Question about Epson Stylus Photo R320 InkJet Printer
Epson stylus photo r320 ink pad relacement
I got an end of service life error message regarding Ink pad needing to be replaced. I hate to have to replace this printer already?
Thanks Scott
  • 7 more comments
  • Geifer Apr 15, 2009
    I need photos, I want to try this.
  • Jollibee Lanzaderas Virtudazo
    can i see a photo??
  • Peter Sep 22, 2013
    Please show me the photo and the procedure to fix it. you would be honored if you can send them to my email id which is pldum73@yahoo.com
  • Anonymous Mar 16, 2014
    epson ink pad end service life l110
  • Anonymous Mar 17, 2014
    how troubleshooting epson l110 when the product's ink pad are nearing or at the end of their service life?
  • Anonymous Mar 18, 2014
    The printer's ink pads are at the end of their service life
  • Anonymous Mar 23, 2014
    what can i do for this
    what is solution
  • Anonymous Mar 25, 2014
    override error message to use printer
    New Friend:
  • 6 Answers
Here's 3 things you can do to get around this...depending if your printer is new and still under warranty or not (do NOT void your warranty!).
I have used all 3, but the third one was a lifesaver (AND money-saver!). About once a year I have to reset the printer using #2, but other than that....#3 is the greatest!!!
1. Try resetting it by, unplugging the power cord then while holding down the POWER STOP and MAINTENANCE buttons simultaneously while replugging the power cord caused a reset to zero on the counter. You will still have to replace the pads or redirect the waste ink tube to a receptacle on the outside of the printer, hope this helps?
2. If you go to inkjetprinterhelp.us there you will find the ssc service utility. Once you open the page click on the service utility and then choose the english version unless you can spk russian.If you then scroll to the bottom of the page and install the prog. Once you have installed the prog you will get the ssc utility logo in your bottom tray. Right click the icon and then select reset protection counter from the protection counter drop down. Once you have done this restart your computer and this should reset the system.
3. INSTALL AN EXTERNAL WASTE TANK and forget all about those gunky ink pads forever!
On the left rear of these printers is a small trapdoor held by a single screw.
Remove it, look inside (down and to your left) and you'll see the waste ink tube.
The tube is free at one end, and with a suitably curved piece of wire you can hook it and wangle the end out through the opening (you may dislodge a small piece of plastic in the process -- just put it back where it was, it's only a vibration damper.) I found the tube to be rather short....so I added an extension since I do not have room directly behind my printer for a container. I used the tubing you use with oxygen tanks or fish tank bubblers. They also make a little plastic connector so you can join the two together.
At this point, you're almost there.
All you need now is a suitable container for the waste ink, and I drilled a small hole in the trapdoor cover so you can put it back on without pinching the tube (or you could just leave it off.)
The container is a small square one with a snap-on lid, approx. 60mm square and holding about 150ml -- they're sold in sets of three for a few cents and are for making ice-blocks etc. in your freezer. Any small container will work.
Make a hole in the lid (slightly larger than the tube to let air escape) insert the tube and forget about the internal pads forever.
I've had mine in place for almost 2 yrs now and it works like a charm. If you need photos, let me know and I have a couple I can send you.
Posted on Jul 01, 2008
  • EdAv Mar 06, 2016
    Midge Burton can you please send me some photos how to install am external waste tank for workforce 645. Thanks
    Novelist:
    Sniper:
  • 68 Answers
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Posted on Jul 15, 2008
Go to google and put in scc service utility once you have that then just reset your counters
Posted on May 02, 2009
Message "Service required. Parts inside your
You'll probably find that that the print head is worn out (according to Epson) and it needs to be replaced. It's cheaper to buy a new printer.
Mar 13, 2011 | Epson Stylus Photo RX700 All-In-One InkJet...
Service required printer parts are at end of life
your printer porous pad need to be replaced.. and the waste ink counter need to be reset...
May 20, 2010 | Epson Stylus Photo R320 InkJet Printer
Waste ink pads - need counter re-set
download "SSC Service utilities" software and try with this program
Dec 21, 2009 | Epson Stylus Photo R320 InkJet Printer
I have an epson stylus photo R200. It has stopped working and has alternate red flashing lights. Error message says serviceable parts are nearing end of life. How do I get it to carry on working?
I'm not sure about the servicable parts. You might want to contact Epson.
I have seen "parts are nearing the end of life" which applies to the ink pads that absorb excess ink. In that case, the printer needs to be replaced or serviced by Epson or an independent service provider. If you just get the ink pads serviced, it may still fail soon. Then you can run the resrt utility. For more information and the reset utility: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp?cookies=no&com.broadvision.session.new=Yes
I hope this helps.
Dec 15, 2009 | Epson Stylus Photo R200 InkJet Printer
Px 700 not old less than a year changed cartriges 5 times printer says ink pads at the end of their service life i wouldent think so need to print a map urgent
Need to reset waste ink counter and replacing waste ink pad. Try to find adjusment program at indoreset.blogspot.com, or contac me. If urgent, you can just extend outlite pipe from head cleaning mechanic to outside of printer.
Oct 18, 2009 | Epson Stylus Photo R320 InkJet Printer
I have Epson stylus photo R320 printer and it keeps on saying parts inside your printer are at the end of their life,?
You need to reset waste ink counter. Don't forget to replace or wash waste ink pad. Or just extend outlet pipe from head cleaning mechanics to outside bottle.Use SSC latest version or R320 adjusment program. Find at indoreset.blogspot.com. Or contact me if you don't find out there. It's free.
Aug 19, 2009 | Epson Stylus Photo R320 InkJet Printer
Parts inside your printer are at the end of their
On your machine it means that the ink absorbers are full. There are around 9 of them. You will need a shop to replace them and then reset the counters.
Aug 10, 2009 | Epson Stylus Photo R320 InkJet Printer
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
I have an Epson R320 Printer. error message;service required. printer parts are at end of service life see service manual for details. I can not find anything in the service manual about this. This printer...
This message indicates that your waste ink pads are full and require replacing. Replacement is costly, messy and requires the printer to be taken completely apart. Most often the counter has "jumped" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://www.ssclg.com/epsone.shtml
http://inkjetprinterhelp.us/epsonSSC.html
More information about this issue and the "official" Epson resetter is available from the Epson web site, please read this link:
Please take a moment to rate this solution. Thanks.
Apr 14, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R320 InkJet Printer Logo
2,018 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
