Step
Action
Value(s)
Yes
No
DEFINITION: This diagnostic procedure should only be used if the high beam headlamps are operating properly and the low beams are inoperative.
Did you perform the Headlights System Check?
Go to Step 2
Go to Headlight System Check
Does the test lamp light?
Go to Step 3
Go to Step 5
Go to Step 4
Go to Step 6
Go to Step 7
Go to Step 8
5
Replace the headlamp dimmer switch.
Is the repair complete?
6
Repair the open in CKT 359 (PPL) between the headlamp dimmer switch and the daytime running lamp relay.
7
Replace the high/low beam headlamps.
8
