Question about Black & Decker String Trimmer Cordless 12" 18V
How do you change the string on a black and decker grass hog
  • Anonymous Jun 28, 2008
    how do you change the string on the trimmer?
  • Glenloy May 03, 2009
    Although a couple of years old, today was the first time that I have ever used used this product which has an automatic feed system. When it stopped trimming the grass, I investigated and discovered it had run out of cord! Here's the problem: I'm assuming it needs a new spool, but try as I may the old spool won't budge. Am I supposed to do something other than unscrewing it? Help!
  • 313 Answers
SOURCE: Black & Decker Grass Hog
possible broken plastic part of spindle assy.
Posted on Jun 19, 2008
  • 9 Answers
SOURCE: Black and Decker Grass Hog Model #GH1000
the drive cable probley kinked or bent and does not drive the head the cable goes from the motor to the head take the clamp bolt out and lift the head off the cutter check the cable
Posted on Jul 30, 2008
  • 133 Answers
SOURCE: STRING IS USED WITHIN MINUTES. IS THERE A TRICK
Probably wound backwards. Follow the arrow on the spool for both. Both SAME rotation.
Posted on Apr 21, 2010
  • 133 Answers
SOURCE: how to restring back and decker grass hog
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit. Replace empty spool with new full one or wind on aftermarket string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
SOURCE: string will not advance on black and decker grass
Is it best to buy a spool for Grass Hog, than trying to re-string myself? String seems to get stuck.
Posted on May 23, 2010
I need a new spring to replace the lost one that makes the spool advance. Its a Grass hog that is a few years old. Not battery powdered, but electric. Can yoy tell me where to buy one or what size...
They have upgraded the old string heads (type 1) to a new string head (type 2). They say type 1 is no longer available. Please see part numbers 20 & 21 in this 14" Grass Hog parts breakdown diagram. The new string head is relatively inexpensive. If you don't want to get one, could I suggest you take the old spring (if you have it) and match it up with possibly a new spring at the hardware store. Sometimes you get lucky! Here is the parts diagram for it. Hope this helps!
http://www.ereplacementparts.com/black-and-decker-gh1000-type-grass-hog-trimmeredger-parts-c-4167_9518_9532.html
Oct 30, 2010 | Black & Decker 14" Grass Hog Xp...
;How do you lengthen the string? (Have the grass
To lengthen the string:
- Turn the Grass Hog upside down
- Push in on the two release buttons on either side of the spool (they're orange)
- Pull the spool head off and spin it to release more string while you pull the string with your hand (make sure it is still fed out through the hole in the base)
- Pop the spool head back into place
Test the Grass Hog to make sure the string is not too long. If it is you'll hear it cracking against the plastic guard on the base.
May 02, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
How to restring back and decker grass hog
Apr 11, 2010 | Black & Decker 14" Grass Hog Xp...
String will not advance on black and decker grass hog electric trimmer
Did you re-string it? If you did it is possible that you crossed the string over itself and it is stuck. Check that and good luck...Lee
Oct 20, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
I don't undestand how to fix the line after it
The string is wound the wrong direction; it should be wound clockwise on the spool.
Jim
Jun 18, 2009 | Black & Decker Black and Decker & Grass...
Black & Decker String Trimmer Cordless 12" 18V Logo
241 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
