Question about Electrical Supplies
I have power in 14/2 and 14/2 out to light. how do I wire the switch. I tried putting whites together and blacks to switch but it doesn't work.
Your breaker is not tripped.
Your light bulb is working.
You have a working on-off switch that has two brass screws and a green ground screw.
That is a single pole switch. Black wires go on either brass-colored screw, and whites are twisted together.
If switch has 3 screws and ground screw, connect black wires to dark-screw and one of the brass screws.
First you should test your wires.
You have 2 cables.
Both cables have black, white, and bare copper ground wires.
One cable goes to light.
Other cable comes from breaker box.
Cable from breaker box has black-hot wire and white-neutral wire.
Turn on power and test black wire to white, and then test black wire to ground.
Tester should light up with both tests.
If tester does not light up, then breaker is suspect, or there is a short in nearby box.
Track back the short towards breaker, going one box at a time, each time testing black to white and black to ground.
Next, inside the switch box, remove the switch and connect both cables without the switch.
Black to black
White to white
Turn on power, does light turn on.
If light turns on, your switch is suspect. Connect new switch. One black wire to each brass screw, and then tie white wires togethr.
If light does not turn on, your light is suspect. Open light fixture and test black to white and black to ground again.
If light tests with power, then check your bulb
If light has no power, then wire between switch box and light is suspect.
Posted on Dec 07, 2010
SOURCE:
I'm looking for help. Installing a Woods 59007 timer. It has 4 wires, red, black, green, white. My current electrical setup is a black, white, and ground wire in the box. How do I hook this up? T
Hook all the white wires together.
Hook all the greens or bare copper wires together.
Hook your hot black to the timer black.
Hook your black wire that goes to your light to the red switch wire.
then try the switch if the light doesn't work switch the red and black switch wires around black to light red to black power.
Oct 19, 2014 | Woods In-Wall Digital 5-10-15-30-Minute...
Can I run 110 /14 2 from a light switch down to power a 110 plug receptacle
Hi Don,
Shut the power off.
Inspect the switch.
If the switch has two cables (2 black & 2 white wires) which would indicate that power enters the switch on one cable and supplies the light through the switch on the other cable, you can supply a new outlet so that it can be on all the time or controlled by the switch. Either way, you'll need to run a 14/2 cable from the new outlet to the existing switch box. Connect the bare ground wire to all the other bare ground wires by adding it to the bundle in a wirenut; and connect the white wire (neutral) to the other two whites under a wirenut.
Power back on.
Using a meter or tester; carefully determine which of the black wires on the switch is "on" all time and which is turned "on and off" by the switch. Indicate which is which on the wire with tape, or other marker.
Power off.
Remove the wire you want to supply the outlet.
Cut a short (8" or so) length of insulated (black, red or blue in color) #14 copper wire & strip 3/4" off each end. Combine one end of this short wire, the original switch wire, and the black from new 14/2 cable together under a wirenut..
Connect the other end of the short black wire to the switch and put everything back together again.
Power back on.
The outlet will either be on all the time - or turn on and off by the position of the switch. You're done!
I hope this helps - if it was not the answer you were expecting, please describe how you want the switch, light & new outlet to work in greater detail.
Apr 15, 2012 | Electrical Supplies
Replaced a light switch for a ceiling fan. Switch
On the switch ... one wire goes to thefan or the light and the other wire goes to the power.
All white wires normally go together.
Jun 05, 2010 | Hampton Bay 52 In.Carriage House II in...
Electrical hookup
Tie all the black wires together and connect to the black power wire coming from the switch. Tie all the white wires together and connect to the white wire coming from the switch. If this does not work then what you have is a switch leg going to the light. This will be just a white and black wire coming from the switch with another power wire going in. Look at the switch and see if you have a white and black wire connected to the 2 screws. if so this is a switch leg. You will have to disconnect all the black wires in the light mount and find which one is carrying power in. Let me know what you find and we will proceed.
May 23, 2010 | Home
Tried to install a ceiling fan to replace a chandelier. light on fan and fan itself works but only by the pull chains, it will not turn off or on by the wall switch that controlled the light. when i...
I can help with this but I need some more clarification. Does the switch on the wall not do anything at all, or does it turn them both off or on. The black wires are the power wires and the whites are your neutrals. You figure out what wires are coming from your switch. If there was a switch on the wall that controlled your chandelier before that there has to be a white and black wire that go to that switch. Look at the switch in the wall. If all you see in the switch box is a black and white wire then they did a switch loop, which means they started the power up in the fan box, sent it out to the switch through the white wire and brought it back to the fan through the black wire in which case the one white wire up in the fan box is a powered wire. If there are four wires in the switch box (2 black two white), then they brought the power into the switch box, tied the whites together as neutrals and connected the blacks to the switch. So then up at your fan the white is neutral and black is power. To wire a switch loop at your fan, find the power wire, connect it to the white wire that goes out to your switch and the black wire from your switch will get connected to your fan motor and fan light. If it was not a a switch loop connect fan to the black coming from the switch and all whites will get tied together. Good luck!!
Apr 16, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
My fan has three wires, black white and blue. It had no manual and I wonder how to wire it to the on/off switch.
Put the black and blue wire together with the black wire on ceiling. Put the White with the White wire on ceiling. Bare/green wires are ground put them together.
What fan wires do.
The black wire is to power the fan motor.
The blue wire is to power the light on fan.
The white wire is neutral.
If you wire this way you turn on the switch and use the pull chains to control the fan and light.
You can also buy a remote control unit at a home depot. And it will have instructions on how to hook to fan and ceiling.
Jan 02, 2010 | Hampton Bay 52 In.Carriage House II in...
Trying to hook up 2 lights to a light switch. Power is coming through one light then to wecond light and switch. How do I get the 1st light to work on the switch?
OK I asked for better info but, lets try this... If there is only one set of wires going to the switch, this is called a switch leg. Both wires,no matter what color they really are, are treated as black. so then in the first light box you connect one leg of the switch leg to the hot black incoming wire. the other leg connects to all other black wires in that box.Including the light. the white wires all hook together.( not the switch leg white, remember its really black)Including the light All Bare ground wires hook together. In the other box just match up colors and connect the wires together.Its as simple as that. Larry
Nov 14, 2009 | Electrical Supplies
Light will not shut off on fixture (replacement of ceiling fan)
One of the two cables in the ceiling box is power and the opther is a switch leg .. what you need to do is connect the two black wires together at the ceiling, connect the white power wire to the white fixture wire ,.,. connect the white switch wire to the black fixture wire .. put some black tape on that white to make it legal .
Sep 27, 2009 | Hampton Bay 52 In. Black Huntington III...
How can i wire a combination switch outlet
first try putting the red and black together and the whites together...turn on power, if the lamp lights all the time then keep reading, (if not you need find out which is hot and which is going to the lamp this can get complicated if the color code is not followed)
find out if the blk is hot all the time or if the red is hot you need a tester for this. its easier to make a double pig tail on the hot wire and put one of the pigtails on one side of the switch and the other on the BRASS screw on the recpt. now put the other wire (red or blk) on the other side of the switch no pig tail. then tie the whites together with a single pigtail and put the pig tail on the SILVER side of the recpt. make sure you tie in a ground as well or the GFI will not work. hope this helps
Aug 19, 2009 | Leviton 8299 Combination Switch / Smart...
Pull on/off switch
Put one wire from switch to black wiring coming in and the other to the black going to the ballast.
If you do not understand please post back
Dec 01, 2008 | Electric Door Light Switch
Electrical Supplies Logo
129 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
