No boot up
I have a problem my laptop wont boot it powers up and thats it if i keep turning it off and on it will eventually boot up but then it locks up the fan on the cpu is working so its not hot any ideas.Thanks its a toshiba tecra 9000
  • simplydig Mar 16, 2009
    Toshiba tecra 9000 doesn't come on, power light comes on but screen show faint lines horizontally but nothing else
  • skhan007 Apr 04, 2009
    My Laptop "Toshiba Tecra 9000" does not boot when turned ON. It does not even display the BIOS. Just the POWER light stays ON.
    Novelist:
  • 148 Answers
Mr Diaz what operating system are you using and when it boots up does the fan race or go to a high rev sound? There are a couple of things to look at. let me know what you got and we can walk through this.. Take care.. mark
Posted on Jun 28, 2008
My hp model, hp pavilion rt3290, red wont work power button is on caps lock flashes n thats it
Try this "wrapping the laptop with a fleece blanket" according to this forum it is a known problem with graphics adaptor.
Laptop not booting and CAPS lock blinking
Feb 14, 2015 | HP Computers & Internet
Gateway laptop ne56r43u wont boot up
Do you have any more details? Was it the victim of a fall? power surge?
Jul 16, 2013 | Computers & Internet
Gateway m255 laptop cpu fan wont let me boot up
open your laptop up and make sure the fan cabels are in correctly if not push them in if that dosen't work get a new fan for it
Jun 15, 2012 | Gateway M255-E Notebook
My laptop has power but wont boot...please help
hi,
Try to boot you computer to safemode, turn off computer then turn it back on then keep on tapping F8, then choose safemode, if youre able to boot to safemode, do system restore going back to the time that its properly working, click start > all programs > accesories> system tools > system restore then pick a date when you think that its properly working..
If its not able to boot to safemode, you will need to reinstall the operating system using the recovery disc that came with the computer.
Hope this will help... Please rate...
Jan 20, 2011 | Acer Computers & Internet
When i put on my laptop, it starts to boot and then eventually goes off. when i put it on again, it does not come on, however if i take off the battery and reinsert it and put the laptop on, it begins to...
Welcome to Fixya
This could be a hardware problem. Lets try to eliminate the possbility of a software issue. Try to boot up the computer in safe mode first and let us see if it will give you the same problem. Turn on the computer then keep on tapping F8 key. Press safe mode when prompted.
Let me know of any development when you are done with the process.
Thank you for using Fixya!
Jan 11, 2011 | Lenovo 3000 N100 Notebook PC
It wont cut on keep making a beeping sound
beeping sound means that you have a bad power supply. Normally when booting your laptop, the power supply supplies enough power to boot to the operating system. You consult HP to replace your power supply in your laptop.
Oct 19, 2010 | HP OmniBook XE3 Notebook
Laptop wont boot up to anything, just a black screen when you turn it on and the light at the cap locks flashes 5 times and thats all.
Number of Blinks or BeepsLocation of Blinking LEDsComponent Being CheckedError ConditionContinuous glowBattery power LEDBatteryThe AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.1Caps Lock/Num LockCPUCPU not functional2Caps Lock/Num LockBIOSBIOS corruption failure3Caps Lock/Num LockMemoryModule error not functional4Caps Lock/Num LockGraphicsGraphics controller not functional5Caps Lock/Num LockSystem boardGeneral system board failure6Caps Lock/Num LockBIOSBIOS authentication failureContinuous blinkAC power adapter LEDPower adapterInsufficient power
Oct 10, 2010 | HP Compaq 6735s Notebook
Laptop boots then shuts automatically off
If you haven't tried it yet, pull the battery out and try booting from the adaptor only. If it boots normally, then your battery pack may be bad (shorted cell) or the regulator that has the job of charging and monitoring the battery pack while keeping your system running may not be healthy.
If you own any multimeter (at the cost of Chinese DMMs, everyone should own one), check the battery pack for charge. Under normal conditions, they should measure a couple of percent higher than their rating. You will have either Lithium Ion or Nickle metal hydride batteries in the pack so should measure some multiple of the nominal cell voltage of one of those types that are respectively 3.6 & 1.2 volts.
Nov 28, 2008 | HP Pavilion dv9000z Notebook
Laptop Won't startup Vostro 1500
See if you can run the Pre-boot System Assessment (PSA) diagnostics. To run the PSA+ Diagnostics on this system, perform one of the following actions:
1) Hold down the <Fn> key while pressing the power button.
2) Turn on the system, press <F12> at the initial Dell™ logo screen, and select “Diagnostics” from the boot menu.
3) Disconnect the AC power and remove the battery. While holding down the power button, insert the AC connector into the back of the system. The system then starts and the message “Diagnostic boot selected” displays. The system then launches the PSA+ Diagnostics.
According to Dell specs, there is no error code listed that you described, (Flashing Caps LED). Also try reseating the memory modules, (you might want to try this first).
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 07, 2008 | Dell Vostro 1500 Notebook
Computers & Internet Logo
322 people viewed this question
David Payne
David Payne
