Question about KitchenAid KTT570 4-Slice Toaster
Electrical Toaster will not start - KitchenAid KTT570 4-Slice Toaster
  • walshhoward Oct 10, 2008
    Toaster just stopped working....no lights or display when you plug it in
  • 87 Answers
Short in the wire you will need to bye a new one are return this one.
Posted on Jul 12, 2008
My Breville digital toaster is making crackling noises.
your question is under coffee maker category and it is about toaster.
Anyway your toaster should not make crackling noise indicatve of arching. If it has run its life, change it
Nov 18, 2013 | Breville Coffee Makers & Espresso Machines
Delonghi xr640 toasting-finished chime not working
follow this steps and fix it. God bless you
f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
Euro pro to241r
If the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the electrical cord.
If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse.
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostat .
Oct 10, 2013 | Toaster Ovens
Dualit toaster - timer sticking.
The dualit all electrical parts like elements and timer switch are all manufacture in china and they are not as they used to be. I have a customer with a toaster of 25 years old and we have replace only one heating element up to now. For recent models we replace electrical parts in about 2 to 3 years, some times every year as you describe.
Feb 22, 2010 | Dualit Vario 3 Slices Toaster
Electrical wires connection
Placed the item in the trash can.
Thanks
Dec 06, 2009 | Toastmaster TUV48 UltraVection 1400 Watts...
Rival to606 temperature control doesnt work, unit doesnt heat up
The heating bar or element needs replacement.you can find it in electrical shop or electronic and electrical supplies in your area.
If you find this answer helpful, kindly vote it.
Nov 09, 2009 | Rival TO606 1500 Watts Toaster Oven with...
Right side stopped working
In the manual:
Check to see if the toaster is plugged in; if it is, unplug the toaster, then plug it back in again.
A tone will sound when the toaster is plugged into a live electrical outlet.
If no tone sounds, check the electrical circuit the toaster is connected to -
is a fuse blown or a circuit-breaker tripped in your home?
At least with "unplugging and plug it back again in the electrical outlet" the right side of our toaster works again. The tone that should sound with plugging in didn't work...
Aug 15, 2009 | KitchenAid KPTT890 Pro Line 4-Slice...
Toaster not working
Is the electrical outlet working? Plug something else in (a lamp perhaps) and see if there is power to the plug.
Hamar nnelg
Mar 25, 2008 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
Failure of toaster oven
Hey, I once had the same problem, but then we discovered that one of the electrical cables had split, or it could just be the age of the Toaster. Try to take it apart and look for were the main cable spits up. Then go from there. If it is not visable, then the problem may be in the main cord. If none of these suggestions work, I suggest that you take it to your local electrical store.
Oct 22, 2007 | Kitchen Appliances - Others
KitchenAid KTT570 4-Slice Toaster Logo
117 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
