Question about Vacuums
Instructions on how to use a food vacuum sealer
  • 1 more comment
  • Anonymous Aug 13, 2008
    hi,i need instructions for this,i dont have pdf,and i have dialup so i cant dl it...can any1 get it onto a txt file?thanks
  • savaged_4 Sep 01, 2008
    i bought the carpet cleaner at a garage sale and cannot ge it to do anything at all. not even turn on! need some instructions on how to use it pls
  • raebrad Sep 12, 2008
    My problem was not with vacuum cleaners, rather it was with food vacuum sealers. Thanks for trying anyhow.
I'm trying to clean my carpet i sprayed some 409 cleaning foam on the floor. now i want to **** up the dirt. how do i get it to **** up the dirt from the floor?
Posted on Sep 12, 2008
Where can I purchase Polyscience 300 Series after checking the price?
Vacuum sealers are a great way to get more out of the food you buy. With proper storage, they can significantly extend the lifespan of your food, prevent spoilage, and minimize waste. They're a powerful money-saving tool that benefits families, homeowners, and food lovers. POLY SCIENCE 300 SERIES is the best sealer and comes with features like :
  • Versatile vacuum sealer that works with a large variety of different foods
  • Built-in marinating cycle extends the abilities of this machine
  • Stainless steel construction and many more. To get the price detail click here.
Apr 20, 2017 | Vacuums
How to Choose a Vacuum Packaging Machine?
When purchasing vacuum packaging machine, due to there are too much alternative models, people always become confused that how to choose a suitable vacuum packing equipment? Following analysis is conductive to your choice.
1.To determine the nature of products.
Different vacuum packaging machines are suitable for different products, some products with special properties, such as fluid, powder, granular and lump objects, etc., should not only satisfy the vacuum packaging function, but also asked to achieve better effects of vacuum packaging.
2. To select the appropriate vacuum packaging machine models.
Thinking about the function, vacuum packaging machine has many types, including ordinary ones, rolling ones, continuous stretch film ones and small vacuum packaging machine, etc, according to different production, people can select vacuum packaging equipment that fit themselves.
Different functions: Automatic stretch film packaging machine, single or double chamber vacuum packaging machine, automatic vacuum packaging machine, skin packaging machine, cassette vacuum packaging machine, rolling vacuum packaging machine, air switch installed packaging machine.
Different materials: all stainless steel, semi-stainless steel, ordinary steel, plastic spraying.
Different vacuum pumps: domestic special pump, imported vacuum pump, special vacuum pump. Imported pumps are more expensive, domestic pumps are relatively cheap, customers can choose them according to the practical situation.
3. Whether the power supply of workshop is suitable for vacuum packaging machine.
Some vacuum packaging machines apply to 380V power and some are suitable for the 220V power. If the power is too far away from the vacuum packaging machine, longer wires is required, and this situation may cause inadequate voltage, affecting production. Therefore, people should buy vacuum packaging machine according to the power of their factory.
4. Evaluate quality and after-sale service, etc. of vacuum packaging machine and choose cost effective vacuum packing factory, since this will reduce a lot of trouble for use.
5. Before purchasing a vacuum packaging machine, purchaser should consult with manufacturer on parts supply problems, to avoid delay in production caused by the malfunction of vacuum packaging equipment.
Dec 21, 2016 | Vacuums
Cannot get it to vacuum.
Does it try to vacuum but never flattens the bag? Make sure the bag you are using is completely sealed on the opposite end. Otherwise, the seal on the sealer is probably allowing air to leak into the sealer. If it has a foam sealer, I've found it sometimes helps to run the foam sealer under water, squeeze out the excess water, reinsert the foam sealer (make sure it is seated all the way) and then try again to seal the bag.
Mar 07, 2016 | FoodSaver Food Saver Vacuum Sealer...
Why does the vacuum sealer not seal the bag nor seal?
wow when I ran my food business I seemed the only one that could get this thing to seal right every night , Im gonna say it was because I wasn't in a big hurry , these machines work great but there not fast it takes sometimes 5/10 minutes to get a good seal on them , and you cant overload them either , when it comes to these less is more , makes for a easier time using them
allow the food to stop about two inches from top edge of bag , and wipe any loose food from the sealing surface (inside) as this will affect the seal as well
Jan 19, 2016 | FoodSaver V3420 Smart Seal Vacuum Sealer...
It will seal but not vacumn and seal
is this a vacuum sweeper or a vacuum sealer for food
Feb 07, 2015 | Vacuums
Foodsaver v3820 does not vacuum
the pump is broken. would you like to repair this? if so let me know so i can give you steps---- assuming you have tried the obvious like ---another power source- toggling the power switch- looking for obstructions. let me know good luck
Mar 30, 2013 | FoodSaver V3820 Vacuum Food Sealer...
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
What is vaccum packing?
Vacuum packing is a method of storing food and presenting it for sale. Appropriate types of food are stored in an airless environment, usually in an air-tight pack or bottle to prevent the growth of microorganisms. The vacuum environment removes atmospheric oxygen, protecting the food from spoiling by limiting the growth of aerobic bacteria or fungi, and preventing the evaporation of volatile components. Vacuum packing is commonly used for long-term storage of dry foods such as cereals, nuts, cured meats, cheese, smoked fish, coffee, and crisps and also for shorter-term storage of fresh foods such as vegetables, meats, and liquids such as soups.
Vacuum packing is also used to reduce greatly the bulk of non-food items. For example, clothing and bedding can be stored in bags evacuated with a domestic vacuum cleaner or a dedicated vacuum sealer. This technique is sometimes used to compact household waste, for example where a charge is made for each full bag collected.
Please rate this fixya
Jan 29, 2009 | Vacuums
Vacuums Logo
75 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
