Question about Frigidaire 11.6 cu. ft. / 328 liter Upright Freezer FFU12K1CW
UP RIGHT FRIGIDAIRE FREEZER AUTO DEFROST 11CF I THINK
FREEZER WONT SHUT OFF BOX TEMP IS 0 TO 10 DEGREES AT SETTING #4 RUNNING SINCE LAST NIGHT (24 HRS)
  • oicurmt Jun 30, 2008
    I guess you are right reguarding running time 80 to90 % It finally turned off after running almost non stop.I don't use the freezer all year.I shut it off in Dec and restart it up in June.Maybe it was still sleeping.
    Novelist:
  • 161 Answers
This could be normal for the summer. This is the right temp to keep it at. Some units are meant to run 80 - 90 % of the time. Turn it all the way up and check the temp. Most units when working properly can get below 0. Check the condensor underneath for dirt and to see if the fan is running under there. (smaller units don't have anything underneath) Some have coils in the rear and the smallest units just use the sides of the cabinet to disperse the heat. Check the gasket see if its sealing properly or maybe the door is warped and not closing at the bottom.
Posted on Jun 30, 2008
Traulsen G sereis 2 door freezer keeps running past set temp of "0" degrees keeps freezing all the way to -35 degrees and I have to shut it off to keep it from running? any advice??
It basically sounds like the temp sensor is not sensing the box temp that the control functions on. Other wise, the control may be stuck. Traulsen seems to have a fairly descent tech support line. Call them for steps on how to read the controller.
Feb 04, 2014 | Traulsen G-Series G22000 Solid Door...
My freezer is froze
The defrost element and/or timer.
Sep 01, 2017 | Frigidaire Freezers
Frigidaire freezer LFFH21F7HWG. the temp gauge outside registers only 0. I have 3 thermometers inside all register 18 degrees. ice cream is soft in the box. machine was delivered last Tuesday. the freezer...
these freezer are designed to run about 70 percent of the time the temp displayed can vary by +/- 3 degrees..make sure you have fan operation in the freezer and the air flow is not blocked or restricted. also make sure that the door is sealing properly
Aug 31, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
My freezer has gone into what seems to be a defrost cycle but is on day 4. Is this normal? It is staying at 0.2 degrees C
This freezer has a manual defrost control on it, comes this way. Also has defrost drain hose in the front with a wrap around evaporator and condenser coil. A unit should only defrost for about 45 minutes to remove any build up, 4 days indicates it is stuck in defrost. It doesn't show the cross over temp to F from C on my chart at 0.2 degrees. You should have a defrost control that you are able to put into defrost your self. Look around the back or anywhere there may be a removable panel or it should show you where to put this box into defrost since it is manual and not automatic.Give it a turn in the direction and watch to see what happens. It may go into defrost again and come back out on its own and freeze properly. If it continues to stay in defrost, you will need to replace this timer. Take all of the info and pick one up at a appliance parts house that will stock it. Draw you a diagram so you dont forget how you removed it and that will make it much easier to install. I will also send you a link about this freezer next. It will be coming to you after you get this. Keep me posted.
Shastalaker7
Mar 31, 2010 | General 14.8 cu. ft. Electric Chest...
Freezer defrost cycle
If the defrost timer sticks in the defrost mode,yes. Normal defrost time is 30 minutes or less depending upon which timer is installed.
If it happens again,locate the defrost timer and turn the dial manually to see if the compressor comes back on. If so,replace the timer.
It is probably on the rear near the compressor. Some are under the front behind the dust guard.
Feb 24, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezer temperature v
This sounds like your motherboard,computer or control board(they call it different things in different models) is bad. It is responsible for the fan speed and timing of the defrost cycle. To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Sep 20, 2009 | Freezers
New freezer not cooling - temp @ 25 degrees and food is defrosted
It is probably the control board and since it's new it's still under warranty so a certified Frigidaire repair man will fix it without charge. There should be a telephone number with the paperwork you received when you bought it.
Aug 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
Jul 26, 2009 | Frigidaire Freezer Refrigeration White...
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Frigidaire 11.6 cu. ft. / 328 liter Upright Freezer FFU12K1CW Logo
624 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
