HP Officejet printer
The printer works at times, but sometimes it says "No connection" and all cables, USB ports are all connected. I usually disconnect and reconnect, and at times that solves the problem. I even recently purchased a new USB cable and it still said no connection. What is the problem?
    Novelist:
  • 143 Answers
I assume that your printer is connected to a network. if so, it could be that the printer is set to use dhcp for the ip address. and if that's the case, it's better to set the printer to use static ip address since there would come a time that the dhcp server (a router most of the time) would provide another ip addresses to all the devices connected to it. that could be the reason why you are getting a "no connection" message (disconnecting and reconnecting it at times would solve the problem temporarily).
here are the steps on how to set static ip on the printer using a windows computer.(Note: the installation cd can automatically assign a static IP address as long as the printer does not obtain a dynamic (dhcp) address)
- boot up your computer the normal way so it'll get an ip address from your dhcp server
- then turn off your dhcp server so that the printer will not get any ip address via dhcp
- reset the printer to set its factory default configuration (with no dhcp address)
* unplug the printer from the power
* plug the power cord back in while holding in the printer’s
report button (it will try to find a dhcp server; after about three
minutes of no dhcp response, the printer will default to a static ip address of 192.0.0.192
- then print a configuration page to confirm that the ip address of the printer is set to 192.0.0.192
- then press the report button (wait until IP address is 192.0.0.192 before proceeding. if it remains set to 0.0.0.0, check the network cable connection to the printer and to the network is secure. If some other address appears repeat steps 3 and 4 until the default address appears
- you can now start the software installation cd
*during the installtion, follow these steps:
- select the model of the printer that you are using which is hp officejet before clicking on "next"
- then select "do network settings for me, then press "next
*follow the instructions on the remaining install screens
- the software will pick an ip address in the private 169.254.x.x range (not available on the open Internet) and permanently assign it to the printer. it will also set up a static route to that address in the computer’s printer configuration
- turn the dhcp server back on by turning on the dhcp server by
connecting your cable/dsl modem or dhcp to the network. because the hp now has a permanent static ip address, it will
no longer try to use dhcp server to get an address
- install the software on the other computers on the network who will be using the printer. the installation software will discover the hp printer at the 169.254.x.x address, and will add the static IP address in each computer’s printer configuration
Note: if the installation cd will permit you to change th private ip address from 169.24.x.x, it's better to set it on the same range as of the ip address given by your dhcp server (for example your dhcp server provides ip addresses starting from 192.168.1.100-192.168.1.250, set the printer's ip address to 192.168.1.59-below or any ip address that will not compromise any ip addresses that were already being used by your other devices)
hope this'll help you but if you'll have other concerns just ask me.
ciao!
Posted on Jun 28, 2008
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
My HP OfficeJet J6450 stopped working after getting a paper jam. It is connected with a USB cable. I have tried deleting the printer and reinstalling the software without success. The software...
When installing the printer click on local printer and uncheck the box below it. I think it says something like locate my device. then on next screen click create new port, you should see USB001 in there.
Jun 09, 2011 | HP OfficeJet 6310 All-in-One Printer...
I have a HP Officejet 4355 All in one printer. I have installed the driver. But the connecting with printer takes long time and finally the result is connection failed. the entire cable usb port all...
connect it to some other USB ports and reinstall the driver ..' hope this works if it wont work remove its covering of the chips and then rub the contacts with a good white rubber.. this will help..
Sep 12, 2010 | HP Officejet 4355 All-In-One InkJet...
No connection ref hp officejet pro 8500 a909a
How are you connecting to the printer (over the network or a direct USB connection)? If you are using a USB connection, try a new cable or plugging into a different USB port. If you use a USB hub, try a direct connection.
If you are using a network connection, check if your firewall is blocking the connection. Also check that the router (or switch) didn't dropped the network connection and didn't re-synch with the printer (or worse changed the IP address of the printer).
I hope this helps.
Apr 19, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I recently replaced XP with Windows 7 and connected my HP Officejet 4351v all-in-one printer, but I cannot get a printout, just fax and copies. I get an error message on the printer indicating that there...
Try a new USB cable and check if the printer works in another USB port (or another computer). Check if a known working device works in the USB ports on your computer. Check if your USB ports have been disabled for security or power-savings (esp when on battery) in the Device Manager and the Power Savings area.
I hope this helps.
Mar 14, 2010 | HP Officejet 4315v All-In-One InkJet...
I can not get my printer to connect to my comupter. When it comes time to connect the cable from the printer to the cmoputer it fails.
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aber3
Sep 05, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp PSC2355 scan function inop
hi,
aswq9
Aug 25, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer cd will not download for hp 5610 The printer has worked for some time. now a message comes ujp that it is not connected to computer
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
ab44
Jul 02, 2009 | HP Officejet 5610 All-In-One InkJet...
OfficeJet R40 printer cable with a USB connection
Yes there is. This is what you need.
Thanks and please take a moment to rate as fixya.
Dec 12, 2008 | HP OfficeJet r40 InkJet Printer
Computers & Internet Logo
317 people viewed this question
David Payne
David Payne
