Question about Linksys Wireless-G WRT54G Router
My router stopped working - Linksys Wireless-G WRT54G Router
    President:
  • 357 Answers
Try to create a new connection.
Chapter 1: Connecting the Wireless-G Broadband Router
Hardware Installation
1. Locate an optimum location for the Broadband Router. The best place for the Broadband Router is usually at
the center of your wireless network, with line of sight to all of your mobile stations.
2. Fix the direction of the antenna. Try to place it in a position that will best cover your wireless network.
Normally, the higher you place the antenna, the better the performance will be. The antenna's position
enhances the receiving sensitivity.
3. Connect a standard Ethernet network cable to the Broadband Router’s Internet port. Then, connect the other
end of the Ethernet cable to your Cable or DSL Broadband modem.
4. Connect your network PCs or Ethernet devices to one of the Broadband Router’s numbered ports with a
standard Ethernet network cable.
5. Connect the AC Power Adapter to the Broadband Router's Power Socket and the other end into an electrical
outlet. Only use the power adapter supplied with the Broadband Router. Use of a different adapter may result
in product damage.
Chapter 2: Configuring the PCs
Overview
The instructions in this chapter will help you configure each of your computers to be able to communicate with
the Router.
To do this, you need to configure your PC’s network settings to obtain an IP (or TCP/IP) address automatically, so
your PC can function as a DHCP client. Computers use IP addresses to communicate with the Router and each
other across a network, such as the Internet.
First, find out which Windows operating system your computer is running. You can find out by clicking the Start
button. Read the side panel of the Start menu to find out which operating system your PC is running.
You may need to do this for each computer you are connecting to the Router.
The next few pages tell you, step by step, how to configure your network settings based on the type of Windows
operating system you are using. Make sure that an Ethernet or wireless adapter (also known as a network
adapter) has been successfully installed in each PC you will configure.
Configuring Windows 98 and Millennium PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network icon.
2. On the Configuration tab, select the TCP/IP line for the applicmy router stopped working - 9641e30.jpget adapter.9641e30.jpg
Do not choose a TCP/IP entry whose name mentions DUN, PPPoE, VPN, or AOL. If the word TCP/IP appears by
itself, select that line. Click the Properties button.
3. Click the IP Addremy router stopped working - a443500.jpgect Obtain an IP address automatically.a443500.jpg
4. Now click the Gateway tab, and verify that the Installed Gateway field is blank. Click the OK button.
5. Click the OK button again. Windows may ask you for the original Windows installation disk or additional files.
Check for the files at c:\windows\options\cabs, or insert your Windows CD-ROM into your CD-ROM drive and
check the correct file location, e.g., D:\win98, D:\win9x, etc. (if “D” is the letter of your CD-ROM drive).
6. Windows may ask you to restart your PC. Click the Yes button. If Windows does not ask you to restart, restart
your computer anyway.
Configuring Windows 2000 PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network and Dialup
Connections icon.
2. Select the Local Area Connection icon for the applicable Ethernet adapter (usually it is the first Local Area
Connectionmy router stopped working - ea4fa3a.jpgouble-click the Local Area Connection. Click the Properties button.ea4fa3a.jpg
3. Make sure the box next to Internetmy router stopped working - 6cbaf1a.jpgTCP/IP) is checked. Highlight Internet Protocol (TCP/IP), and click
4. Select Obtain an IP addmy router stopped working - 9297bc0.jpgtically. Once the new window appears, click the OK button. Click the
5. Restart your computer.
Configuring Windows XP PCs
The following instructions assume you are running Windows XP with the default interface. If you are using the
Classic interface (where the icons and menus look like previous Windows versions), please follow the
instructions for Windows 2000.
1. Click the Start button and then the Control Panel icon. Click the Network and Internet Connections icon.
Then click the Network Connections icon.
2. Select the Local Area Connection icon formy router stopped working - f2e300e.jpgable Ethernet adapter (usually it is the first Local Area
Connection listed). Double-click the Local Area Connection. Click the Properties button.
3. Make sure the box next to Internet Protocol (TCP/IP) is checkedmy router stopped working - 076b379.jpg Internet Protocol (TCP/IP), and
button. Click the OK button again to complete the PC configuration.
If you would like more information on setting up your connection, please ask me a question.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 28, 2008
Dlink router stopped working
I think you should try to reset and reconfigure it manually.
Connect the modem and computer to the router.
Reset the router.
OPen the setup page.
Change the settings.
See How to setup router
Mar 05, 2012 | D-Link D Link Dir 601 Wireless N Home...
Stopped working on my computer
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jul 19, 2010 | Linksys Wireless-G WRT54G Router
My computers stopped detecting the wireless network. The wireless router used to work fine with all my computers, but today it stopped. I am unable to connect online via wireless, but if i plug cables...
Power cycle all devices. that should do the trick. You may also want to get to the User Interface of the router to check if the router radio has been turned off by accident or the wireless detection has been stopped by accident.
Jul 07, 2010 | D-Link Xtreme N DIR-655 Wireless Router
The lights went out and the router stopped working
not usually... try a reset, little hole in rear and press the little button there. That may work...
Mar 02, 2010 | 2wire HomePortal 1000 Router
Router stopped working, isp had me bypass router and net worked
If your computer is able to go online through the
modem, that means the modem is working fine.
You will need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for more information about the routers
and network
Feb 27, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
D-link has stopped working with comcast internet.
Are you trying to install the router.You can do it manually
without the CD.
MAke sure that your computer is able to go
online through the modem.
through the modem
Then you need to connect the computer to the
router ad the modem to the router.
router and change the settings of the router according to the
ISP.
Click Here for step by step by instructions
Jan 16, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
My wireless router works then stops working how can i fix this
It works and then stops. I think you will need to upgrade the firmware of the router.
Download the firmware of the router from the manufacturer's web site.
Open the router set up and upgrade the firmware of the router.
Once you upgrade the firmware then reset the router for 30 seconds. unplug the power and plug it back in.
Reconfigure the router.
Click Here for more info on how to upgrade the router firmware.
Dec 05, 2009 | Gateway Wireless-B Router (wbr-100)
Microsoft mn500 router: the wireless part stopped working.
  • reset the wireless settings on the router page, call your router tech support to access the router configuration page
Aug 11, 2009 | Microsoft Broadband Networking MN-500...
Actiontec GT704-WG wireless connection not working
you say it suddenly stopped working, if you can connect to the router via ethernet cable then try to access the router's web utility page and make sure your router is in mixed or G-only. If you can't still connect to the router through wireless then try restarting the Wireless Zero Configuration from windows. This is how it's made: Go to control panel and double-click "administrative tools", then double-click "services". You will see a list, scroll down to Wireless Zero Configuration and click "stop", you'll see a progress bar. After that click "start", you'll see another progress bar. Now try connecting to your router via wireless connection. If you still can't connect then repair the connection by right-clicking the wireless icon at the bottom right corner. Keep repairing until you connect.
Hope this works!
Feb 16, 2008 | Actiontec GT704WG Wireless Router...
Linksys Wireless-G WRT54G Router Logo
215 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
