Cannot dial specific FM radio station on Ccreative Zen 4 GB mp3 player and when I auto connect, I get 1 or 2 channels but not the ones i want
  • 8,596 Answers
It's not necessarily a defect in your specific player - double check the latest firmware on Creative's website to see if it fixes any known issues with the FM radio. If not, you can try exchanging it at the store, but you may have the exact same problem with the next player. Also, try tuning outside or in a different area, and see if you get better reception.
Posted on Jun 28, 2008
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
Tip
How to add an iPod Input into a Stock Radio?
<p>You can add an iPod to a stock radio in your car, even if the plant does not have an auxiliary input or iPod input using a specific number of iPod car accessories. One such accessory is a cassette adapter that plugs into your iPod as a headset, but ends on a cassette tape to your stock cassette radio. However, not all cars have cassette players, thus more accessible to the FM transmitter. <br /> <p><br /> <p>1. Connect your iPod to an FM transmitter, if you connect headphones to the iPod. <br /> <p><br /> <p>2. Connect the FM transmitter to your cigarette lighter to power and then to the transmitter. <br /> <p><br /> <p>3. Press up and down on the transmitter to the FM transmitter to change, you will pass the signal to your radio. Choose a station that is not a radio station on it so you do not interrupt the signal. <br /> <p><br /> <p>4. Set your stock radio to the channel you selected on your transmitter and then play the songs on your iPod. You will see the songs on your iPod through the radio station you selected. <br />
on Aug 09, 2011 | Apple iPod touch
How to play raido
hi,
u didn't mentioned the model number of ur Coy DVD, any way do the following
first of all connect the AM and FM antenna to ur dvd player. ( located in the back side)
take the remote and do the following
1 .press the AM/ FM button. make selection u need AM or FM ( if u want to turn channels on AM select AM and got next step, after that select FM and do the same for turning FM channels)
2. press the MO /ST button to select stereo.
3. press the AUTO button to auto tune channels available
4.what till all channels memorized
now ur radio is tuned. u can directly select the station using the numeric keys ( for eg:- to go to channel 2, u should press 0 and then 2, if u want o go to channel 14, press 1 and then 4.
u can also select channels by pressing the RADIO plus and minus button .
when u want to listen radio press AM/ FM button and select ur desired channel.
ok
Dec 17, 2010 | Coby 5.1 Channel DVD Player with Home...
The radio component will not work. All I hear is static on any station.
make sure you are on fm not am, and make sure you are in a place with good reception. maybe try new earphones or while you have the radio on try moving the earphones and the player around.
May 18, 2009 | Creative Labs ZEN V Plus MP3 Player
How to recover the FM stations
From the FM Radio option, there is a "scan for stations" option.
Jan 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
Sansa clip - not able to playlist listen on car radio w/ adapter
1) Go into the settings menu, go to FM settings, and make sure the FM Region is set for United States. If you are outside the US, change it to "World"
2) The radio might initially be set for Pause - to test this, turn to a specific radio station that you know you get, and press up on the clickwheel. The "block" icon underneath the radio station should now change to a play arrow, if indeed it was on pause.
Jan 02, 2009 | SanDisk Sansa Clip MP3 Player
My Zen mp3 player is stuck or frozen on "Shutting off" mode.
when off hold play down. then turn on(while holding play). then theres a recovery menu go to clean up.
Dec 28, 2008 | Creative Labs Zen Micro MP3 Player
Need the sansa c250 driver; won't charge from xp
this player really sucks ... and believe ... i love sandisk players... my solution for this was the following:
i ve got a wall charger (for itself it almost did nothing)
i put my player to dial and FM station (like i was listenning to a radio)
waited some seconds and connected my charger.
it appears that the player freezes but after 2 to 4 hours it get full charged.
before that i tried everything and nothig was solving the problem.
Mar 13, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
No radio in menu. only music. voice .settings .
The service may not be available in your area. Make sure the headphones are connected to the player when searching for radio stations: Here's pg 15 of the user manual:
FM Radio (if applicable)
The Sansa
player includes an integrated FM radio for listening to live broadcast FM
stations. Please note that the FM Radio function may not be available in your region.
Listening to FM Radio
To listen to live broadcast FM station, follow these steps:
1. Select FM Radio from the Main Menu.
2. A radio frequency menu will appear.
3. Press |<< or >>| to adjust and search for the desired frequency, or select
preset by pressing Select.
4. For fast search, press and hold the |<< or >>| buttons.
Feb 20, 2008 | SanDisk Sansa Clip MP3 Player
Presetting fm radio stations
make sure you have the latest firmware
http://us.creative.com/support/downloads/
Dec 31, 2007 | Creative Labs ZEN V Plus MP3 Player
 Grubhead
Grubhead
