Question about Dell Inspiron 1501 Notebook
Monitor/screen My screen has a wide white triangle, with colored lines to the right of it. I can only see a small portion of my screen
    Novelist:
  • 148 Answers
Ketaluv I'm sorry to say that your screen has been damaged somehow and needs to be sent to dell they have the best in customer service. I know i've worked with them Take care .. be mucho blessed... Mark
Posted on Jun 28, 2008
Vertical Lines Dell Ultrasharp 2001fp
Sorry to say that it is a permanent damage of your monitor screen. Usually you can do nothing. But if you want to change the monitor screen, you have to visit a monitor & television specialist.
Cost will be 1/4 of a new monitor.
Sep 22, 2017 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Vertical strip of flashing horizontal lines on Acer Aspire 7551G screen
More than likely it's the lcd screen and will have to be replaced. I could be the video card, but most likely the lcd screen especially when you can put pressure on the screen and cause changes. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok, then the problem is with your lcd screen and the video card is ok. If the Borrowed monitor displays the same as your lcd screen then the problem is with your video card inside the computer.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Once you narrow it down to the lcd screen as being the problem you might try taking the lcd screen apart to reseat the lcd cable on the back at the top of the lcd. Just unplug it and plug it back into the connector. You can also try doing the same where the lcd cable plugs into the motherboard. Just pull it out and put it back.
May 31, 2012 | Computers & Internet
Samsung SyncMaster 193P, screen completely dead. Small blue power light comes on.
Same problem with my samsung 193p.only i got no picture in a background even when i was using flash lite. These procedure helped me.
Quote:
"I just finished fixing my Samsung 193p LCD with similar problem. The problem was a black/blank screen as if it was off. But if you are going to use a bright flash light there was data in it. So I suspect it was the inverter.
Procedures made.
1. Disconnect the power adapter and the D-sub cable.
2. Remove the small philip screws at the back of the LCD and remove the cover.
3. Remove 4 philip screws.
4. Disconnect the 2 data cables.
5. Openning the white cover is tricky. Use a flat screw driver and press it at the bottom middle part and use a credit card and pry from the middle part going to left or right side.
6. Remove the philip screws (black) around the LCD.
7. Remove the 4 philip screws and 4 at the middle part.
8. Be careful removing the switch cable. It is very fragile one of the 4 wires might come out (I did but fix it).
9. The Inverter board is at the left side. Take and remove the 4 inverter cables and the white wide cable.
10. This is another tricky part. Near the white cable there is a FUSE (brown in color). Check if it is open. If yes, You can use 2 think wires and solder on both ends. (Be careful the size of the fuse is soooo small like a half grain of rice). Or if you have a car fuse you can also use it.
11. Resolder the 6 terminals of the each transformer. There are 2 transformer so 12 terminals in all.
12. Assemble the parts back and you are done.
Good Luck. Happy fixing.
Roan
Triangle Tech Whiz"
Here is link to see broken fuse f201
http://photobucket.com/images/Inverter+fuse+F201?_escaped_fragment_=
May 19, 2011 | Samsung SyncMaster 193P 19" LCD Monitor
White line about an inch wide down the middle of the screen. Otherwise picture is clear and sound is good
White line you see running through your LCD monitor is a line of dead pixels. To fix this problem, you will have to get your monitor serviced or, if the monitor is new, replaced.
Jun 12, 2010 | Televison & Video
Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Mar 14, 2010 | Vizio VW42LF 42 in. LCD HDTV
Band of virtually solid white lines (ca 7cm wide)
check on bios if still there then monitor needs repair.
Sep 15, 2009 | Dell E176FP 17" LCD Monitor
Toshiba Satellite P105-S6124 Screen lines
Are these lines on the screen during the whole boot process? If so then the screen cpu and/or the video cpu has gone bad. Connect an external monitor. If the picture is clear, no lines, then the problem is the LCD screen. If the lines appear on the external monitor during the boot process then the mother board will need replacement.
Good Luck
Mar 22, 2009 | Toshiba Satellite P105-S6124 Notebook
Screen Problem
Unfortunately the fix is a new lcd. The tab welds at the top of the lcd are not allowing that portion to work correctly. As these tabs are fused to the lcd you will need to replace the lcd. My Toshiba M105 is almost the same.(I Have 4" Gone) on the right side. so to use it I clicked and dragged my system tray from the bottom to the side. And shrunk my web pages to utilize tthe good portion.
I suppose I should replace it but being only 18months old the LCD's run about 160.00 USD.(sometimes I just hook up an external monitor.
Apr 16, 2008 | Toshiba Satellite P105-S6207 Laptop
Dell Inspiron 1501 Notebook Logo
53 people viewed this question
Alun Cox
