Question about Bushnell Deep Space 78-9003 (525 x 76mm) Telescope
Assembly information need instructions for secure and correct assembly
  • 3,186 Answers
All of Bushnell's manuals are on this web site:
Download your manual for free-
Posted on Jul 09, 2011
Need assembly instructions
If you use the bolts and nuts, it should go together easily. 'need assembly instructions' does not help with your question, as there is NO information about your subject. PLEASE put more information in ANY question you ask. Could you help if I said I have a green car and need to change the radio? What car, model, type make, etc.
Apr 05, 2015 | Furniture
Victoryland Black Metal Futon Frame assembly instructions
You should contact the store you bought the futon frame from and ask them to send you the assembly instructions or to give you the contact information of Victory Land.
Aug 24, 2012 | VICTORY LAND Shopko Victoryland Black...
Turn indicator/wiper switch assembly replacement instructions please?
steps required to remove and replace indicator switch assembly.
1.disconnect the battery earth lead.
2.from the rear of the steering wheel remove the screws retaining the horn pad..
3.lift the horn assembly away from the steering wheel far enough to remove wiring.
4.Once that is done then move to the next step.
5.Remove the locknut and steering wheel nut .
6.then mark the end of the steering shaft and the steering wheel to correctly relocate and install in same position.
7.then with the correct tool remove the steering wheel from shaft.
8.then once the steering wheel is removed you can then move on to removing the lower steering column cover screw and then remove cover.
9.disconnect the wiring from the multi point connector under instrument panel.
10.release and free wiring harness.
11.unscrew and remove the hazard switch knob.
12.remove the dipper-wiper switch securing screw and manoeurve the switch upwards.guiding the wiring through the column. will actual find there are 3 phillip head screws securing the switch to lever switch to the combination switch.
14.when putting this assembly back to together just follow these steps in reverse..
hope you find this helps you
Aug 03, 2012 | Holden VK Cars & Trucks
How to assemble a Mainstay glass folding table
I suggest that you call the store that you got the table from and ask them to either send you assemble instructions or give you the contact information of the Mainstay company.
Jul 31, 2012 | Garden
Need instructions to assemble a Mainstays 40" Glass folding table
Hello, The passenger's side sliding door on a 2004 Kia Sedona minivan, does not close correctly, unless you push really ******* the door to help it close. I believe the latch needs to be cleaned and...
Kia doesn't publish instructions for servicing JUST the latch assembly for the sliding door. They only have instructions for disassembling the ENTIRE door.
Basicly, this is what you need to do.
Remove the screws and the door finish panel. Part of it simply "clips" into place. Make sure all of the screws are removed before pulling on the panel to get the clips to let go. You will have to be inside the vehicle with the door closed to access some of the screws. The others can be accessed with the door partially open. The door will have to be open to get to the screws at the bottom of the door.
Remove 3 bolts securing the inner door handle.
Carefully peel the door screen (plastic film) from the door.
There should be 3 bolts securing the latch assembly to the door.
Release the clips securing the outer door handle linkage to the latch assembly.
Remove the latch assembly.
Reverse procedure to install.
NOTE: There is also a Technical Service Bulletin (TSB) published by Kia that addresses sliding doors that are hard to open or close. It covers all the ADJUSTMENTS on the door that can cause these types of problems. The bulletin itself has lots of pictures and instructions about how to check for the actual CAUSE of the symptom and how to make adjustments to correct it. It is too large to post a copy here. You may try going by your Kia dealer to see if they will print a copy for you. If not, you can access the information by subscribing to AllData DIY for a small fee. (around $27/year)
It is Bulletin Number TT820405-001
Sep 05, 2011 | 2004 Kia Sedona
I need remove the avast anitvirus of my computer, but is impossible, because i need addictional another antivirus
If I understand your question correctly, you want to remove your installed avast anti-virus but you are hesitant from un-installing because you are leaving your computer defenseless. If correct, I can suggest you use Microsoft Security Essentials. It's free and protects your computer just as good as any anti-virus commercially available in market today.
You can download Microsoft Security Essential from here-
1) Click download button.
2) Run the setup or the installer.
3) Follow the instruction prompted to you.
I hope the above information will be helpful. Thank you for using Fixya.
Feb 20, 2011 | AVAST Software Avast Free Antivirus
Hi, I have a Bush Fp026 food processor and am having problems getting the mixer/processor element to work. The blender is fine, but how do I get the mixer working!? HELP!!
Are you sure you have the Model Number correct. I believe the Bush appliances are also marketed under the Kewwood brand name. Was able to find information for the Kenwood FP260. When you see the picture on the front you should know if it is applicable to your product,
The instruction book is available here.
The machine will not work if not assembled correctly. Check the schematic provide for assembly and make sure you are putting the processor together correctly. The fact the blender works fine suggests that when you assemble the processor it is not engaging with the safety switch which would allow power to engage.
Information on other models can be found here.
Feb 02, 2011 | Microwave Ovens
Can't get the Linksys Router's list of Network Security Settings
The router has a built-in web-server.
So, just connect your web-browser to that web-server,
select the correct page, and click PRINT.
Jan 01, 2010 | Linksys WRT160N Wireless Router
Little Tikes Swing Along Castle
Your 4 screws may hold the swing piece to the slide piece. You actually secure it to the slide side wall with one of the red screw caps but you can also secure it with 4 screws that screw into the plastic.  You can also find the manual and assembly instructions at
Mar 04, 2009 | Little Tikes Swing Along Castle
Bushnell Deep Space 78-9003 (525 x 76mm) Telescope Logo
139 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
