Intel 802.11a/b/g,b/g Mini-PCI Card driver installtion problem
Hi Sandrew,
While installing the the Wi-Fi driver. The installtion widow apperas for 3-4 seconds, blinks and then disappears.
I am not able to install the install the driver. looking forward or your help.
OS : XP
LP model : Toshiba Satellite M200
  • 37 Answers
Try updating driver from Device Manager
regards
raj
Posted on Jul 30, 2009
I have the ASUS T101 how do I get internet access without WIFI. Is there an internet card I can get?
Most desktop computers do not have Wi-Fi capabilities. If you wish to connect it to Wi-fi, you can use a USB Wi-fi LAN Card, which can be connected to any USB port of the PC and can be used to recieve wi-fi signals/ data. Note that PCI Wi-fi LAN Cards are also available, which are internal and added to PCI Port of the PC.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | ASUS Computers & Internet
Tip
Toshiba Bios Password Deletion Satellite P100 & Satellite Pro P100 With...
With notebook turned off;
  • Open Wi-Fi Cover
  • Remove Mini Card Wi-Fi card
  • Locate & Short Out JP8 for 5 Seconds
  • Remove short and turn on
  • NO BOOT
  • Press & Hold Power button to turn off
  • Turn on again & password is cleared
Satellite L10, L20, L30 & Satellite Pro L20
  • Open Wi-Fi Cover
  • Locate & Short Out JP1 for 15 Seconds
  • (Satellite L10)
  • Satellite L20/Pro L20 short out G1
Satellite M100 & Tecra A6
  • Open Memory Cover
  • Remove Memory
  • Remove Black plastic insulation
  • Locate & Short CMOS CLR1 for 15 Seconds
NOTE:
All the following models use the same password removal process.
Satellite: 17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70, A80, M40X, M50,M60, M70, M100
Tecra A3/S2, A5, A6
  • The jumper is always located under or near the memory modules
  • Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOS CLR1 (M100 & A6)
Satellite A100 & Tecra A7
  1. Remove Strip cover
  2. Remove 2 x K/B screws
  3. Move K/B Unit up but don’t disconnect
  4. Release & Remove Mini Card Wi-Fi Card
  5. Locate & short C88 Pin 1 & 2 together
  6. Power on Machine while still shorting Pin 1 & 2
  7. As soon as the TOSHIBA logo appears, remove short
  8. If machine boots, Password has been removed
  9. Satellite A100 (PSAA2A-02C01N)
    1. Remove Memory Cover from base of machine
    2. Release & remove right side Memory Module
    3. Lift black plastic insulation
    4. Locate & short PAD500 Pin 1 & 2 together
    5. Power on machine while still shorting Pin 1 & 2
    6. As soon as the TOSHIBA logo appears, remove short
    7. If machine boots, password has been removed
    TECRA A4 & Satellite M40
    1. Open modem & Wi-Fi card cover
    2. Remove mini PCI Wi-Fi card
    3. Lift up black plastic
    4. Locate & short C738 Pin 1 & 2 together
    TECRA S1
    1. Open palm rest cover
    4. Locate & short C5071 Pin 1 & 2 together
    TE 2300
    1. Remove 2 x B12 screws from bottom of system
    2. Remove strip cover
    3. Remove keyboard screws 1 x B2.5 & 1 x SF4
    4. Remove 1 x 4mm screw & Wi-Fi cover
    5. Remove mini PCI Wi-Fi card if fitted
    6. Locate & short points as shown in picture below
    7. Power on machine while still shorting points
    8. Short for 5 seconds
    9. Nothing will appear on the screen
    10. Turn system off holding down power button
    11. Password is now removed
    Satellite A60
    1. Open Wi-Fi slot cover
    2. Lift up black plastic
    3. Locate & short C561 Pin 1 & 2 together
    4. Power on machine while still shorting Pin 1 & 2
    5. As soon as the TOSHIBA logo appears, remove short
    6. If machine boots, password has been removed
    If you need your Toshiba bios password removed and your model is not listed above then chances are it's a procedure that can only be done at an authorised repair centre.
on Jun 08, 2010 | Computers & Internet
What is WLAN 1591 Half Mini-Card?
