Question about Tomtom GO 700 GPS NAVIGATION BRAND ONLY $9.95 SHIPPING
Amp stereo hook ups
I have a sony xplod in dash stereo that i would like to put with a jensen 300 watts amplifier....i need to know how to do the right connections
  • 624 Answers
You need to run RCA cables from the RCA output jacks on the back of the Sony to the input RCA jacks of the Jensen amp. Then you need to run a wire that connects to the blue wire of the wiring harness on the sony to the "remote" or "turn on" terminal of the jensen. That is the wire that turns the amp on when the radio is turned on. It should be on the power wire terminal of the jensen along with the +B (positive) and the GND (ground) terminals. Those are the only ones that go from the Sony to the Jensen. You also need to have the speakers connected to the speaker jacks of the amplifier, and the power wires connected to the power terminal of the amp. The positive power wire needs to go to the positive battery terminal and the ground should be connected to the chassis of the car close to the amplifier. make sure the ground is connected to a clean bare metal part to make sure it is good.
Thats all, but you also need the proper guage wire and make sure no bare wire is exposed to any metal areas or the chassis of the car. You can get all of those things at anyplace that installs car audio. They can tell you the proper guage wire and they have the RCA cables to.
If you are not experienced at this type of installation you really would be better off lettng a professioanl do it for you. It is easy to wire something wrong and damage the amp and/or the receiver.
The wires also need to be run in a place that they will not be damaged and are out of the way.
Ihope this helps you, and please be careful. Help is here if you need it.
If you found this information to be helpful a rating of "FixYa" would be appreciated. It is the only reward we get for the free help we offer.
Posted on Jun 28, 2008
How do I Wire my 12" kicker cvs to a sony xplod 800-watt amp for best possible sound.
I would first need to know what the impedance level is for that sup. You may be able to hook this in mono or in stereo. But you definitely do not want to connect it up to the amplifier where as to cause damage.
Jun 01, 2014 | Rockford Fosgate Car Audio & Video
My stereo in 1997 chevy caviler is turning off and on when turned up to a high volume. I have a sony xplod 52 watt by 4 channel radio. With two 6x9 sony xplod 50 watt rms and 300 watt peak power in the...
Most likely cause is heat. The clearances behind the radio are often not sufficient to provde the proper air coolling that the higher power radios need. The heat sinks on the rear of the radio require a certain amount of air flow to dissipate the heat generated under high load conditions. If you add summer heat to the equation, you can have the radio going into thermal cutout to protect it circuity.
May 27, 2011 | 1997 Chevrolet Cavalier
I have my amp hooked up perfectly, but why won't it work? is there a re-set or somthing? i checked fuses and everything
Unlike the stereo unit, amps doesn't have a reset button.
Check the fuse in your hood.
Check all wiring, especially the ground to chassis.
Check for voltages, remote turn on should have 12V to ground and power cable should have around 12 to 14 volts.
Sep 19, 2010 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
I hooked this 1000 watt amp turns on but it
Your amp needs to be serviced. Bad protection circuit. Take it to a local car audio shop and have them bench test it first to be sure. Hope this helps.
Sep 26, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
How to measure watts
You need a Volt Meter and an Ohm Meter. P = VI & I = V/r, so Power = (Volt^2)/Ohms .
You can get the ohms by hooking them up to the subwoofer input wires, and you get the volts by hooking up to the amp output terminals/wires. Although, amps will put out different voltages for different frequences, this should give you ballpark estimates.
Nov 10, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Additional speakers
does your stereo have additional outputs? you can get around that. anwser is: depending on the amp, yes you can.
Sep 20, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Hooking Up A Sony XM754HX To Jensen BP210
hi .let me see if i can help u out ...need more info on the speaker..are the 8ohm or 4ohm ? and are the single are DVC?.....from what i can see u can bridged the amp..and u must connet the subs in series or just connet each sub +/- to +/-..and that will give u a stereo mode... u will still get great sound
Jun 21, 2008 | Sony XM-754HX Car Audio Amplifier
Car amps
important is to hav correct wires and groud cable...
Dec 29, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
1000 watt amp sony xplod
how do you have your system hooked? What speakers do you have? There is a lot more too it then just wattage.
Jan 23, 2007 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
123 people viewed this question
Top Tomtom Car Audio & Video Experts
xxxxxx xxx
Are you a Tomtom Car Audio and Video Expert? Answer questions, earn points and help others
