First look under when your license plate lights are and you will see 2 phllips headed screws remove those screws and the license plate light assembly will drop out of the bottom of the trunk, simply twist the blub to unlock it from the light housing pull the bulb straight out of the socket replace it with a new bulb and the installation is the reverse of the removal.
SOURCE: change oil light remains on
To reset the Change Oil Light:
Open driver's door and open fuse access panel
Turn ignition key to on (don't crank the starter)
Push reset button located in fuse panel
When Change Oil Light starts to flash
Press and hold reset button until it beeps and light goes off
Repace panel
SOURCE: rear license plate lights
do they have covers on them?
if yes they will clip off then 2 screws behind that for the plate
SOURCE: how do you change the license plate light bulb
OK>>> it is very cold here, but nonetheless..I went outside to check on my Oldsmobile for your benefit....On mine (I can't guarantee it is the same for all of the vehicles listed above). If you are looking at the license plate, LOOK UP and you should see the bulb and whatever encasing is there. Mine is in a tube and it is attached with (2) mini bolts that will need to come out first, then it just looks like a simple matter of disconnecting the electrical plug, taking out the old bulb and putting the new one in. I hope this helps someone....
SOURCE: how do I change the rear license plate light bulbs?
License Plate Lights
Removal & Installation
License plate lamp retainer clips
To Remove:
Remove or disconnect the following:
To Install:
