Question about Apple iPod touch
ITUNES DOES NOT RECOGNIZE MY IPOD TOUCH
IT SAYS MY IPOd TOUCH NEEDS to be restored so i did that. I even tried installing itunes all over again but it still doesnt recognize it. MY nano works fine and i already restored 3x and it still doesnt work!!! i am desperate please help!!!!
  • creed161 Jul 06, 2008
    my ipod touch would not detect itunes. when i turn it on the screen tells me to connect to itunes and turns off if i'm not already connected to the computer.
  • nellyj Sep 28, 2008
    it says ipod is disabled connect to itunes and when i connect it to itunes it doesnt recognize it pls help i miss my music ive tried holding the home button when i plug it into the computer
  • 106 Answers
Put it in DFU mode while connected to the computer. to do this, hold the home and power buttons for 10 seconds and then let go of the power but keep on holding the home for 10 secs. the screen will be black and nothing will show up. go to itunes and click on your ipod on the left. then click restore. this should work.
Posted on Jul 02, 2009
5 Suggested Answers
SOURCE: My Computer and iTunes does not recognize my iPod
reformat and put a new songs and videos thats the fast way to do it
Posted on May 01, 2008
Download the Ipod Reset Utility from apple.com
Posted on Jun 16, 2008
ipodslinger
  • 688 Answers
put your ipod in disk mode by following these steps.
press and hold the Menu and Center buttons on the clickwheel. when you see the apple appear, switch your fingers to the center and play/pause buttons.
whena check mark appears plug it into you computer and it should detect and mount.
add music and have fun.
Posted on May 24, 2009
  • 43 Answers
SOURCE: My ipod touch 4th generation
"iPod is disabled - Connect to iTunes" . This is because someone(or something?) has tried to crack your password too many times, which causes Iphone/Ipod to automatically disable itself to protect your data.
To restore your iPod, you must connect your iPod to iTunes with your iPod connector table. Make sure it is on and has this message when you connect it to your computer. Once connected, iTunes should detect it as usual.
Once connected, make sure you have all the proper sync settings enabled - for example, applications, music, photos, etc. Change something so that the Sync button in the bottom right appears in the iTunes window. Then sync the data.
When syncing is finished, turn on your iPod / iPhone and you should notice that the message is gone. Type in your password and the disabled message should be gone.
If the message is still there, try holding the sleep and home button at the same time until the iPod turns off, then continue holding the sleep and home button until a screen with the iTunes logo and a picture of the connector cable appears. This will put your iPod in Restore mode. With this option, you must click the Restore button in iTunes, which will delete all your data on the iPod.
Posted on Jan 13, 2011
Why wont itunes recognize my ipod touch? why may
1. Reset or restore your iPod for a try, this can fix many general iPod problems. 2. You may try this iTunes alternative, I always use it to upload music and video to my iPod once my iTunes can't recognize my iPod, my friends recommend it to me, it's safe and works pretty well, you can also use it to copy music and video from ipod to computer for backup, it's useful when you lost your iTunes library. 3. Update your iTunes to the latest version. Plug in your iPod. If iTunes can't recognize it, then in iTunes in the top left corner click help> run diagnostics. On the box that comes up, check the last two things. Click next and it should identify your iPod. I got this method from Apple technical support. Hope it helps. Contact me if you have any other question.
May 14, 2011 | Apple iPod touch
Hello. my ipod touch (the old version) has been on the same screen for three weeks now. it says plug it into the computer into itunes. when i plug it into the computer itunes comes up. then a small...
try to restore your ipod. first put the ipod in DFU mode by holding the home and sleep button until the screen goes black, now let go of the power button and keep the home button depressed, after around 20 seconds, you will hear a noise (beep/ding) from your computer as if it had just recognized a new hardware device, now iTunes should recognize it in DFU mode. iTunes should tell you it has detected a device that needs to be restored and if you follow the instructions in iTunes you should get a restored iPod.
Note: everything on your ipod gets deleted.
Apr 12, 2011 | Apple iPod touch
Apple ipod touch 8GB For got password
1. Hold down Sleep/Wake button and Home button together, until the iPod touch powers off. Once the iPod touch turns on again, let go of the Sleep/Wake button about 1 or 2 seconds later, still holding the Home button. Once plugged in to your computer, iTunes will recognize the device is in Recovery Mode. You can now restore which will set the iPod touch back to factory defaults, thus removing the passcode.
2. Open up iLiberty+ and other the Other Tools tab select Enter DFU Mode. Your iPod touch will be recognized as in Recovery Mode by iTunes once you plug it in, at which point you can restore through iTunes. This will wipe the passcode as you're setting the device back to factory defaults.
