Question about Epson Stylus 880 InkJet Color Printer
Changing ink cartridge
Cartridge holder will not move to access ink cartridge using instructions on lid. it just plays peek a boo and then hides again
  • kwaggmire07 Jun 28, 2008
    solved my own prob w/different site . illustration on my printer lid instructs to push the "clean" button for 10 secs,when actually its the paper feed button.Friday afternoon at the illustration label factory i guess.
Thank you so much. After hours of holding the button down as instructed and almost mangling my hand to try and grab the cartridge, your solution worked great.
Thank you, thank you, thank you!
Posted on Oct 27, 2008
I cannot stop the ink cartridge holder to stop in the correct positioo to replace the cartridges on my epsom cx5500 printer
Hello jgw_cansdale,
Welcome to Fixya.com!
If the Ink light (fon3_66.gif) is flashing that means one or more of your ink cartridge is low on ink, and if it's steady it means one or more is out of ink. For Epson printers, there are lots of ways to identify whether your printer is out or low on ink. For today let's just stick with the printer itself.\
Remember: A flashing fon3_66.gif means LOW ON INK, and a steady fon3_66.gifmeans OUT OF INK.
1. Open the scanner bed by lifting it up just like opening a brief case. By doing this you should now be able to see the carrier area this is the area were the ink carrier or ink holder moves left and right,
2. Press the Ink button. Now remember flashing means LOW and steady means OUT of ink.
If the Ink light is flashing, and you pressed the Ink button the carrier or ink hold will move under a small arrow just right above the carrier to point to you which ink cartridge is low on ink. pressing it again will point to another if you have multiple cartridges that are running low, if not it moves directly to the ink cartridge replacement area were you can pop the carrier's lid open to access the inks.
If the Ink light is steady, and you pressed the Ink button the carrier or ink hold will move under a small arrow just right above the carrier to point to you which ink cartridge is out of ink. pressing it again will point to another if you have multiple cartridges that are out of ink, if not it moves directly to the ink cartridge replacement area were you can pop the carrier's lid open to access the inks.
Regards,
Deathschythe33
Aug 22, 2011 | Office Equipment & Supplies
I lost my installation cd for my x2470 printer. I do not have money,is there a way to install it witout a cd
    • Step 1 Open your web browser and go to Lexmark's "Drivers and Downloads" page (see Resources section below). Locate the search box labeled "Search by Model" and enter X2470. Press return. Select your operating system from the pop-up menu. Wait for the download page to load, then click the "Download Now" button. Save the installer file to an easily accessible location.
    • Step 2 Rotate the printer so that the rear section is in view. Connect the power cord to the power cord connector located on the right. Plug the remaining end of the power cord into an electrical wall socket. Connect one end of the USB cable into the USB port located on the left. Rotate the printer back into place.
  • Step 3 Turn on your printer. Extend the paper guides and insert paper into the tray. Readjust the paper guides so that they are flush with the paper.
  • Step 4 Lift the scanner unit and wait for the print cartridge holder to move into view. Push down on the light blue lever to raise the cartridge holder lid. Install the ink cartridge into the print cartridge holder. Close the cartridge holder lid and lower the scanner unit.
  • Step 5 Connect the remaining end of the USB cable into any available USB port on your computer. If any "Add New Hardware" screens appear on your computer, click "Cancel."
  • Step 6 Open the previously saved installer file and follow the onscreen instructions.
  • Step 7 Locate the button on your Lexmark X2470 that looks like an open scanner pointing to a computer monitor. Press and hold this button for three seconds. Follow the instructions that appear on your computer. Once this is complete, your printer is ready for use.
May 23, 2011 | Lexmark X2470 All-In-One InkJet Printer
I want instructions to change hp psc 1610 ink cart.
Turn the printer on.
Lift the lid that covers the print-head mechanism.
Wait 15 seconds.
The print-head will slide to an accessible position.
Press down on the ink-cartridge, to "unlock" it from its holder.
Gently slide it out.
Gently slide in the replacement ink-cartridge.
Press up-and-in on the ink-cartridge, to "lock" it into its holder.
Close the lid.
Print a test-page.
Feb 17, 2011 | HP PSC 1610 All-In-One InkJet Printer
I need to replace ink but the ink holder is all the way to the right and won't move
Are there any instructions on the inside of the lid?
Wait until the print-head slides to the position from where the ink-cartridges can be changed.
Oct 31, 2010 | Canon PIXMA MP190 All-In-One InkJet...
How to change ink cartridge ?
open the printer by lifting the lid, and the ink cartridges will auto move to where you can have access to them, ensure you have the power on, check in detail the present position, and replace the new inks colour by colour in the same position, close lid, power off the printer for 3minutes, power on again and follow the instructions on alignment, and cleaning of the new inks
Mar 31, 2010 | HP Officejet 4315 All-in-One Printer
I'm trying to change an ink cartridge. Cartridges
Usually the printer manual will have instructions on changing the cartridge. If you don't have a manual, there is a chance you can find one online by googling the make and model number. On some printers the cartridges center when you open a door to access them, or lift a lid or a scanner deck, or turn off or turn on the printer.
Oct 03, 2009 | Office Equipment & Supplies
Change ink cartridge on epson stylus SX200 -printing head moves from side to side but then parks to the R and I cannot get access to change the cartridges.........
The ink cartridges are all separate so you press the cancel button (with no jobs pending) to bring the cartridge holder in to the right place open the holder remove the cartridge and then replace it, let the printer purge the cartridge then your good to go
Mar 24, 2009 | Epson Stylus Photo R320 InkJet Printer
Can not get the ink tray to stay so i can change the ink tx 100
Press the Ink Button on the printer and lift the lid. The ink carriage should move to the pointer to indicate the first cartridge that has gone. Press the button again, and it should move again to the next cartridge. When it has gone through all the empty units, it will move to a clear part of the printer and stay there until you replace the cartridge(s). Press the button again and it should move back and charge the heads with ink.
Mar 05, 2009 | Epson Office Equipment & Supplies
I need to change the ink cartridges on epson stylus sx200 but i need help as instruction book doesntreally tellyou how-thanks
buy an ink cartridge made specifically for your printer. Turn on your printer and raise the lid or press the cartridge changing button. 3 Wait for the cartridge carrier to slide out. with an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal. Carefully remove the tape from the ink opening on the bottom of new cartridge. Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been. 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned. with an Epson printer close the cartridge holder lid and press the cleaning button to charge the cartridge. Close printer cover.
Dec 09, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus DX7400 - Ink cartriges
Lift the scanner up to expose the inside of the printer. Thers a button "stop" top left face of printer, press and release and the print cartridge holder will move, press again and it will stop at the colour that needs replacing, press again (total four times) to show if other cartridges are ok. Press again and the cartridge carrier will return to right of the machine. Lift the lid (grey colour) to show the cartridges, remove and replace the ones that have been shown to be empty. Close the lid, it should click. Close the scanner down again. Press "start" to recharge the cartridge. ANy other problems try the epson support site. Good luck.
Aug 31, 2008 | Epson Stylus C86 InkJet Printer
Epson Stylus 880 InkJet Color Printer Logo
79 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
