Question about Samsung DVD-R135
Parental control misfunction
Parental control is blocking a G movie
  • shnghid Sep 07, 2008
    i never engaged parental control. now my player is locked and i am unable to get access.
  • Anonymous Mar 14, 2014
    When I try to watch an r rated movie it tells me parental settings
Which up/down buttons are those?
Posted on Oct 12, 2008
I down loaded the instruction manual and there to pleasure was the solution. factory reset hold ^ up and v down buttons at same time for ???? seconds. for me it reset. good luck
Posted on Sep 07, 2008
How do I change Parental Control on ROKU?
Parental control is one of the features available on roku. This feature restricts the children to access the movies and TV shows based on the rating of the movies and TV shows.
Roku doesn't provide any true parent controls. But the parental control workaround is simpler one. Only a few channels on roku have the parent control. Such channels are Amazon Instant Video, Netflix, and Redbox.
Initially, you have setup your roku account and add the channels from the channel store by using the PIN.
    1.Sign in to your roku.com/link account.
    2.Click the update button which is next to the PIN reference.
    3.Then choose the choice "A PIN is required when using your Roku account to make the purchase or add any item from the Channel Store."
    4.Put the 4-digit PIN and save the changes. After that, you can watch the channel by installing them from the roku channel store.
    After finishing the watching the channels delete it.
    If you deleting the paid channels means there are no issues because you need not pay again for reinstall. For re-install it you have to sign in again.
    For some channels which have parental control, that doesn't require to delete the channel after watching.
    If you want more information about the roku call 1-844-965-4357 to get instant help.
Apr 07, 2014 | Computers & Internet
TV power button on my RCA True Flat 27" screen TV
RCA TVs come with a child lock capability called V-Chip. It's a parental control system which allows you to block programs and films by content, age-based ratings and the ratings which come with the movies. The parental control is a code, sent by the broadcaster to your television. The V-Chip will not work if the broadcaster doesn't send the control, or if the parental controls are switched off or unlocked. The controls are set up in the TV's main menu. The default is off.
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
Jun 17, 2013 | Televison & Video
Password forgotten control
If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. More than Nine and half Lakh viewers cannot be wrong.
May 18, 2013 | RCA E13320 13" TV
How to unlock childs security?
Instructions
Jun 28, 2012 | Sansui DTV3200 32" TV
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
Unable to get some NR movies to play even though I have unblocked NR material
The parental code is :
1,2,3,4
When the parental block comes up hit play, then type in the code and hit play again.  It should be all set.
Mar 28, 2008 | Disney Princess TV/DVD Combo
Parental Controls feature
Hey Aurora, After you put your password in, go back and change the password using blanks spaces. Then it should reset to 'parental control off'. Let me know if this works. Some Sanyo models are different to reset.
Jul 21, 2007 | Sanyo Vizon LCD-15A2 Television
Samsung DVD-R135 Logo
190 people viewed this question
Henry  Thomas
Henry Thomas
