Question about Refrigerators
Amana refrigerator The freezer is cooling normally, but the fridge is not.  The fan will come on, but the air blowing out is not cold
  • Chuck Badeaux Mar 28, 2009
    I have replaced the defrost timer and thermostat and tested the element and it's good. The origionial problem was the fan wasn't getting a ground and I jumped a wire off the freezer door light and now it cools fine and goes on and off with the thermostat as it should but will not auto defrost. Never sends voltage to the heater element. Suggestions? They come out of the back wall(wiring to the element) and I really don't want to move the freeser out if I don't have to as the water input is a small copper tube and may break. Help please??
  • 481 Answers
It sounds like it is not defrosting. check in the back wall of the freezer to see if there is a buildup of snowy frost. if there is even the slightest amount then the refrigerator is not defrosting. possible causes: defrost timer heating element in freezer thermo switch in freezer
Posted on Jun 28, 2008
  • Mike Durland
    Mike Durland Jul 06, 2008
    • none of my free suggestions have helped you at all?
    •  if you fell  the issue with the machine is something else let me know, i will try to help you figure it out.
    Mike
My bottom freezer gets cold but the top part (fridge) does not. Why? I have an older first addition style
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
May 19, 2011 | Amana ABB1927DE Bottom Freezer...
Fan in freezer runs and is cold. No air is coming
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 17, 2010 | Amana ABB1927DE Bottom Freezer...
My Amana fridge #ARB2215CB seems to be cooling the
Your refrigerator probably has an issue with its "damper control assembly", which regulates cold air coming from the freezer compartment. Contact an appliance service company.
Apr 13, 2010 | Amana ARB2217C Bottom Freezer Refrigerator
Freezer is cold, refrigerator is warm. sounds
check the fan from the freezer side if its not running /possible frozen or jammed will cause the refridge side to be warm the fan blows the freezer air into the fridge side to cool their is also a damper or duct control which can build up if no blockage or debris test fan for power if power than test fan it self if not running than repair or replace as necessary
Apr 09, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
Freezer working but Fridge not cooling... Tried adjusting temp to max cool and nothing. Unblocked vents, still nothing... Pulled off back panel cover to vacuum and brush... still nothing... help??? In case...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Oct 26, 2009 | Amana ARB1917CSR Bottom Freezer...
Refridgerator not cooling, but freezer is freezing
Oct 21, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refridgerator side wont cool but freezer side does.
Sep 27, 2009 | Amana DRSE663B Side by Side Refrigerator
Hi, my amana freezes my food in the refrigerator....
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..It may be stuck open letting in too much cold air.
Aug 15, 2009 | Amana Refrigerators
Amana ARB2214CB refrigerator fan not working?
the fan is locted in the freezer and it blows up to the ref and it sounds like the fan quit working and needs replace to check it the be for sure take the back panel off and with the ref running test the leads to the motor and make sure you have 110 volts if you do it is a bad motor
Jul 07, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Refrigerators Logo
154 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
