Question about Dryers
Kenmore electric dryer when i turn it on all I hear is a humming noise
  • 481 Answers
 hold down the door switch with tape and try to start it while turning the drum inside. if the motor doesn't start then you might need a new motor; expensive.
if the humming noise is actually the motor running and the tub is not turning then it is the belt; inexpensive.
Posted on Jun 28, 2008
Kenmore dryer Tub will not turn freely. Feels as if it's hung up. When you you press the start button it will just make a humming noise.
A guess, sounds like you are hearing the motor running but no tub belt as it is probably broke. If you are asking then you probably don't know how to fix it so you should call a repairman. Or the tub guides are wore out either way a repairman can help.
Nov 22, 2011 | Kenmore Dryers
My kenmore dryer makes a humming noise when u turn it on n the drum will not spin
If you are hearing a humming noise and no spinning . You have a burnt motor..Do not attempt to switch it on till you fix it to prevent further damage
Mar 07, 2011 | Dryers
Kenmore 80 series dryer makes loud humming noise when it is drying clothes think it may be a belt that needs to be replaced
More likely is that your motor is going bad...that will make a very loud hum when it starts to go...
DryerRepair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 07, 2010 | Kenmore 65924 Electric Dryer
I have a Kenmore Dryer, model # 96585210 / 65852. I have it apart and have narrowed my problem to the actual motor. I get a humming noise, but the motor does not spin. After a few seconds, it stops...
You have verfied the motor is shorted out already, when you hear it just hum and smell like burning rubber/electric.
Yes replace the motor.
Oct 02, 2010 | Kenmore Dryers
Drum not turning, hear humming noise
the humming noise is from the motor,see if you can spin the drum by hand,if it moves you have a bad motor,if it's hard to turn you could have something stuck in the blower wheel or the belt is jammed somewhere,the blower wheel is behind the duct that the lint filter slides into
Mar 20, 2010 | Whirlpool LER4634J Electric Dryer
When I press the start button on my Kenmore Dryer Model #96291100 I hear the motor humming and the timer clicking but it's not turning on. The belt is good
you have a problem with a part called a capacitor,which holds an electric charge to start the motor when,when it's faulty,the motor cannot start,hence the humming noise.it must be replaced,only by a qualified repairman.
Oct 06, 2009 | Dryers
Hums when turned on-won't turn over
belt may have broke. if you are hearing a humming sound . thats the motor .whitch is good, sounds like the belt broke or slipped off.
Sep 12, 2009 | Kenmore 73952 Gas Dryer
When you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Feb 14, 2009 | Kenmore 659 Electric Dryer
Kenmore Dryer
the bearings in the motor are locked up. they are sealed so you have to replace the motor to fix it.
Nov 25, 2007 | Kenmore 62602 Electric Dryer
Dryers Logo
137 people viewed this question
Top Dryers Experts
