Question about Philips 55PP9363 55" Rear Projection HDTV-Ready Television
PHILLIPS MAGNAVOX 60 BIG SCREEN 9P6040C101
CONVERGENCE BOARD MISSING, HAVE PICTURE BUT SWAYED AT TOP OF SCREEN, IMAGES ARE DOUBLED (SHADOWED EFFECT) TOLD I NEED NEW CONVERGENCE BOARD AND THEN CONVERGENCE HAS TO BE SET. I have a philips projection tv and it is bowed on the top and bottom of the screen. The colors also don't line up. I was told it was a convergence board or could be a "pin cushion problem" I would like to save a lil money and replace the boards myself, but am unsure of the exact problem
  • Anonymous Feb 19, 2009
    Was this problem fixed cause I have the same problem with my TV.
I have a philip magnavox 60" screen. My problems is when you turn the TV on there is a oral circle with a blue color on the left side of the oval and a red color on the right side of the oval circle. When the TV get warmed up it goes back to a full screen. Could someone tell me what is my problem and how can I fix it and where can I get parts to fix it. My model # is 9p6040c101. Thanks Robert
Posted on Nov 12, 2009
  • Philips Master
  • 8,617 Answers
Can you post a picture of your screen or send it to my email slinteriors@yahoo.com as it sounds like its just the convergence Ics and the 6.8 ohm resistors, but a pic would help me do a accurate diagfnosis.
Posted on Jun 29, 2008
Images on screen are doubled. Everything
u have bad convergence ic stk392-110 or stk392-150
Apr 13, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Concave looking screen and double lettering, color aweful
you need the following comvergence repair kit it comes with the replacement ICs and resistors plus step by step instructions on how to do the repair. Heres the kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Apr 20, 2009 | Philips Magnavox 9P6034C 60" Rear...
No picture
Replace BOTH of your STK ICs will have part number on them they are big black ICs.
Feb 18, 2009 | Philips 60PP9202 60" Rear Projection...
no this is what you need...
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
or send it in for repair here
Feb 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
60" Phillips Magnavox
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests. Best of luck, hope ya fix it.
Jan 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Problem with convergence
bad convergence ic's
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Try re-soldering the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests. Best of luck, hope ya fix it.
Jan 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
NEED USED SCREEN FOR PROJECTION TV
I have an 9P6040C101 that i am selling off parts.
I did sell the mesh screen, but i have the protection screen and everything else.
443-255-1892
Oct 19, 2007 | Philips Magnavox 9P6034C 60" Rear...
Convergence problems with model#9P6040C101!
They are large black colored IC's with the markings of STK392-xxx (xxx could be 110,120,150) There could be open resistors as well and you have to make sure if you do replace the IC's that you apply heat sink compond to the back of them otherwise they will prematurely fail.
May 03, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips 55PP9363 55" Rear Projection HDTV-Ready Television Logo
493 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
