It is helpful to know brand and model regarding a query. The popcorn popper probably has a thermal switch to prevent overheating which may happen if the popper is over full. It is a cut off. And you generally have to wait about 15 minutes or a bit more for the unit to cool down so it works again.
no you shouldn't have to do that. you are correct about the heat. what happens is it doesnt get hot enough for the moisture in the seed to expand to pop it, but its hot enough to dry it out so it cant pop. so it burns instead and you end up with a bunch of old maids. the thermostat is the first place to check.
The thermostat built into the kettle stops the kettle from heating at a prescribed temperature. usually around 425 F. This is hot enough to smoke and cause instant burns, but is the required temp for popping popcorn.
I do not know of a "thermal fuse" built into popcorn machines. Mechanical thermo stats are not flawless. they can and do malfunction, either too cold or too hot. the model popper you have is not adjustable, or repairable.
If you are tripping a electrical circuit breaker that is a different problem not related to kettle heat. It is a symptom of an overloading problem of your outlet, or a ground fault in the popcorn popper.
Popcorn needs 400F to pop, if you machine is not hot enough it will not pop popcorn. You did not include very much information to help fix it, but if it is a home use popper, you cannot repair anything on them. A true commercial popper you can replace thermostats, and fix the problem.
That model has a thermostat (also called a high limit) that is set at 450F. it should produce a popping cycle of 3 mins, and yes will burn popcorn if you don't dump it fairly quickly. The speed it heats cannot be too fast, there is only so many watts in the heat element. it may go to hot, but never to fast. The best way to test temp is time the 2nd popping cycle with a stop watch. the second batch should be 3 mins +/- 30 seconds. if it is 4 mins it is too cold. a 2 min popping cycle is to hot. A popper that is too cold is also popping poor quality popcorn, higher amount of unpopped kernels, and small chewy popcorn. Measure carfully when doing time test popping. That model is 2oz oil, 6oz popcorn, and 1 tsp salt. Start timing when you put ingredients in, and stop when you dump it. The kettle must be hot, that is why you time the 2nd batch.
Turn on light and popcorn buttons, for 2 minutes to heat up the popper's kettle.
Then turn off the popcorn button, this stops the turning gears while loading oil and popping corn.
Warning the stainless steel kettle will be hot. Might want to wear an oven mitt. 1 tablespoon of oil (I use coconut oil) and 1/3 cup of popping corn. This makes est. 6 to 8 cups of popcorn.
NOW turn on the popcorn button so the gears start turning, this turns a wire on the bottom inside the kettle to keep the kernels from sticking or burning to the bottom.
If making multi batches, during the process it states in the manual to allow it to cool 5 to 10 minutes. I normally pop 3 to 4 batches and then let it cool down.
When finished popping, turn off both the light and popcorn buttons.
Is the heater heating? Please check it ... Plug it into the outlet ... and put your hand GENTLY on the burner to see if it heats up. Of course, if it gets hot ... remove your hand.
I suspect the heater is not functioning 'pop'erly ...
