I am in NZ and have philips 616K dvd player. Have some dvd's origin UK that wont play on my dvd. Comes up wrong region. My daughter also in NZ has played these dvds in NZ but not sure what brand dvd she has. Is it because of the possible age of my machine which was given to me about two years ago. Regards Sue
  • 376 Answers
Changing the region code for DVD616K :
1. Press OPEN/CLOSE, and wait for the tray to open.
2. Use the remote control to input digital key '1', '1', '1', 'l' in that
order.
Kindly leave a few seconds between each entry, the microprocessor is slow
with these entries.
3. Press number '7', '8' or '9' to display the current region code of the DVD
player.
OR
4. Press any number of '0' to '6' to set the required region code. The OSD
will display the new region code of the DVD player.
5. Region '0' will be the setting for multi region
6. The region setting will be saved in the FLASH memory.
7. Press OPEN/CLOSE again, the DVD player will return to normal operation.
Posted on Sep 09, 2008
PHILIPS DVD player 616K, how to change region or get into right region. my player was working OK. Suddenly it stopped functioning and showed/diplayed '' wrong region'' on the TV screen.
2. Use the remote control to input digital key '1', '1', '1', '0' in that order
if that dont work go 1, 1 1, 1 in that
order.
with these entries.
player.
OR
note: you want to chose region 0 so u can use all regions
Nov 15, 2009 | Computers & Internet
Can I play a dvd region 2 dvd on a Philips 5 disc changer 783c dvd player? its a uk release of a german film. The DVD player gives system menu selections stating many nationalities
just because it may have many languages does not mean it is multi-region.
what you need to do is search for "region free hack" and the model of your player.
If there is one for your player the process takes less than 30 seconds to do (did on my single play philips which is region free whoo hoo)
beware though you may have to spend some time finding the free codes and there are a lot of sites out there that want to charge for this info (dont pay just persevere)
The method is usually power on the dvd press eject whilst holding down a key combnation until a menu comes up then selecting 0 ZERO as the region or somthing similar there are variations even from the same manufacturer.
I disagree with the whole region scam and do not class hacking a dvd player as any form of piracy. its simply allowing me the freedom to choose what i watch from whatever country i want.
Aug 11, 2009 | Philips Televison & Video
Changing of region code
I have the same system and I changed the region code to muti by pressing STOP 7344660 after opening the tray as per instruction I read in the net.. It worked.. on the TV screen it displayed region as 0
Aug 05, 2009 | Philips LX3600D System
How do I unlock my LG RC388 to play other region disks
YES, it can be changed to view all regions. I've just done my new RC388 (bought it 4 hours ago) and it works.
To start the hack:
Click the home button on the remote, go to the Setup page, highlight the 16X9 TV aspect ratio and enter in this coded sequence: 1 3 9 7 1 3 9
A new factory menu now comes up on the screen.
To change the values of these options hit the enter button and scroll with arrow keys until you get to the option you want to change. For the region code hack replace the value of "option 5" with the value of: ff
Press enter.
(Changing this value will set unit to region code 0 which should allow any region to be played on the player.)
Now, hit the "return" button to save and exit.
Switch off the machine - switch on - all is well now.
Good Luck,
Will
Mar 31, 2009 | Televison & Video
WRONG REGION on the screen
Have you checked the region in your Disc Properties? Go into Disk Management, find your dvd and right click on it. Go into the properties and you will see a heading for Regions. In there it explains a bit about regions, which should be at 2. If it is not, then change it to 2. Let me know if this doesn't help.
Feb 02, 2009 | Philips Phillips 16X External DVD 2XRW...
Dvd wont play
http://www.avforums.com/forums/dvd-player-hacks/367355-technika-1030-tesco-value-dvd-player.html
try the link I've copied in above.
it tells you how to change the region to multi region. where you can play ntsc and pal.
We use pal in the uk.
Dec 31, 2008 | Panasonic DVD-S27 DVD Player
Wrong Region message
This will make the player region free so it'll play anything. It worked on mine and i have the same player.
remote control :
- Press "System Menu" key to enter Set Up menu.
- Move to "Preference Page" using arrow keys to the left or to the right.
- Press the following sequence in the remote control: 135566
- A menu indicating "Region Code" will appear.
- Change region using arrow keys to top or down. Region Code = 0 will play all regions.
- Press "System Menu" key to exit Set Up menu.
Jul 14, 2008 | Philips DVP5982
Philips 7" DVD portable player
The PET702 will be a region 5 machine, whereas the UK DVDs are region 2.
DVD players from a particular region are designed to play only DVDs from the same region, due to copyright and distribution rights in each country or region.
However the PET702 can have the region protection removed by making it multi-region:
Switch on the PET702 and Open the tray.
Press SETUP button on the remote control, which will bring up the menu.
Highlight "PREFERENCES" and press OK.
Press [2], [5], [2], [3], [1], [5], [LEFT], [DOWN]
The screen will show: "Region Code: 2"
Press [1-6] to manually set the region OR [0] for multi-region.
You will now be able to play DVDs from anywhere in the world.
This is particularly useful, because region 1 DVDs from the US often come out when the movies are still in the cinemas over here. Region 1 DVDs can be bought perfectly legally by mail order or from the internet.
May 07, 2008 | Televison & Video
DVD player must be made region free by unlocking it.. after that you can play all the discs you want.. for ubnlocking it you can try google//
Jan 19, 2008 | Philips DVP-3005 DVD Player
Multi region
Your DVD player can be hacked by following the attached guide so that it will play any region. http://www.videohelp.com/dvdhacks/philips-dvp-320/3522
Jun 21, 2007 | Philips DVP320 DVD Player
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