1pcs Intel 5100 "Half" Mini PCI-E Wireless Card
Standard / Public Version fit in any brand laptop
Intel Mini PCI-E Wireless Card 512AN / 5100
  • Manufacturer: Intel Corporation
  • Manufacturer Website Address: www.intel.com
  • Product Model: 512AN_HMW
  • Product Name: 512AN_HMW WiFi Link
  • Marketing Information: The Intel WiFi Link 5100 Series is a family of IEEE 802.11a/b/g/Draft-N wireless network adapters that operate in both the 2.4 GHz and 5.0 GHz spectra. These adapters, available in both PCIe Mini Card and Half Mini Card form factor deliver up to 300 Mbps of receive bandwidth; in addition to providing a host of features that enhance today's mobile lifestyle.
  • Product Type: Wi-Fi Adapter
  • Wi-Fi Standard: IEEE 802.11n (draft), IEEE 802.11a/b/g
  • ISM Band: Yes
  • UNII Band: Yes
  • Number of Antennas: 2
  • Antenna Type: Diversity Antenna
  • Wireless Transmission Speed: 300 Mbps
  • Host Interface: Mini PCI Express
  • Dimensions: 1.06" Height x 1.18" Width x 0.13" Thickness
Jun 26, 2011 | ASUS A7V333-X (A7V333-X/L) Motherboard
What year was toshiba satellite 2410-S203 pc notebook first launched?was it equiped by WIFI?
My sources indicate 2003.
It has > Optional
http://www.csd.toshiba.com/content/pr/html/Satellite%201410%20and%202410%20Press%20Release%20%289-24-02%29.html
The Wireless Antenna On-Off switch is on the Right side. The Wireless Antenna LED is to the left of the On-Off switch. It glows when the wireless antenna is in use.
It has to have an > optional
Turn the laptop over, Front facing you.
The Battery Compartment is on the Front Right corner.
The Wi-Fi Compartment Cover is on the Back Left corner.
Remove the single screw in the right middle of the cover. (Philips head)
See if a Wi-Fi PCI Mini Card is installed.
No?
You'll have to obtain a Wi-Fi PCI Mini Card for your Toshiba.
From a quick search just now, (Not advertising for this website),
http://www.impactcomputers.com/p000339520.html
(Remember to remove ALL power to the laptop Before installing. AC adapter {Charger} and Battery.
Also remember to observe Anti-Static Precautions before handling the Wi-Fi card, and when installing)
Here is the Toshiba Satellite 2410-S203 Notebook PC User Manual, also,
http://www.fixya.com/support/p265858-toshiba_satellite_2410_s203_pc_notebook/manual-14885
Nov 16, 2010 | Toshiba Satellite 2410-S203 Notebook
My friend has a dell latitude c400 which will connect to internet via earthnet, has a built in wireless but how do he turn this function on, what short key or anything else is it, pls helllpp
Go to Network conections and enable the wireless device. OR, you may need to open up the wi-fi door and check the model# on the wi-fi card, and type in the model# followed by 'drivers' in a Google search to acquie the drivers, too
Sep 24, 2009 | Dell Latitude C400 Notebook
How do i set up wireless internet on my hp pavillion a330n desktop? Do i need a wireless card or is it built in? and where do i put the wireless card if i need one?
Yes you need a wireless adapter.
Solution one : Get PCI wireless adapter which you will insert in an empty PCI slot inside your computer.
Solution 2. Buy a USB wireless adapter, which you plug in a USB port.
However, if my memory serves me right, that particular HP pavillion is 5 or 6 years old, and it does support USB 2.0, just USB 1.1
My advice to you is to buy a USB 2.0 PCI card to be installed in an empty PCI slot )or in the one occupied by the firewire )if not needed). This card will provide 4 or 5 USB 2.0 adapters. Then buy a USB wireless adapter, which you will be able to use with other computers.
Hope It helps.
Rate this solution if it helps you.
Aug 29, 2009 | HP Pavilion a330n (Refurbished)...
What mini pci WIFI card can I use in my Acer Aspire L310?
this laptop has 1 mini card slot for optional wireless LAN (selected models) just choose any decent aftermarket wireless g card and it will work , givin it's drivers are installed correctly and the laptop is set to autoconfigure the wi-fi. Most are set like this by default.
you also have a port for rj-45 , so having a 6ft network cable would be handy if you were sonewhere like a hotel which had free internet but no wireless.
Oct 24, 2008 | Acer Aspire L310 (ASL310UD631A) PC...
Computers & Internet Logo
166 people viewed this question
David Payne
David Payne
