Question about Whirlpool GEW9250 Electric Dryer
4 wire to 3 wire dryer cord
Mike
thanks for the advice, but as I search the web, I see that I need to get a "grounding strap"? as well to connect the neutral wire to the frame of the dryer, is that right?
thanks again
  • 481 Answers
Usually the grounding strap is still on the machine after the installation of a four prong cord (they just bend it out of the way), if not you can use a wire to connect the neutral to the case or just buy a ground strap when you buy the cord.    (hot wire 110v) neutral wire (hot wire 110v) neutral wire is always in the middle. both on the cord and on the machine
Posted on Jun 28, 2008
Kenmore 700 dryer with a three prong cord is being converted to four prong. Is there a drawing of what wires by color going to the proper screw location?
There's a ground strap wire (green/yellow) attached to the dryer cabinet and connected to the center terminal where the white neutral wire of the power cord is connected. Disconnect this ground strap wire and remove the 3-prong power cord from the terminal block taking note where the wires are connecedt to. Connect the 4-prong power cord in the same way same wire colors of the 3-prong cord are connected to the terminal block. Connect the ground strap wire to the remaining fourth wire (green/yellow). Just do the reverse when converting 4-prong to 3-prong. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 13, 2011 | Kenmore 700 6972 Dryer
How to connect power cord
Hello Jake. It depends on whether or not you have a 3 prong cord (3 wires), or a 4 prong cord (4 wires). So I'll just tell you both.
For Three Prong Cords
the Center cord wire goes on the center terminal,
the left on the left ,
and the right on the right.
Note: There should be a ground strap or wire that runs from the center terminal to the dryer case
wrightly_3.jpgHere is an example of a 3 prong cord for a whirlpool dryer. If your terminal block has 5 screws, you still do it the same way as stated above. these wires are not colored. You should have a strap in the middle that is connected with the middle wire. Sometimes there is a wire attached there instead of a strap.
For Four Prong Cords
the White cord wire goes in the center,
the Red on the Right,
the Black on the Left.
The green cord wire goes to the case or the external ground screw.
Here's an picture to use as an example;
wrightly_4.jpgJust be sure to use the strain relief at the opening where the power cord first enters the dryer. It will help secure these connections against being pulled loose or cut on the cabinet, and that could pose a risk of you coming close friends with 240 volts. Not a friend I want to have.
I hope this is helpful,
If you have any questions, feel free to ask.
thanks for using fixya
Mike W.
Aug 12, 2011 | Whirlpool Dryers
I need to change powercord from a g & e electric dryer.it ends into like a square black block,going inside dryer.
It depends on what type of cord you are changing to. I think what you're describing as a sqaure black block is the terminal block.
If your new cord has four wires, should be black, white, red, and green. If this is the case, it goes like this:
Black to the far left screw (L2)
White to the middle screw (N)
Red to the far right (L1)
Green goes to the cabinet, usually behind a green screw.
If this is the case, you're changing from a 3 wire cord to a 4 wire cord, and your 3 wire cord is still connected; then behind the middle screw is probably a strap connected underneath it. When you change to the 4 wire cord, bend and push the strap up out of the way for future use if needed. It acts as the ground for the 3 wire cord.
With the 4 wire cord, the green mounted to the cabinet acts as the ground.
Now......
If i'm wrong with the above, and you're intalling a 3 wire cord; they could all be the same color (the wires). If so, just put....
The far left wire to the far left screw.
The middle wire to the middle screw with the strap attached to it.
the far right wire to the far right screw.
I hope this is helpful, and that I havent completely misunderstood you and wasted your time. I would be glad to help any further if you need it.
Thanks,
Mike
Jul 26, 2011 | Dryers
Wire hookup
You have to remove the cover plate on the back to access the terminal block.
If you have a 3 prong cord;
The center wire goes on the middle terminal. There should be a strap for this one that's connected with the wire.
Left wire to the left terminal, Right wire goes on right terminal.
For a 4 prong cord;
The black wire to the far left terminal, The red wire to the far right terminal.
The white wire goes to the middle terminal, however fold the strap up and away for future use.
Green wire is bolted to the cabinet for ground.
