Washer fills only with hot water
I have a Kenmore series 80 washing machine that is approximately 10-15 years old. When the temperature selector is set on cold/cold the washer will not fill. The machine will fill when the selector is set to any warm or hot combination only with hot water. Can you please help me.
  • anberman Jun 29, 2008
    I replaced the valve, cleaned out the lines and cleaned the screens but still have no cold water. Twice after turning the water on and off the cold water ran for about 3 seconds then shut off completely. What else could the problem be? Thanks in advance.
  • anberman Jun 30, 2008
    I am using a basic hose that connects directly to the valve on the wall and the other end to the machine. There are no shut-offs for the hoses.
  • 37 Answers
You need to check to be sure the cold water is turned on. Not trying to be smart but have seen the valve shut off before. if you have water to machone then the water fill valve is bad and needs to be replaced.
Posted on Apr 05, 2013
  • 413 Answers
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still slow, replace valve.
Regards,
reg501
Posted on Jun 28, 2008
  • Richard
    Richard Jun 29, 2008
    What type of fill hoses are you using? There are some hoses that have a special valve in them will shut of water if a specific water flow rate is sensed....to prevent flooding. I have seen issues with this type of fill hose.
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series will not fill up with water
if your washer will agitate when set to fill but not fill, then your pressure switch is bad.
also you may want to check and see if you are getting both hot and cold to your washer.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer
Your transmission is not engaging thats why the speed changes your making will sometimes get it to work.Honestly any machine after the 10 year age mark is not worth the cost of replacing the transmission.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Hot water wont shut off
solenoid valve is jammed open
replace
Mar 31, 2008 | Kenmore 24902 Top Load Washer
70 series wont fill w/water
CHECK SCREENS IN WATER VALVES FIRST. CHANGE TEMPERATURE SELECTOR TO COLD ONLY, SEE IF IT WILL FILL. IF IT DOES FILL AND SCREENS ARE CLEAN YOU MOST LIKELY NEED A WATER SELONOID.
FXIT
Jan 26, 2008 | Kenmore 22422 Top Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Washing Machines Logo
215 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
