I have a Marshall G100RCD guitar amp which keeps blowing fuses. Inspection of the circuit board appears to show to points that are burnt
  • elcocoiee Apr 10, 2009
    hi, i have the same problem, but i think i can find out the bad components. i will find them and tell you later..
    it will be very helpful some information about schematic so i can deduce were is the problem.
    thanks.
    koko
    President:
  • 624 Answers
You have a shorted output channel. You probably see burnt resistors and very heat stressed areas of the board. That is a sign of the outputs being shorted. Unless you have experience in repaired amplifiers you will not be able to repair this yourself. If you change the burnt resistors, they will most likely burn up again. The output transistors for one of the channels are also shorted. They must be replaced along with every other bad component. If you miss just one of the bad components you will most likely burn up all the good parts you just put in. Resistors must be checked to make sure they are within the rated tolerance, capacitors must be checked for being shorted or being dry, diodes must be checked for being open or shorted, output transistors and driver transistors must be checked for being open or shorted, and the list goes on. It is a very difficult job for anybody not experienced in repairing electronics.
Take it to a reapir center that will work on those type of amplifiers, not all repair centers will.
I am very sorry to give you such bad news, but it is the problem you are having.
If you need any additonal help feel free to ask, if you decide you are going to try and fix it yourself I can tell you what to look for and how to check them, but without the proper equipment you will not be able to do this.
If you found this information helpful a rating of "FixYa" would be appreciated. The "FixYa" ratings is not just for helping you fix your equipment yourself, it is also for helping you decide if you can even fix it yourself or not.
Thanks, and I hope you find a good repair center.
Dave
Posted on Jun 28, 2008
Low volume on my marshall
I am very new here and don't know how to answer a question to a specific problem so I will write about the most common problems that I have had over the decades doing guitar amp repairs. If you find that your amp is extremely low in volume and then suddenly comes back to normal- check out the effects return [or power amp in] jack. Especially in Marshall amps-these corrode and your signal dies. If there is loud noise such as hissing and crackling with no guitar patch cord in the input jack- the input jack is likely at fault. They normally have switching contacts that ground part of the input circuit when the 1/4 inch male plug is disconnected. When this in is corroded or too weak to make normal contact, you can get these symptoms. If your amp is a solid state Marshall or Fender and there is a random buzzing sound with no guitar signal connected- hit the side of the amp and listen for the buzz to go away or become louder-if it does, this usually means that the connections are loose at the two large filter capacitors. In one or more Marshall amps, they use a filter circuit in the low voltage power supple for the preamp tubes. If you encounter a dead Marshall[the model escapes me now] remove the circuit board and resolder the four connections at the bottom of the bridge rectifier. If you have any other amplifier repair questions you can email me direct at computerlen@hotmail.com.
Nov 14, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
I got a Marshall MG100HFX Amplifier for guitar. The problem is that whenever i turn treble switch on it gives clean sound as it should, but in couple seconds it fades away. When I turn the switch again it...
I haven't played or worked on a MG100HFX but I understand amp circuits very well. The behavior you are describing sounds to me like a bad capacitor in the Treble circuit. This is a problem that would require the skills of an experienced amp tech. If you are within your warranty period you might want to return it. If not, a good local repair shop should be able to diagnose the problem.
Good luck and keep rockin'!
Mar 01, 2011 | Marshall Amplification Marshall MG100HFX...
Hi. I have a Marshal MG10CD amp. It was working fine, till a few days ago, when it suddenly stopped functioning. The amp gets power supply, as you can hear static when switched on, however, when the...
Check for a dry/cracked solder joint where the 1/4 inch phono input jack connects to the printed circuit board. Solid state Marshalls are renowned for this.
Feb 23, 2011 | Marshall MG10CD 10 Watt Combo Amplifier
I was given a Marshall MG Series 15 DXF guitar amp. The input jack has been twisted off and broken out of the circuit board. I would like a diagram of this part of the circuit. OR Is this soldered to...
Typically these input jacks have 3 or 4 "tails" that solder to the circuit board. The best thing is to get an exact matching jack. You can search for 1/4 inch jacks with matching profile at Digikey.com, Mouser.com, and try www.tubesandmore.com/
In the future ALWAYS loop the guitar cord through the handle so plug is not yanked sideways when people trip over the cord.
Dec 14, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall MG 250dfx head gone bad need help thanks
Ok guys, read your your posts and i have to say that ive experienced the same symptoms with my dfx250mg. I am a bit of an an adventurer, so i decided to take apart the head and diagnose the issue myself, this is what i came up with. The sections R107 and R96 of the large circuit board have overheated (likely linked to the faulty cooling fan of this particular model). Anyways, i reconnected them temporarily and the problem subsided. Now to resolder and test the results.
Feb 04, 2010 | Marshall Amplification Marshall MG250DFX...
Blows main fuse. Found burnt place on circuit board where connection 1 is. It's the board that's mounted to the heat sink with fan at the back. Disconnected connector 3 that goes to con 1. Now fuse does...
Chances are a power transistor has shorted. Sometimes input rectifier diodes short or electrolytic caps.
Here is a hint to troubleshoot this: Connect a 150 watt lamp in series with the hot side of the power line to the amp. This will limit the current (and voltage) and prevent the fuse from blowing. You can do a lot of troubleshooting at the much reduced voltage.
If board is burnt to carbon, this "cancer" needs to be cut out and removed as the blackened board is slightly conducive instead of an insulator. Often a circuit trace has fried the board. One must install jumpers around ones that have smoked.
Sep 24, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Is there a circuit breaker
There should be a fuse holder near the place in the back of the amp where the power cord plugs in. Also some Marshalls have fuses in fuse holders on the circuit board. Always replace with the same value and type as the original fuse. Never open up the amp when it is plugged in to the outlet. When replacing the internal fuses do not touch the capacitors as they retain a lethal charge. If the fuse continually blows it is an indication of a more serious problem which will require servicing by a qualified repair person.
Jun 25, 2009 | Marshall Amplification Marshall MG250DFX...
Marshall amplifier
old marshall eh ?? how old ? is it solid state or tube.
Jan 05, 2008 | Computers & Internet
634 people viewed this question
 Grubhead
Grubhead
