Question about Samsung DLP HL-P5663W 56" TV
Humming noise when turned on
My tv hums continuously when turned on .is there a setting problem ,age problem?
    Sergeant:
  • 291 Answers
Annebatiste:
Humming almost always comes from DC supply problems.A leaky SCR [silicon control recitfiter] transistor [used in a/c to dc power supply], leaky Capacitor [large metal type for heavy voltage\current], bad or value changed bias for SCR transistor, value changed filter resistor and loose transformer[Xformer] that the coils INSIDE vibrate sending a radio frequency [R\F] SIGNAL (like a radio station) into the audio amp section or right into the speakers causing the hum.
Check entire power supply, all filter capacitors, coils, chokes ,transformers (somtimes used to push signal into speakers)
Posted on Jun 28, 2008
Guitar amp continuous humming from speaker
Firstly, do not disconnect the speakers from the amp when it is on. Damage is possible.
You have a bad ground somewhere in the hookup. The first suspect would be your guitar-to-amp cord shielding connections at each plug, then, the wiring in your guitar. Try changing each of these to another as a trial, one at a time.
Here is Marshall's spiel on hum
http://www.marshallamps.com/support/faq/hums-hisses/
Mar 11, 2014 | Audio Players & Recorders
there's a air break in the tv needs professional service by a electioneer can be dangerous if you attempt to fix it yourself
Jul 03, 2008 | Samsung DLP HL-P5663W 56" TV
The humming noise on my rca scenium starts just a
If this is a DLP set, which I suspect it is....you need a new color wheel. Common problem for these sets. If you don't have an extended service plan, about a 300--400 fix, in home.
Oct 09, 2009 | RCA Scenium HD65W20 65" Rear Projection...
Making a lot of noise
Sounds like a bearing in the cooling Fan
Thanks for using FIXYA
Sep 21, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
Deep Humming Noise
if the noise continues after you power down its the cooling fan
Jan 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Loud noise
I believe it is the color wheel. The motor might be going bad or it has dirt or dust in it.
I hope this helps
Shuttle83
Nov 06, 2007 | Toshiba 62HM95 62" HDTV
Zenith C27V22 27" TV loud humming noise
There is a coil in the set with a magnet glued to it, called the horizontal linearity coil. Sometimes the coil "sings", making a squeeling sound. I have seen this many times, and there really isnt anything actually electrically wrong with the set. To stop the squeeling the coil should be replaced.
Jun 19, 2007 | Zenith C27V22 27" TV
Samsung DLP HL-P5663W 56" TV Logo
139 people viewed this question
Henry  Thomas
Henry Thomas
