WASHING MACHINE TAKES A LONG TIME TO DO A LOAD
  • wheelo1963 Jun 28, 2008
    Washing machine takes up 2 hours to do a load, I noticed not much water getting into machine. I have pulled the hoses off and cleaned the filters in both the hot and cold water fittings (cold was full of rust flakes). After connecting the hoses and starting the machine again still the same problem. I have pulled out the solanoids but have no idea how to test them to see if they are working correctly. Any ideas???????
  • 481 Answers
Check the water flow from the hoses. if that checks out thenyou may need to replace the water valve; it is inexpensive and it seems that you already know how to take it off and on.
Posted on Jun 28, 2008
Why does it take an hour and a half to wash one load of clothes.
ow long should a normal load of washing take? - Netmums
www.netmums.com > ... > Kitchen & Household
Netmums
Nov 25, 2008 - 15 posts - ‎12 authors
Ours is 47 mins on aquick wash, and one hour 10 for a normal wash. ... that's fine for every day stuff provided I don't fill it more than about half full. .... white shirts do not get clean at just 40 degrees and that takes 2hr 5 inutes xx ...
Why does washing machine take so long to wash
www.whitegoodshelp.co.uk > ... > Common Laundry Problems
Oct 29, 2013 - If most washing machines are taking too long to wash, one way of ... electricity than just washing the clothes with the heater off for hours. ... I would be able to handwash and spin a load in half the time the machine takes to do it ...
12 laundry mistakes you're probably making - CNN.com
www.cnn.com/2014/10/01/.../how-laundry-mistakes-real-simple/
CN
Jan 14, 2016 | Washing Machines
I used aml 85 ariston washing machine but it takes time to wash it takes 2 and a half hour to finished.how can i make quick washed for this.i want like 1 hour wash only
Select a quick wash cycle which will take in less time to load water , rinse and spin, Also choose with a smaller load. check the INLET water pressure to be good, check the drain to be effective, if not clean both the valves..
Jan 23, 2013 | Washing Machines
I just bought this washing machine a week ago,everything seems to be fine but it takes an hour to wash one load of clothes,can I adjust the time to half an hour(my old washing machine only takes 30...
The newer washers are much more gentle on your clothing, but they also take their time to do the job...
Yes, it can be a pain to have it take so long but your clothing will love you for it and will stay nice for you longer...you will also be using less water...
Not much you can do about it as the engineers that know all are the ones that program these things...
heatman101
Jan 21, 2011 | LG WM2010C Front Load Stacked Washer /...
Have kenmore heavy duty 80 series about 15 years old. It will not go into spinning mode after washing mode or rinse mode as it is supposed to.. By fooling with the controls I can eventually get it to...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 27, 2010 | Kenmore Washing Machines
Washing machine takes double the time it use to and some times doesnt drain
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Dec 27, 2009 | Maytag EPIC MFW9700S Front Load Washer
Water fills slowing in washing machine, kenmore ultra fabric care
Check the water inlet valve. If there is a problem it can cause a slow fill condition. Unplug the machine, turn off the water and remove the water supply hoses. Check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris. The solenoids can be tested using a multimeter or ohmmeter. A lack of continuity means a bad solenoid and the valve assy will need replaced. I will attach a photo for reference. Hope this helped and best wishes.
Oct 04, 2009 | Kenmore 24032\24036 Top Load Washer
How can I reduce the time needed for a wash ? It takes 2 hours is there any way to make it less ?
Most machines have a soil level selection (light / normal / heavy) and if you select light soil level the wash time is reduced. Also, some machines have a " Quick Cycle " which cuts a lot of time off, which should only be used with lightly soiled clothing. Additionally, make sure you have adequate water pressure, and that the inlet screens are clear so that the cycle is not delayed essesivly due to slow water fill. Regardless of all these, the higher spin speeds of a front loading machine (those have the longest wash times, due to the low water use and the tumbling wash action used vs an agitator in a top load machine) will result in reduced dryer run time, thus helping to reduce the overall time a load takes to wash and dry. (although still longer than most top loading sets) Generally, the energy savings and larger load sizes will outweigh the extra time the machines take.
Sep 16, 2009 | Washing Machines
1 1/2 PER LOAD
This is joyce
It is according to what cycle you have it set on and what kind of detergent you are using. if you use something other than HE detergent you may have a very long cycle, its trying to get all the suds out of your clothes, and yes the cycles do range that high.
Feb 11, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Washing Machines Logo
127 people viewed this question
Top Washing Machines Experts
