Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Red and blue screen on Hitachi 50v500
I have a primarily red screen with some blue once in a while and a fuzzy look to the entire picture.  This happened overnight after 4 years of having the TV.  I called Hitachi and they mentioned a light engine, which I got and nothing new happened.  No fix and a stupid light engine!  :(
  • mchavez Aug 26, 2008
    Same problem, after havinh my Hitachi 50" hdtv, we have experienced a big blue screen that started on one corner of the TV and now is covering 1/2 of the Tv.
    I called Hitachi and told me hat they had that problem with a large porcentage of the TV and no solutions.
  • 11 Answers
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Posted on Aug 31, 2008
So is it not the bulb when you get a redish bluish screen
Posted on Nov 06, 2008
I saw a similar procedure but first you have to set the input for an unused one... maybe ANT2 or video2, video3, video4, or whatever is not currently hooked in to any working input sources, then pwer off and try the 12C menu procedure..
Posted on Nov 05, 2008
Not worth a monkeys ****!!! Idiot
Red tint to screen
If the model is a 50v500 the real question should be does the set have a red oval area in the middle of the screen (entire screen not red)---if the entire screen is red you have a chance---it has a red oval area and it needs a new optical light engine----you will have options also but limited if that is the case.
Aug 26, 2012 | Hitachi 50V500 50 in. HD-Ready LCD...
My 50v500 screen has a red screen when the tv is on but no signal. Also, the top of the screen has blue on it. Is this problem just as simple as replacing the lamp? Thank you. Richard Doyle
  1. Perform Memory Initialization. NOTE: You must write down some data values before performing initialize.
  2. Check this status of the picture. It will determine what part need replacement
Apr 29, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
It appears my hitachi 50v500 has lost its green? sharpness is still there but color has go amuck. what can it be?
Symptom: Picture is pink, not enough green, too red, redissh picture, shiny red picture, etc, permanent condition.
Cause: Please do Memory Initialization
Jan 05, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Same problem
The red death as its called.
Very common in the 50v500 and 50v700 series.
it is caused by a blocked filter deep inside the TV, nearly inaccessible.
The LCD panels overheat (red one or blue one) and the light engine needs to be replaced.
You are better off living with it unless you have a warranty.
Sorry it wasn't better news.
Jul 09, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
50v500
If you have the "red" blob in the center of the screen or you have "blue" blobs that show up in random areas of the picture then the only repair is to have a technician replace the optical light engine.
Dec 19, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi Model 50V500A RED BLOOM
Pls check this picture..
If you have same issue I would recommend pls change light engine.
Good Luck
Dals123
Oct 06, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50v500 blueing problem
I am not expert but before you go to a lot of trouble, read all of the post on the infamous "red cloud", "red blob" and "blue streaking". In evey case, it appeared that the light engine was the problem. We just had our light engine replaced and the TV looks perfect. We dealt only with Hitachis Customer Relations Department 800-654-7013. You will have to have a certified tech come out and diagnos the problem. Hitachi will then call and verify, with the dealer, that the problem is a defective light engine and will send out a brand new one.
We were told the part cost around $1500 (Hitachi covers that) however, they will ask you to pay for the install. Our install cost $400. Worth is to us as we paid $3600 for this set 3+ years ago and we have loved this TV. When you first call Hitchi, they will act like they've never heard of this problem but they will give you names of certified techs in your area. Once the tech confirms that it's the light engine, Hitachi will own up to the problem and send out the part.
You really should only deal with Customer Relations ( I listed their 800 number above as you will be chasing your tail so to speak with their regular customer service department. Good Luck!
Nov 24, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
TV Problem
It is a failure in the light engine itself. You will need to have it replaced. Here is a link to that rather costly part. http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/50V500/Hitachi+Ltd/Hitachi/UX22201D/New.aspx
Apr 05, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
270 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