I hope that helps.
thanks,
Mike
Jul 21, 2011 | Dryers
I am changing the 4 wire on my 2 yr old maytag dryer to a 3 wire to fit the recptical in my new house. Other then the 2 hots and 1 neutral connection, my dryer also has a white ground wire off to the side,...
So you have an, ahem... problem....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
At this point - you have two choices....replace the wiring from the dryer's breaker to the receptacle with all new 8/3 with ground romex (it more then likely only has 8/2 with ground now)....and replace the receptacle with a 4 prong grounding receptacle to match your dryer's cord....OR - as an alternative - you can replace the cord on your dryer with a 3 prong cord to match the existing dryer receptacle outlet.
Out of the 2 choices....the first one will bring the old wiring in the home up to current Codes (all NEW homes must have this 4 wire/4 prong set-up per Code...but older homes are grand-fathered)...but it is clearly the most involved, time consuming and most costly approach...and it is recommended only an electrician do this work. If this approach is taken....your dryer cord can stay as is...it will now fit the new receptacle outlet with no modifications.
The second approach - is to pick up a 3 wire 3 prong cord at your local hardware store to match the existing 3 prong receptacle.....and replace the 4 wire cord on your dryer with it. Although this is the least desireable - it is an allowed approach because this is an older home with existing wiring. This is a much less involved approach...all you need to buy is the 3 wire dryer cord (they come all ready to go) remove the 4 wire cord and install the 3 wire cord to your electrical connections at the back of the dryer. Hopefully...when the 4 wire cord was installed on your dryer, the ground strap wasn't removed completely (this is a metal strap that will connect the white wire to the metal frame of the dryer)...because now you will need to re-use the ground strap. For more on this....see the images of the differences of the 3 wire and 4 wire dryer hook-up at:
http://www.applianceaid.com/general.html#3to4
NOTE: the only real difference between the 3 wire cord and the 4 wire cord is now the white neutral and the ground are kept seperate in a 4 wire..the green ground will connect directly to the dryer frame....where in a 3 wire there is no seperate ground wire - ground and neutral are one and the same...the ground strap connects the frame to the white neutral. The 4 wire permits a better safety measure...in the event of an electrical problem (ground fault) in the dryer...the fault now has a seperate path to your panel's ground...and less chance of a shock from touching the metal frame of the dryer.
The choice of how to proceed is up to you....if you go with completely updating the dryer wiring from the breaker outward...I recommend an electrician do this work for you (it's about an hour's work...plus materials). Then your exisiting dryer's 4 wire 4 prong cord can stay as is....the electrician will install a 4 prong receptacle made to fit your cord.
If you go with simply replacing the dryer's cord....changing it to a 3 wire so it will fit the receptacle...make sure the ground strap is re-utilized as seen in the images at the site above.(also make sure all work is done with the dryer breaker (or fuse if a really old home) off before starting any work. If you change the cord yourself...make sure to reconnect in exactly the same manner as the previous cord was connected...(make a note on paper or take pictures so that there are no mistakes)..and that you tighten the nuts securely to the posts once the wire lugs are on them. Where you state you do not have a background in electrical work...you can have an electrician change this cord for you...(typically in under a half-hour)....or you can do it yourself - by carefully following the pictures.
The choice is yours...if it was me - I'd change the wiring from the breaker outward...making the older home meet today's current Codes and be complaint for this dryer..and then you wouldn't need to change a thing on the dryer....but you can go either way....Codes allow this grandfathering in older homes with existing wiring.
Feb 19, 2010 | Dryers
How to hook up a 4 wire plug to a Maytag clothes dryer model LDE8824ACM with 3 wire connecters.
Feb 09, 2010 | Dryers
Need to replace existing three wire plug with new four wire plug. there are only three terminals to connect to. what do i do?
Based on your description....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
Feb 08, 2010 | Dryers
Need to change from 3 prong cord to
disconnect the green or brass ground strap from the terminal block to the body then wire the new plugs three colors the same as the old then connect the green from the plug strait to the body. on a 3 wire the dryer is grounded through the neutral, on a 4 wire the ground goes to the body.
Dec 02, 2009 | Dryers
I have a new 4 prong plug to replace a old 3 prong on dryer
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom/right.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Sep 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
Whirlpool GEW9250 Electric Dryer Logo
95 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
