I have a memory card that creased and it is not working
    Novelist:
  • 148 Answers
If I follow what you mean the card is bent or misshaped in some way,, If so it is toast.. Sorry I accidentally stick those in my pocket sometimes forgetting they are fragile. Take care...Mark
Posted on Jun 28, 2008
Repair dents in 2008 Escape XLS PAssenger side rear panel
The creased one has to be hammered out some and filled. The other can be popped out as long as it is not next to the crease. It may need filled some also.
Sep 03, 2016 | 2008 Ford Escape
We have an Ultima washing machine and creases the cloths very badly any suggestions please
The amount of creasing you will get is directly related to the speed you select for the final spin dry cycle and the spin after the first wash cycle which occurs prior to the rinse cycle. The higher the speed and the longer it goes for the more the clothes will crease.
Experiment with different spin speeds on your machine for clothing that is subject to the creasing problem. Also do not put too many items in the machine for a wash as many people do as this will contribute to creasing. Always under load your machine for every wash cycle.
Spin drying is a compromise between creasing and maximum water removal. If you want less creasing you will need to select a more gentle spin dry speed but you will also have the clothes coming out of the machine with a higher water content and they will take a bit longer to dry. The spin time on the program may also be shorter.
In my own machines I use a gentle wash and spin cycle for all clothing that I don't want heavily creased. Running it on a wash cycle with a high and longer spin speed when the machine is spinning the clothes after the initial wash, and then again after the final rinse, will thoroughly crease the clothes every time.
Also bear in mind that different fabrics that are suitable for machine washing will perform differently and some are just too subject to creasing even if you use the most gentle wash, rinse and spin cycle. Hence you can take 2 different 100% cotton fabrics out of a machine and hang them to dry and one will be almost crease free and the other will be thoroughly creased. With these fabrics that are just very subject to wash creasing, it is better to hand wash and rinse them. Then after rinsing drip dry them or put them in the machine and spin them for 1 -2 minutes maximum just to get some of the water out and hang dry them.
Dec 28, 2015 | Hotpoint Washing Machines
Old tapes recorded wont track speedup slow down
Hello; This can be a very complicated issue. The simplest, is a dirty control track head located on the output (or right side of the drum containing the video heads). It is just before the pinch roller. Clean well with isopropyl alcohol 91%. The second likely thing is a damaged tape, that has a creased bottom edge caused by a defective VCR that has excessive reel takeup torque that causes this tape to crease while playing it. Open the cassette door where the problem is and check the tape for a bottom crease. usually about a crease 1/32 of an inch or more from the bottom. Tapes that are creased cannot be saved. John
Dec 15, 2010 | Sylvania 6260VF VCR
The paper alwayes jamming
If paper is consistently jamming, there are two usual suspects: worn feed rollers or a physical obstruction. If the paper comes out with a crease or dog-eared corners, you most likely have some sort of debris blocking the paper path. However, if the paper doesn't have any creases or bends, then the feed rollers have most likely worn out or need to be cleaned. For obstructions, I would suggest manually feeding a thick piece of card stock through the machine in hopes of clearing out any debris or stuck paper bits.
-David.
Nov 02, 2010 | Office Equipment & Supplies
Canon ZR200 memory card say ''card error'' when inserted. Card is not locked. I have formatted it. Have used 3 different sizes of cards. Sometimes it will say ''card error'' then start working a couple of...
Sounds like the contacts for the cards are dirty. Turn off the camera and remove the batteries before doing the following.
Try taking a piece of card stock (or a manilla folder) and cut it to the size (width only) of your memory card. Fold it to make it thicker. Wet the creased end with rubbing alcohol. Now gently insert the creased end into the memory card slot and move it in and out to clean the contacts. Remove and blow out with a can of compressed air to dry. Let sit a few minutes and then your cards again. You might want to clean their contacts as well with a clean rubber type eraser by gently rubbing the contacts on the cards.
Feb 01, 2010 | Cameras
Crease reduction facility won't work
Crease reduction facility is just a slower spin cycle if you coose a delicate wash there will be no apparent difference
Mar 07, 2009 | Washing Machines
Paper Creasing
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 06, 2009 | Office Equipment & Supplies
Appears to be a roller crease on the paper
i want the installation cd fo my printer HP PSC 1410
Jan 01, 2008 | HP PSC 1410 All-In-One InkJet Printer
Stylus cx6600
sounds like a paper pick up or alignment issue, if your machine is under warranty claim it. If not these parts can be replaced but will cost you
Mar 14, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
