Buzzing noise from color wheel
Thanks for helping me pinpoint the problem. I will order the part and attempt the repair.
  • Anonymous Nov 22, 2008
    On my Toshiba 62hm95, I have a humming noise during power on and also after power off for a few minutes.
  • 8,617 Answers
Youre welcome let me know if I can assist you further.
Posted on Jun 28, 2008
I have the samsung DLP HL-6163W model. I've had this TV for 6 year, and have logged many hours on it. Tonight, the TV started making a buzzing noise in the back, and the colors got all screwed up. I...
This tv have a colors wheel design in it to this tv.The buzzing noises and the colors are all screwed up because the colors wheel is worn out and spinning off of is axis and rubbing it against the wall of it hall of the steal box frame that hold the colors wheel itself.Don't attemp change the colors wheel by ur self,if u have no mechanical skills.Bacause the colors wheel itself sit way back of the tv,have to take out many mechanicals parts,before can come to the colors wheel itself to replace it.Because u will regret it later if u putting the colors wheel itself in wrong.Hire a tv repair person to replace it.
Apr 04, 2011 | Samsung HLP6163W 61" Rear Projection...
I'm experiencing a loud buzzing (fan?) sound that just started recently while watching my HLP5674W. The picture is fine, but the sound of what may be a fan or something like that is very loud and will...
Loud sound would be coming from defective color wheel that is mounted i light engine, next to lamp housing. Replacement of color wheel is required expertise/ experience and professional will do that for you in correct and in safe manner.
Contact local tv repair shop to get color wheel replaced in tv.
Thanks.
Oct 19, 2010 | Samsung HLP5674W 56" Rear Projection...
Buzzing noise, just replaced the lamp, pulled and ...
The colors wheel was defective,was spinning off of it axis that was where the buzzing noise came from.Now the colors wheel it totally dead,that why u not hearing anymore buzzing noise,and not getting a picture.Hire a tv repairman for this job.Replacing DLP tvs colors wheel is not easy,if u have no machanical's skills and never done this before.
May 21, 2010 | Samsung HLN5065W 50" Rear Projection...
My tv is making a loud buzzing noise
Bearings in color wheel going bad and needs to be replaced. Call a local tv repair shop on pricing and availability of color wheel for your model and chassis
number.
Dec 03, 2009 | Samsung DLP HL-P5663W 56" TV
I have a Samsung rear projection tv. It has been
The Lamp probably is bad but it going bad would not cause a buzzing sound. I have a hunch that the Color Wheel Motor is bad causing the buzzing noise. It is a major repair and the cost would be expensive. But this is the deal, you will need to get a qualified repair person out to confirm the symptom to be sure. You can go ahead and replace the Lamp to get the set working again and use it for as long as you can stand the buzzing noise. If it is the Color Wheel Motor, I would check prices on replacement sets just to get a feel of how much you are willing to spend for repairs.
I hope this helps,
Skyassoc
Oct 28, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Loud Humming Noise
Samsung is notorious for having the motor on the color wheel burn out. If the color on the tv starts to fade or shift tones when the rev'ing or noise is happening then you'll know its the color wheel. There are only two moving parts in this set, the color wheel and the fans. If you're smelling something, it could be either. Take the back off the set and put a piece of tape on the lamp door switch and turn the set on. Try to pinpoint the source of the noise. If its a fan, no big deal, Radio shack should have a replacement. If it sounds like its comming from under the set, dig a little deeper and try unhooking the color wheel motor, not as easy as I am making it sound but either way the fan is about $20 to fix and the color wheel is about $100. Sure beats a $400 tech bill. If you get stuck, comment back and I'll send pictures of the dismantle.
Nov 28, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Buzzing noise from lamp area.
if your model is the HDLP50W151 your color wheel is 212.00 at the following link and they provide free instalation instructions and also free tech support to help you with the Indexing when your finished as all color wheels in RCA TVs have to be indexed after instalation. You need color wheel 212184 heres the link
Click on the color wheel catagory on the left column.
http://servicemanuals.vstore.ca/
Jun 26, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
buzzing from the lamp area could be either the fan or color wheel Whats the model number of your set, and I can better answer your question
Jun 26, 2008 | Televison & Video
Samsung HL-R6167W DLP color problem/buzzing noise
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
169 people viewed this question
Top Televison & Video Experts
