Aroma Health Grill AHG1125 Logo
Apostle Patricia Holley Posted on Dec 07, 2010
I need a temperature regulating thermostat model arg11257
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Jul 12, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
1187
Points
8
Hi, not sure if you are still looking for a replacement thermostat for your health grill but we have just listed an Aroma Health Grill on eBay, Model AHG-1125. It is used but in great condition. Take a look at http://www.ebay.co.uk/itm/251106355119?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
The listing ends on Sunday 22nd July, at 8:51pm. Cheers
Roper oven model FEP310GW0. Oven will not heat
If your Roper oven is not heating, there are several possible causes. Here are some steps you can take to troubleshoot the issue:
  1. Check the power supply: Make sure the oven is properly plugged in and that the circuit breaker hasn't tripped. If the oven is getting power but still not heating, move on to the next step.
  2. Check the heating element: The most common cause of an oven not heating is a faulty heating element. You can test the element with a multimeter to see if it's working properly. If the element is faulty, it will need to be replaced.
  3. Check the temperature sensor: Another possible cause of an oven not heating is a faulty temperature sensor. This sensor regulates the oven temperature, so if it's not working properly, the oven won't heat up. You can test the sensor with a multimeter to see if it's working properly. If the sensor is faulty, it will need to be replaced.
  4. Check the oven control board: The oven control board regulates the oven temperature and controls the heating elements. If the control board is faulty, the oven won't heat up. You can test the control board with a multimeter to see if it's working properly. If the control board is faulty, it will need to be replaced.
  5. Check the oven thermostat: The oven thermostat regulates the temperature in the oven. If it's not working properly, the oven won't heat up. You can test the thermostat with a multimeter to see if it's working properly. If the thermostat is faulty, it will need to be replaced.
If you're not comfortable troubleshooting the issue yourself, it's best to call a professional appliance repair technician to diagnose and fix the problem.
Jan 31, 2023 • Ovens
Maytag mgr7775wb is not regulating temp properly
Why is the oven temperature incorrect?
The oven temperature controlis usually controlled by a thermostat that uses a capillary and liquid filled bulb. When the bulb's liquid gets heated up, it expands and puts pressure on a diaphragm which opens and closes a switch that controls the gas to the burner. Just set the dial to what you need the temperature to be. Over time, it is possible for your thermostat to lose its calibration. Sometimes, the thermostat sensing bulb comes loose from the holder. If it is out of place, the thermostat may be getting faulty readings. If this is the problem, re-aligning the bulb properly will take care of this problem.Digital display models use a sensor to control temperature. If this is faulty, replace it. Other ovens use a mechanical system to control the temperature.On many models, you can adjust your oven thermostat using a small screwdriver. The adjusting screw is located on the thermostat valve stem. Remove the knob and you'll see the screw underneath it. You want to turn the oven on and run it through at least two cycles while watching a calibrating thermometer in the oven for high and low temperatures. Adjust the screw as necessary to fine tune the temperature.Some models don't have an adjustable thermostat, and you will have to replace the thermostat if you want to resolve the problem.
The oven sensor:works with the oven control board to regulate the oven temperature. If there is an oven temperature problem, this sensor might be defective. The sensor can be tested by using an ohm meter. As temperature rises, the resistance measurement also rises. The manufacturer of the oven sensor determines the correct resistance,Oven temperature problems can be caused by other things,but this is one of the common causes.
Beware on some models nowmost of these ovens they are electronic and they are integrated into the control itself
some different sensor ohm readings at room temp. approx 16 ohms at room temperature and at 350?F it is 29~33 ohms.
Read more:
http://www.justanswer.com/appliance/5xrsf-ge-xl44-gas-oven-oven-ignites-even-when-oven.html#ixzz3YdtiPcn8
The reason for my free advice is GOD is good!
Food on top shelf is freezing
Not sure what model you have so I need to guess that it only has a thermostat control that regulates temperature? Can you post the Model Number? If your model only uses the temperature control to regulate temperatures then I suspect that the temperature control is at fault and needs replaced. Spare parts HERE Can you locate your model number? Click HERE I am here should you need me, Thanks John TrippAppliance 911
Contact Me Here
4helpful
4answers
Po128 is the code. What's the problem
Well, I can't give you any specific information regarding your vehicle because you forgot to mention what kind of vehicle you have. (This is kinda important if you really want some help figuring out what is wrong with your car)
The "Generic OBD" of code P0128 is "Coolant Temperature Below Thermostat Regulating Temperature"
The most likely cause is a stuck-open thermostat, however, I have also seen defective Engine Coolant Temperature (ECT) sensors also cause this code.
What is the use of fan thermostat controller and explain about it?
A thermostat is a device for regulating the temperature of a system so that the system's temperature is maintained near a desired setpoint temperature. The name is derived from the Greek words thermos "hot" and statos "a standing". The thermostat does this by switching heating or cooling devices on or off, or regulating the flow of a heat transfer fluid as needed, to maintain the correct temperature.
5helpful
2answers
Check engine light on, diagnostic code 0128 and 0410 keep coming up
P0128 - Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
P0410 - Secondary Air Injection System Malfunction
(has to do with exhaust system)
Note: There is a technical service bulletin (TSB) regarding code P0410 for a number of GM models. The TSB calls for the replacement of the AIR pump and the installation of a new secondary injection hose.
Top Aroma Kitchen Appliances - Others Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Don A
Don A
Are you an Aroma Kitchen Appliances - Other Expert? Answer questions, earn points and help others