3. Open up ZiPhone and select Prepare for Upgrade. You're iPod touch needs to be plugged in to your computer before doing so, and once you select that option iTunes will recognize that your device is in recovery mode. You can now restore through iTunes which sets the device back to factory default thus removing the passcode.
Apr 01, 2011 | Apple iPod touch
How can i unlock my ipod touch? i forgot my passcode.
The only thing that could make your iPod touch work again is to put it to DFU mode and restore. I have a full instruction about that to guide you step by step, making sure that you're doing the right thing.
However, that process will wipe out all the data from your iPod, you won't even be able to sync or create a back-up because iTunes does not recognize any iPod that is passcode-locked.
That is also why you need to put your iPod to DFU mode first, so that iTunes can recognize it, to by-pass the fact that it is passcode-locked. And, once its in DFU mode, the only thing that you'll be able to do is to restore, nothing else. And you have no other choice.
Click here for instruction on how to put your iPod touch to DFU mode and restore.
For more iPod touch / iPhone tips, click here.
Feb 11, 2010 | Apple iPod touch
Nano can't be found on computer or home pc the window on nano shows needs connection even though it is connected
1. Try another USB cord or USB cable. 2. Restrart your computer for a try.
3. Reset or restore your iPod for a try, this way can fix many general iPod problems. If you don't know how to do that, you may refer to this iPod tips
http://www.mac-dvd.com/ipod-tips-and-ipod-faq.html
4. Download and install the latest version fo iTunes for a try.
5. You may try this iPod transfer, it's a nice iTunes alternative that can help you upload music and video to iPod, I always use it to sync my iPod when my iTunes can't recognize my iPod, it's easy to use and works pretty well
http://www.ipod-transfer-copy.com/ipod-iphone-to-computer-transfer-cucusoft.html
If you have any other questions, feel free to email me.
Dec 26, 2009 | Apple iPod nano
I have the same problem but i use apple ipod touch 16G 1st gene
1. Start by syncing your iPod with your computer. When you do this, the iPod management screen will appear. Midway down that screen there's a button that reads "Restore." Click the restore button. This begins the process of restoring the iPod to its factory settings. After you click the restore button, iTunes will ask you to confirm that you really want to do this. If your iPod content is backed up, go ahead. 2. The iPod restore process includes iTunes downloading and installing iPod software and bug fixes. You will see a window that looks like this. Follow the onscreen instructions. **On a Mac, you will be asked to enter your computer?s password. On Windows, the installation will just proceed. 3. As iTunes restores the iPod, you will see a progress bar. 4. After the restoration process has completed, iTunes will pop up a window letting you know that it?s done. 5. Now you?ve got an empty, freshly formatted iPod. Now you can sync the iPod with your computer and download your iTunes library again.
Oct 01, 2009 | Apple iPod touch
New Ipod touch stuck in recovery loop... Received an error message while updating software for the touch. Now I can't get it out of recovery..
Try restoring again and when you get the error,press ctrl+alt+delete and end itunes task.then try the restore again...this time it will definitely restore completely!
Sep 29, 2009 | Apple iPod touch
When i turn on my ipod touch it just says connect to itunes when i do nothing happens cant access anything.
you have a software cooruption. the only way to fix this is to do a restore. try plugging it into itunes and see what happens. if itunes recognizes the ipod it will tell you to restore it. if itunes does not recognize the ipod you need to unplug the ipod and turn it completely off. then you need to plug the ipod while holding the home button down until itunes recognizes the ipod and then it will tell you to restore it.
Aug 23, 2009 | Apple iPod touch Second Gen (8 GB,...
Ipod touch turns on but tells me to connecct to itunes
You'll need to find a friend or family member that has a computer to resolve this issue. The iPod touch needs to be restored.
Using the Restore function for your iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPod touch settings are restored to their factory condition.
Whenever you restore your iPod touch, Apple highly recommends that you perform a sync prior to restoring in order to back up any changes since your last sync. If you have movie rentals on the device, see this document before restoring.
Use the following steps to restore your iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update. Connect your iPod touch to your computer. Select your iPod touch when it appears in iTunes under Devices. Select the Summary tab. Select the Restore option. When prompted to back up your iPod touch's settings before restoring, select the Back Up option. If have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you (As long as you've backed up your device, you should not have to worry about restoring your iPod touch).
Once the restore process has completed the iPod touch restarts and displays the Apple logo while starting up
Jun 24, 2009 | Apple iPod touch
Apple iPod touch Logo
1,488 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
