Question about Star Logic 17" LCD Monitor
The cord is bad on my montior
M y cord has a short in it, I can move my cord a certain way and the monitor will come on,but then if i let the cord go the screen goes of, so i tried another cord and the monitor worked good,but its not the cord that i need so how do i get another cord? Thank you for your time and effort in this matter.
  • Anonymous Jul 11, 2008
    I need a new connector.
  • Star Logic Master
  • 5,568 Answers
After looking at several websites, I have to conclude that Star Logic is a marketing name, not a manufacturer.
Check the label on your units for an FCC ID number, go to this site:
http://www.fcc.gov/oet/fccid/help.html
Unfortunately, the pace of importation from the Orient is so frantic, many items (and makers) don't bother to seek FCC approval so you may not find a number.
If your monitor is listed, you may find who made or imported it so you have shot at getting what you need.
Posted on Aug 08, 2008
(montior)on light is blinking on and off NO picture
You can look at my pictures to see what is usually wrong with your DELL monitor:
http://s807.photobucket.com/home/budm/allalbums
Most of the time are due to bad caps, bad soldering works, shorted transisotrs, etc.
Replacement board: www.lcdrepair.us
May 19, 2010 | Dell E153FP 15" LCD Monitor
PL19Wb Monitor: montior is still showing power is on but screen go...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 16, 2010 | Proview PL19Wb Monitor
Had a power failure now montior only blinks can this be fixed
If you are going to DIY repair, please read below.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 18, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Speakers attachment
If it is powered speakers type (you can tell if it has ac adapter or power cord), then yoy will use that green ministereo audio input plug of the powered speakers and attache it to the PC green audio line out, you do not hook the speakers to the monitor. Please vrify what you have.
May 15, 2010 | Envision EN-7410 17" Flat Panel LCD...
Montior keeps flashing on and off for about 3 mins then ok but when montior goes to sleep when i move mouse it happens again
You can have failing power supply due to bad caps.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP and other monitors to get some ideas of what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further, it will also help out other people with the same problem.
Apr 05, 2010 | HP w1907 LCD Monitor
I have no picture on my flat screen montior im using a older montior and its works
If the monitor light comes on but you get an "out of range" message, you'll have to start the computer in "VGA mode". Probably your video card is set to a resolution that the monitor won't display.
Just a thought, as you didn't say anything but you don't have a picture.
If this doesn't work, check the power and cord and video cable before you declare it dead.
Nov 11, 2009 | Computers & Internet
Montiors shut off
if the monitor goes into standbye when you plug it into the computer , it generally means there is NO signal coming from your video adaptor.
Plug the old monitor in , if it works, ide suspect the new monitor(s) are not working correctly.
if it doesnt work , you need to restart the computer in safe mode by repettitively tapping the f8 button as the computer starts, before it says "starting windows".
If you have a signal on your monitor in safe mode, then most likely you have a bad or corrupted video driver and it will need to be updated.
if you have no video in safe mode , you will need to remove the cover and physiclly check that all add-in card power cables and memory chips are squarly seatied in there slots. MAKE SURE YOU UNPLUG THE COMPUTER AND DISCHARGE ANY STAIC BUILDUP IN YOURSELF BY GROUNDING (TOUCHING) SOMETHING METAL BEFORE YOU TOUCH ANYTHING INSIDE THE COMPUTER.
AFTER YOU CHECK THESE THINGS AND TRECONNECT THE POWER AND TRY TO START......POST AGAIN HERE
Feb 18, 2009 | Systemax Venture PC Desktop
Display does not show the color green. Green comes in as black
why not use a known good monitor
in 1 minute flat the truth.
not only that you can move or bad monitor to another pc
and see if it works.
also the cable can be bad.
Mar 13, 2017 | HP VF15 15 in.
I have a ViewSonic VE175 monitor, which has a damaged monitor cord; some of the pins have broken off. Is it possible to repair or is not cost effective and that I should go and purchase a new monitor. ...
This is a sad way for computer manufacturers to get you to buy another monitor when the cord is bad. Some monitors have detachable cords that you can purchase at many big box stores for a reasonable price.
The short answer is no - the average person cannot repair this themselves UNLESS you have a familiarization of electronics and know what to buy and repair on the back of the monitors.
This takes a lot of time out of your day to replace a monitor cord thats permanently fixed to the back of the montior.
My long term solution to you is go and purchase yourself a flat panel monitor which has dropped in price, and make sure you have a detachable cord on that model so you can easily replace it in the future should it becomed damaged.
Aug 17, 2008 | Computers & Internet
Monitor has no picture
Yes! :)
Your monitor is not the problem. Check all the connections from the back of the monitor, to the computer.
"No Signal Analog" means your monitor is working perfectly, however is not receiving signal from the computer.
Didnt find any loose cables?
Try unplugging everything. Leave it unplugged for at least 5 minutes. You need to give the system time to drain all the excess power.
Again your monitor is fine, blue light > No signal > orange light is totally normal for your montior.
Oct 12, 2007 | ViewSonic VX922 19" Monitor Flat Panel
Star Logic 17" LCD Monitor Logo
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
scj103
Jerry Umali
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
