LG CL washer
Just bought the washer and when it goes to agitiate it blows the breaker.
  • RSprague Jun 28, 2008
    Ok, the extension cord fix worked. How easy or difiicult is it to replace the wall socket to run the washer. The wall socket is about 7-8 ft from the wall circuit board.
  • 481 Answers
Try it on another circuit in the house with a decent extension chord. it may just be overloading your current circuit.  other than that it sounds like a bad motor.
Posted on Jun 28, 2008
  • Mike Durland
    Mike Durland Jun 29, 2008
    its not hard, but i would try to find a friend that has a little experience in electrical work to help you in person; if you have never done anything like that. there are some of variables that need to be seen first hand.
Lg wm2140cw washer error code cl My lg washer show cl and I couldn't use my washer
CL means that your washing machine’s CHILD LOCK is ON. You can find two buttons Temp and Options in the panel.
Turn ON the machine, press these two buttons together for 3 seconds and that’s it.
It might have a little kids face above a lock key, in between the wash and rinse buttons, hold these for 3/5 seconds and it should work.
Jul 29, 2016 | LG Washing Machines
I have a CL blinking in the display. How do I reset?
LG Washer Error Code Cl Fix - ApplianceRepairLesson.com
www.appliancerepairlesson.com/.../cl-error-on-lg-washer-repair-help-lg-t...
Jan 19, 2011 - CL means that your washing machine's CHILD LOCK is ON. You canfind ... CL popped up on my display had no idea what it was because the manual didn't say. ... I have the touch screen panel and it does not have temp or option buttons ... I've had tried to reset but won't do do I press temp and what else
How does Child Lock work on my washing machine?
www.samsung.com/au/support/skp/faq/868833
Samsung ElectronicsOct 23, 2015 - If the Child-Lock function is activated, the Child-Lock icon will blink. ...If 30 seconds have passed after opening the cover when the Child-Lock ... Step 5: To clear "CL" error on the display, close the door of the washer after ...
[PDF]Washing Machine - Home Depot
www.homedepot.com/.../d7064d64-8ea1-487d-9c35-a...
The Home DepotJan 3, 2015 - Warnings and Important Safety Instructions in this manual do not ... Donot wash or dry articles that have been previously cleaned in, washed in, soaked ......the Reset water level, "CL" is displayed on the LED display without.
Jan 19, 2016 | Washing Machines
Hi there, my LG wd-80481tp is displaying CL, none of the buttons are working and my manual is in greek, can you advise on the problem please? thanks
Hi
Thanks for using FixYa. CL means child lock, it might have got locked. Try pressing "dry" & "spin" together for 10 seconds or until the CL disappears. Also try pressing "end of cycle" for over 5 seconds. If this doesn't work then try pressing "options & select" till the light goes off. Also try and press ECO and rapid buttons together for more than 10 seconds. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 26, 2010 | LG WD-1280FHD Front Load Washer
LG washer has a fault code of CL and won't run
not aware of a CL code. may be a defective main board.
Apr 30, 2010 | LG WM2487H Front Load Washer
It showing cl on the screen
Hi
Thanks for using FixYa. CL means child lock, it might have got locked. Try pressing "dry" & "spin" together for a 10 seconds or until the CL disappears. Also try pressing "end of cycle" for over 5 seconds.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 12, 2009 | LG Washing Machines
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Jan 29, 2009 | LG WM-2277HW Front Load Washer
LG WM1285 WASHING MACHINE
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
Dec 17, 2017 | LG Washing Machines
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
