marantz 0035 0081 VCR Marta 0037 VCR Matsushita 0035 0162 VCR Media Center PC 1972 VCR MEI 0035 VCR Memorex 0035 0162 0037 0048 0039 0047 0240 0000 0104 0209 0479 1237 VCR MGA 0240 0043 VCR MGN Technology 0240 VCR Microsoft 1972 VCR Mind 1972 VCR Minolta 0042 VCR Mitsubishi 0067 0043 0807 VCR Motorola 0035 0048 VCR MTC 0240 0000 VCR Multitech 0000 0072 VCR NEC 0104 0067 0041 0038 VCR Nikko 0037 VCR Noblex 0240 VCR Northgate 1972 VCR Olympus 0035 VCR Optimus 1062 0162 0037 0048 0104 0432 VCR Orion 0184 0209 1479 0479 VCR Panasonic 1062 0035 0162 1035 0616 VCR Penney 0035 0037 0240 0042 0038 1035 1237 VCR Pentax 0042 VCR Philco 0035 VCR Philips 0035 0081 0618 VCR Pilot 0037 VCR Pioneer 0067 VCR Polk Audio 0081 VCR Profitronic 0240 VCR Proscan 0060 1060 VCR Protec 0072 VCR Pulsar 0039 VCR Quasar 0035 0162 1035 VCR RadioShack 0000 VCR Radix 0037 VCR Randex 0037 VCR RCA 0060 0240 0042 1035 0880 0807 1060 VCR Realistic 0035 0037 0048 0047 0000 0104 VCR ReplayTV 0616 0614 VCR Runco 0039 VCR Samsung 0240 0045 1014 VCR Sanky 0048 0039 VCR Sansui 0000 0067 0209 0041 1479 0479 VCR Sanyo 0047 0240 0104 VCR Scott 0184 0045 0121 0043 VCR Sears 0035 0037 0047 0000 0042 0104 1237 VCR Sharp 0048 0807 VCR Shintom 0072 VCR Shogun 0240 VCR Singer 0072 VCR Sonic Blue 0614 0616 VCR Sony 0035 0032 0033 0000 1232 0636 VCR STS 0042 VCR Sylvania 0035 0081 0000 0043 1781 VCR Symphonic 0000 VCR Tagar Systems 1972 VCR Tatung 0041 VCR Teac 0000 0041 VCR Technics 0035 0162 VCR Teknika 0035 0037 0000 VCR Thomas 0000 VCR Tivo 0636 0618 VCR TMK 0240 VCR Toshiba 0045 0043 1145 0845 VCR Totevision 0037 0240 VCR Touch 1972 VCR Unitech 0240 VCR Vector 0045 VCR Vector Research 0038 VCR Video Concepts 0045 VCR Videomagic 0037 VCR Videosonic 0240 VCR Viewsonic 1972 VCR Villain 0000 VCR Wards 0060 0035 0048 0047 0081 0240 0000 0042 0072 VCR White Westinghouse 0209 0072 VCR XR-1000 0035 0000 0072 VCR Yamaha 0038 VCR Zenith 0039 0033 0000 0209 1479 0479 VCR ZT Group 1972 VCR DVD Combo Apex Digital 1061 VCR DVD Combo Go Video 0744 0715 VCR DVD Combo Hitachi 0000 VCR DVD Combo Panasonic 1762 VCR DVD Combo RCA 0060 VCR DVD Combo Samsung 1075 0820 VCR DVD Combo Sanyo 0104 VCR DVD Combo Sony 0864 VCR DVD Combo Sylvania 0675 0000 VCR DVD Combo Symphonic 0675 0000 VCR DVD Combo Toshiba 0503 Satellite PVR Combo Echostar 1005 Satellite PVR Combo Expressvu 0775 Satellite PVR Combo Proscan 0392 Satellite PVR Combo RCA 0392 Satellite PVR Combo Sony 0639 PVR Panasonic 0616 PVR Philips 0618 PVR ReplayTV 0614 0616 PVR Sonic Blue 0616 0614 PVR Sony 0636 PVR Tivo 0636 0618 Cable PVR Combo Motorola 1376 Cable PVR Combo Pioneer 0187 0007 Cable PVR Combo Scientific Atlanta 1877 TV VCR DVD Combo Sharp 0807
Aug 19, 2007 | One For All URC-3021 Remote Control
Sansui DTV2760 27" TV Logo
752 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
