Question about Denon AVR-3805 Receiver
Setting the Balance is a challange
I can not get the right channels to work in TV Stereo mode can you tell me how to fix this?
  • Dave DeGain
    Dave DeGain May 11, 2010
    Is this the only mode you can not hear the right channel or is it a problem with all sources?
    If you have this problem on every source, the problem is in the Denon. If not, then the problem is from the cable box or whatever you have going into the Denon to listen to the TV. There are several different ways of listening to TV thru a receiver. You may have a cable box, sat. tuner, or even the output of the TV itself going into the Denon.
    It is important to know exactly how it is connected to give you the help you need. These receivers have digital inputs and analog inputs.
    As you know since you own this Denon, they are very complicated receivers, and with more information I should be able to help you locate the source of your problem.
    Thanks
    Dave
    President:
  • 624 Answers
Have you read my clarification request? If you still need help please furnish the required information. If no help is needed any longer, just ignore this post.
Posted on Oct 16, 2008
My right channel is weak. universally. any effect mode and speaker a and b . Seems slightly stronger when balance knob is at center but is still nearly inaudible . Is it the balance pot or a circuit or a...
I have seen this a lot of time on Yamahas, one of the channels are either a bit or a lot softer than the other, this happens after warrenty and you need to have it repaired.
Oct 08, 2013 | Yamaha Rx-v590 5.1 Channel 265w Natural...
Can't change from MONO to AUTO mode
Hello
Can't make sound from mono to auto is your problem I thinks and posts this solution.
Hit the "Menu" button and surf through, come to "Sound Adjust" window.
The settings allow you to change and adjust sound in your TV. There are Bass, Treble and Balance control to adjust to your individual taste.
To adjust them
1. Press Menu button.
2. Press UP or DOWN button to select the desired item.
3. Press => or 4. Press EXIT button when finished.
When adjusting the parameter of "Balance" control, always set it to mid position to get stereo sound from both speakers. If it is set to any extreme end, there will be no output from the speaker of that side, and will hear as mono.
If you press "0" [Zero] button, you can reset the sound settings to it Factory settings.
To select 'Streo mode;
1. Press "Menu" button.
2. Press UP or DOWN button to select MTS [Multi-channel Telivision Sound].
3. Press => or [The ON AIR arrowtells you if a broadcast is in stereo AND/OR contains the SAP.
Press "Exit" button when finished.
Keep the TV in stereo mode to get the best sound quality. The sound will work in stereo
mode even if a certain broadcast is in mono sound only.
Choose the mono setting to reduce excessive noise on a certain channel or broadcast.
Selecting SAP will allow you to hear an alternative soundtrack, if one is available.
Apr 01, 2011 | JVC AV32F476 32" TV
My Aiwa Colour TV, model No. TV-A2019, has developed audio problems. 1. The audio output from the speaker is high even when volume is set at level one. Audio output is constant for volume level 1 to...
You just come aroung the sound decoder section of your tv. Decoder problems may cause the fult you pointed out. Since all the controls are electronically controlled, and all are through sound decoder, which converts sound to stereo the problem must be there. Since sound comes from two channels are ok, there is no problem around sound output. Check for some soldering loose contact, wire socket loose cotanct also.
Oct 14, 2010 | Aiwa F2000 20" TV
Our two left speakers, front and rear will not
Check the connection on the back of the receiver. Check the balance setting, make sure that it's in the middle. Try another mode like stereo, you should hear left and right front only. Also, if your receiver has an on screen menu, check the dB levels for the front and rear left speakers. Good luck!
Dec 09, 2009 | Audio Players & Recorders
Channel Problem
It could be a bad balance control potentiometer or just broken/cold soldering joints due to the age. Bring it in a repair shop. Thanks. ebcelectronics
Apr 06, 2009 | Audio Players & Recorders
No stereo signal out from yamaha p 2500 s
It's unclear what type of connectors are on the end of the cables(s) coming from your computer.
This amp only works with mono 1/4" TRS and XLR connectors, not standard RCA connectors.
Did you try the Right one in the Left Channel to see if the Left Channel worked?
Refer to the following manual and read up on the connectors (page 7) and the use of the Stereo/Parallel/Bridge Switch (page 8). When it is NOT in Stereo Mode the unit only uses the Right Channel controls and input.
http://img3.musiciansfriend.com/dbase/pdf/man/m_480824.pdf
STEREO/PARALLEL/BRIDGE switch
Use this switch to select the operating mode.
• STEREO mode
Channels A and B operate independently (as with a conventional
stereo amplifier). The Channel A input goes to the Channel
A output jacks, and the Channel B input goes to the
Channel B output jacks.
• PARALLEL mode
The Channel A input signal is output through both the Channel
A and Channel B output jacks. The Channel B input jacks do
not function. Channel A and B volumes can be independently
adjusted.
• BRIDGE mode
The Channel A input signal is output from the BRIDGE output
jacks. To adjust the volume, you must use the Channel A volume
control knob.
Apr 03, 2009 | Yamaha P-2500 Amplifier
I have a Proview TV that we just bought from Rent A Center and when we connect our cable to the TV it tells us to scan the channels. We did this and still we get a blank blue screen that says No Signal....
Try this as your model is basically the same as mine.
Push Menu on your remote.
Then a small screen comes up.
Using your left right arrows move left to set up.
Scroll down to tuner mode and again using left right arrows, there are 4 setting you can choose. Once the setting you choose is showing then scroll up to Channel Searching and hit OK on your remote. This will scan all the channels Digital and Analog.
Depending on which of the 4 setting you picked on TUNER MODE you may have to do this again in the next mode to see which will get the most channels on your TV.
I hope this is helpful; Ken, Attica, NY
Nov 27, 2008 | Proview PA-32JK1A 32 in. LCD Television
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Samson co1u recording issue
you first 3 people are idiots... maybe if you had worked with the hardware you would know how the mic works because its obvious you don't. The 4th person is correct because this is exactly how i use the mic and it captures sound in stereo format beautiful when set up rite. Using it in mono, whether use keep on one channel or two drastically reduces the crisp sound that this mic can record.
Mar 18, 2008 | Samson C01U - USB Studio Condenser...
Denon AVR-3805 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
