Question about Kenwood KDC-716S CD Player
Power I pulled my unit out of my car before I sold it and I made a nice box for it and I?d like to wire it up as a garage stereo. Is there anyone who can tell me how I might be able to do this?
    President:
  • 624 Answers
If you have a DC power supply that is rated at 5 to 10 amps you will have no problem. You just connect it like you would in a car, but instead of a battery, you have a power supply for the red, yellow and black wires. The red and yellow go to the positive terminal and the black to negative. Then you connect the speakers to the speakers wires making sure that 1 speaker goes to the "white" and the "white with black stripe" wires, and that another speaker to the "grey" and the "grey with black stripe" wires, those are the front speaker outputs of a Kenwood. The Green set and the violet set are the rear speaker wires which you can just not use if you don't have 4 speakers. Just make sure that each wire is insulated from anything so they don't short out the radio. Now find an old car antenna with the wire and jack still attached and plug it into the antenna jack.
The only problem is when you turn off the power supply, you lose the preset stations and the clock settings.
I hope this helps you, and if so a good rating would be appreciated. It is the only reward we get for offering this free help.
Thanks,
Dave
Posted on Jun 28, 2008
Location of radio fuse in fuse box for 64 falcon and voltage
Just check all fuses.
Also note that many stereos also have a fuse in the back of the unit or inline with the stereo's wiring on the back of the unit. So if you find no blown fuses in the fuse box, then pull out the stereo and check there.
Oct 31, 2012 | Cars & Trucks
Missing wire 4 from manual....whats the name of wire
just had the same problem-it does not come with the stereo or even the DTV1 box, it only comes with the NAV1 unit. Luckily I found a local stereo shop that sold me one out of ther NAV1 box since I only bought the DTV1 box with the stereo and I needed it. So hopefully you will have teh same luck , either that or you will have to buy it directly from Power Acoustik.
May 23, 2010 | Car Audio & Video
Hyundai stereo
Go to www.hmaservice.com and register( Vehicle by VIN). Afterward, you have access to shop manuals, service bulletins, wiring diagrams, etc. about your vehicle.
Sep 20, 2009 | 1999 Hyundai Accent
My garage door doesn't open
BE SURE THE EYES ARE AIMED PROPERLY.
IF THEY ARE POINTED AT EACH OTHER AND THE LIGHTS DON'T WORK YOU MAY HAVE PULLED A WIRE LOOSE - CHECK THE CONNECTIONS.
IF LIGHTS ARE ON AND IT STILL WON'T WORK, UNPLUG THE UNIT WAIT ABOUT 5 MIN. PLUG IT BACK IN & TRY AGAIN.
HOPE THIS HELPS
Jul 10, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
My unit does not turn on anymore
If no power at all then check the vehicle fuse box for a blown fuse. If all are well, there may be an inline fuse which would require pulling the stereo out and checking a fuse that is inserted in the wire just before the stereo. Another place may be a fuse that is plugged or screwed in to the actual stereo. Hope you find the problem. Good luck.
Apr 17, 2009 | Pioneer AVIC-D1 Car Video Player
JVC car stereo doesn't power up
Check the ground wire. It might have come loose. Ground wire is the only black wire in the harness.
Mar 12, 2009 | JVC Car Audio & Video
Stereo works on assessory switch but cuts off when start car
you will have to separate the red and yellow wires. they cannot run together. the red should be connected to the fuse box. there is a slot labeled batt on your fuse box under the dash. there is also an auxiliary wire in the stereo slot used by you factory set. use this for the yellow wire connection.
Feb 02, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Speaker issues
You have to run wires and antenna wire to trunk from head unit pull down the flap where the amp is and unplug the factory plug from the stereo think box is what i call it its the unit in front of the amp you will need to unplug the larger of the plugs it has like 10 wires in it and then unplug the antenna wire and you will connect it to the antenna wire you you ran back to the trunk do not splice any wires if you get a wiring kit for it it should have evrything you need
Oct 20, 2008 | 1995 Lincoln Continental
Fitting subwoofer to Fiat Punto
Yes, I can help you.
You and I will have no ideal if that subwof is good or not.
atdlee@netzero.com
Oct 24, 2007 | Car Audio & Video
Kenwood KDC-716S CD Player Logo
96 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
