My washer keeps kicking out the electrical outlet everytime it goes beyond the filling stage. I hit reset and it only goes for a second. Help!!!!!
  • 481 Answers
Try using a different outlet in your house, with a decent quality extension cord. it might be a problem with the outlet or circuit breaker reset switch.
if it still does it on another outlet in the house then it might be a bad motor.
Posted on Jun 28, 2008
I have just purchased Jura machine and set up. I pressed rotary switch and it says on display machine filling. then it stops like its meant to and says press rotary switch. I press it and instaed of r
Hi Jon, I'm Joel, Is this machine you have for a restaurant or private use. a friend bought a machine like this at Bed Bath & Beyond and his machine had a problem with the rinsing cycle and beyond, this machine has a motherboard inside just like a computer and it should have a reset button underneath it or in the back or it's possible that the motherboard is bad. To recycle the motherboard hit the reset button and wait till the machine to finish rebooting and pull the plug and wait about 5 minutes, if this doesn't work then you need to take back to the store for a replacement or refund, If you ask me I would rather have a refund because this particular machine always goes into a malfunction mode. This is one of the newer model so unfortunately the company didn't have time to get all the kinks out. Hope this helps....Joel
Oct 25, 2014 | Jura Impressa J9 Automatic Coffee Center
Motor won't start
Make sure water is on. Try pushing test and then reset on the built in GFCI on the plug. If it's not a dead motor, when you hit reset, the motor should kick on for a second when you reset it.
Dec 31, 2017 | All-Power America All Power America...
I have a 5 ton ac with two 10 kw heat strips. The problem is that the unit runs constantly on one stage with the temp. set at 66 degrees in the winter. The second stage heat will kick on if I manually...
Between two stages, the difference temp has been set up to call for second stage.. If you need immediate heat what you did is right. But again you have to reduce to your required temp. Hence, wait the second stage get started.
Jan 13, 2011 | Heating & Cooling
Washer keeps filling with water then overflows
you need to check the pressure switch and the hose that goes to it to make sure there are no holes in the hose.some of these switches can be reset.you should replace it if you can not reset it
Sep 01, 2010 | General Electric WHDRE526EWW Top Load...
My Neptune Top Load fills the water, the motor doesn't start.
If i understand correctly you are stating the breaker shut down which means the house breaker for the outlet power kicked out. You might try plugging something else into the outlet to see if it also kicks out, say a vacuum cleaner of a drill.
You need a amp clamp to test for something shorted or grounded (or ohm out windings) which requires trained service........you do not want to get a shock
Jan 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
Is the Bryant 661CJ030-A heat pump single- or multi-stage?
Single stage heat pump. But you must have a two stage tstat for backup electric heat. You single stage cool two stage heat. The second stage brings on the electric heat in case the heat pump can not keep up. Wiring goes r y w1 on most heat pump tstats are switchover valve or o terminal. W2 second stage heat or emergency heat. g is fan c is common terminal.Rus
Nov 11, 2009 | Bryant 463AAC008BA Air Conditioner
NEC NFL-1065 washing machine won't drain or spin
I had the same problem , I replaced the pump havent had the problem again. Then the heater element blew, (kept triping the house fuse) replaced that, then the door would'nt lock everytime, now it will fill up then give a code "E8" I think it's the mother board
Oct 25, 2008 | Washing Machines
Frigidaire washer won't spin, belt seems to be ok. What else can I look for ?, Thank you. e-mail , OSUOWNSFOOTBALL@YAHOO.COM
Check your outlet filters, clean out. The machine will not spin if the filter is blocked. Also check your inlet into the machine. Clean screens on both ends of the pipes. Refit carefully. If you have manual, check for filter cleaning.
Dec 02, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
