Question about Refrigerators
Chest freezer door not real tight can slide a paper inside with it shut
  • 481 Answers
Has the lid been stretched too far back at one time? you may have bent hinges; if not then...
has the machine been unplugged and left in the sun or heat for a while? the insulation in the lid could expand and cause the metal around it to bend causing a uneven seal.
another thing could help; try to adjust the hinges tighter.
Posted on Jun 28, 2008
How tight should the suction be on the door of chest freezer
Hello dotty26 - The door gasket should be securely closing with no resistance. You may try lubricating the door gasket with petroleum jelly to make it easier to open as well.
Feb 25, 2013 | Frigidaire 5 cu. ft. / 142 liter Chest...
I have a Sears Coldspot chest freezer Model #1869. The door doesn't seal properly and ice builds up within the door and the seal becomes even worse. The freezer itself works fine.
A precut seal will be expensive so please don't expect the price to be reasonable should you find one. Sears uses a longer number to list model numbers like 312.215478 as an example. Where can I find my model number? Let me know if you have questions, Thanks Sea Breeze
Nov 19, 2012 | Refrigerators
Freezer items have frost all over them.
A door gasket is the most likely cause with it letting in moist air from the house. The gasket should be snug on a dollar bill all the way around the door.
Sep 01, 2011 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Every time the top frig door is closed the bottom freezer door opens sometimes only 10 or 15mm so that the alarm does not detonate. The reverse also happens, ie top door opens when the bottom door is...
There is an air duct that connects the fridge to the freezer. When the opposite door is closed air is trapped and forced out the other door pushing it open.
The door seals contain a magnetic strip that hold the door to the fridge, these magnetic strips have lost their strength, to test this use a shhet of paper. Open the door, place the sheet of paper across where the door closes, shut the door, then slide the paper out. If the paper comes out without any resistance then the door seal needs to be replaced.
Mar 31, 2011 | Fisher and Paykel E522BRXFD Stainless...
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    We have an ancient Kenmore Chest freezer. I don't know what the orange, green & red lights mean. Also which is "ON" 0 or -
    the light tell you if the door is closed properly or not . Close the door tightly and check the lights. Then open it and check them again this will tell you the positiopn of the door for each colour
    Oct 06, 2010 | Kenmore Chest Freezer 16082
    Freezer is not defrosting
    1. Remove all of the food from inside the freezer and place it into the ice chest. Use more than one ice chest, if necessary. Cover the food with ice from a 10 lb. bag of ice. Alternatively, place all of the food from your freezer into the refrigerator compartment, packed tightly together.
    2. Place one or two 10 lb. bags of ice into one or two large bowls inside the refrigerator compartment to keep the food chilled. Keep the door to the refrigerator tightly closed and avoid opening it during the freezer defrosting process.
    3. Unplug the unit and leave the freezer door open.
    4. Let the freezer defrost overnight or for at least eight hours.
    5. Use the towels to wipe up the melted ice.
    6. Plug in a hair dryer and direct it to the interior of the freezer to melt any remaining ice from the walls and door. Be sure to direct it into the vents of the freezer, too.
    7. Wipe up any water from ice melted with the hair dryer from inside and around the freezer.
    8. Plug the freezer back into the outlet, and return food still solidly frozen to the freezer compartment from the ice chest or refrigerator. Use any thawed foods within a day or two or discard.
    May 25, 2010 | Maytag 21.0 Cu. Ft. Top-Mount Refrigerator...
    My chest freezer shut off (the outside light was
    Try to plug somthing that you know it works ,in that outlet ,and if it doesn't work or goes on and off , the problem is in the outlet, but if works without trouble ,the problem could be in the freezer plug , the cord or the cord conections to the freezer.
    Sep 13, 2009 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
    I've just got a daewoo fridge freezer the american style and i cant seem to open the doors is there any chance you could tell me if there is a lock on the doors
    just keep tugging on the doors, if warm air gets inside the doors the seals stick shut. this happened to ours and it also happens to the chest freezer in the kitchen i work in lol
    Jun 17, 2008 | Daewoo Refrigerators
    Refrigerators Logo
    213 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
