Canon fax mp780 says 'ERROR TX REPORT' 'result NG', what do I have to do to to snd the document? The manual has no translation of error codes!
  • 1 more comment
  • Anonymous Jul 16, 2008
    Canon Fax-JX300
    Scanned pages ok - dialed and connected ok - then BEEPING then ERROR TX REPORT page printed with RESULT NG
  • Anonymous Aug 05, 2008
    I have exactly the same problem and can't find an answer anywhere...  I can't figure out anything to do differently...
  • dulitz May 15, 2009
    I had the exact same problem with an mp830. Turning of the ECM worked. But what am I turning off?
If you go into the fax tx settings and turn off ECM setting, the fax should send (at least it did for me when I had the same problem).
Posted on Dec 16, 2008
Unable to send faxes Error code NG #018 appears
You need to apply Canon's firware update at http://www.canon.com and search for fumx310swin1040en.exe if you have Windows or for an iMac the file is MX310 series Firmware Upgrade Utility Ver. 1.040 (Mac OS X) with a file name of fumx310sosx1040en.dmg
Mar 07, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Faxing
did u try to do a hard reset to clear this error?
if nt try it please
Jun 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
What does coms error 00E8 mean?
Canon FAXPHONE L120 Laser Printer Please follow the instruction as given below may this will help u any
Error Codes
An error code is a four-digit code displayed on the LCD or in the bottom row of a TX Result Report or an RX Result Report when an error occurs.
See the table below for individual error codes.
Error Code Description Action 0001 The sender may not be using a G3 fax machine. Make sure the sender's machine is compatible with your machine 0070 Reception was manually canceled on the machine. Ask the sender to resend the document if necessary. 0071 The machine's memory is full. Print, send, or delete any documents stored in memory. 0080 The recipient's machine did not respond within 35 seconds. Resend the document. Ask the other party to check their machine. If you are making an overseas call, add a pause to the number. 008D The recipient's machine has run out of paper. Ask the recipient to make sure that paper is loaded in their machine. 00A0 Transmission was manually canceled on the machine. Resend the document if necessary. 00A1 There is a document jam. Clear the document jam. 00FF All redialing attempts have failed. Check if the recipient's number is correct or the telephone cable is properly connected, and try again.
Aug 18, 2010 | Canon L120 Fax Laser Printer
NG result
NG is just the error and not the problem, you have to read the code with the NG, it could be a phone line problem, a problem with the fax on the other end, a busy or not answered fax...any number of problems.
Oct 09, 2009 | Canon LaserCLASS Fax 710 Printer
Getting Error TX Report: Result 'NG' - what does this mean???
It means No Good or Not Good, fax was never received for a number of reasons.
Oct 07, 2009 | Canon FaxPhone L75 Plain Paper Laser
Canon MP530 - Fax - ERROR TX Report - NG
Hi flyme.. I have the same problem but on an MF5770 all in one MFP. If anyone can solve this then wow.. I've been trying to find a solution for over 18 months now...
Jun 06, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Need list of Fax result codes for Canon MF5550
NG 070 = Issue: ERROR LCD: CLEAR ADF, DOCUMENT TOO LONG
Solution: Reduce the length of the document
Reduce the length of the document to within 14" (356 mm).
Sep 03, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Re; Response for faxing problem
my canon mp780 fax will not fax all my pages. one page my go threw while i refax and none will go. my error report shows ng for result.what does that mean??
MP830 Canon Faxing problem
Display the fax menu and then select Print Report\List and print the Users Data List. Check the setting of the ECM TX setting. If this is ON turn it OFF. This is the Error Correction Mode setting, probability is the fax you are sending to is not ECM compatible. The MP830 is suppose to automatically send in standard mode if receiving machine is not ECM compatible however I am not sure how well this works. Turn the ECM setting off by displaying the Fax Menu and then select Maintenance\Settings, Device Settings, Fax Settings, TX settings, ECM TX.
Feb 25, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Repeated Fax TX report printing
Solution #3 solved it for me. The report kept printing over and over, so I used the menus (roughly) mentioned in Soluton #3 by guest.
My problem was the printer was trying to print the TX Error Report with the image attached. That made the report too big for standard sized paper, so the machine kept telling me to check the paper size, and I'd hit 'OK', and that made the machine try to print the report again, for it continued to think it had not printed a complete report.
Here's what I did...
Go to: Fax Menu
Arrow right ( >) to Maintenance/Settings, hit, 'OK'
Arrow right to (>) to Device Settings, hit 'OK',
Fax Settings, hit 'OK',
Arrow down ( v ) to TX Settings, hit 'OK',
Arrow down ( v ) to TX Report, OK
Select 'Print error only', hit 'OK',
Attach TX image, Select 'NO', hit 'OK"
With the instruction to not attach the TX image, it will print out the error report without the TX image, the report will fit on the paper, and it will clear this problem.
Jan 22, 2008 | Canon PIXMA MP830 All-In-One InkJet...
997 people viewed this question
k24674
jasbo
jasbo
