Question about Jenn-Air Ovens
Jenn-Air wall oven JMW833ODAS
Hi, We have a Jenn-Air oven that is less than 2 years old. The keypad doesn't work at all.  The clock still works but after turning off the breaker, it is set at the wrong time.  Is this still under warranty?  If not, how much would it cost to fix it?   Thank you for your help. Shelly Sparrow
SOURCE: Problems with Jenn-Air Electric Double-Wall Oven
Try changing the clock assembly --
http://www.partselect.com/ModelFrames.aspx?ModelID=221346&ModelNum=WW30430P&mfgModelNum=&ManufactureID=1&Selected=51238&Position=1&mfg=Maytag&Type=&Mark=1
here is a link to the diagram.
PS120923
Electronic Clock Assembly (Series 10)
Help with series numbers
here is the part number.
Posted on Feb 17, 2008
  • 184 Answers
SOURCE: Jenn-Air Gas Range SEG196 NO CLOCK/DISPLAY
THE ONLY SOLUTION FOR THE BAD DISPLAY IS TO REPLACE THE CLOCK. I HAVE A JENN AIR OVEN TODAY AS A WORK ORDER TO REPLACE THE CLOCK FOR A FAILED DISPLAY.
FOR THE JGW8130DDB WITH NO POWER ANYWHERE, IT SOUNDS LIKE YOU HAVE A SUPPLY PROBLEM. MAKE SURE THE WIRING IS HOOKED UP WITH THE RED AND WHITE WIRES RECEIVING 240 VOLTS AND THE WHITE WIRE ATTACHED TO NEUTRAL / GROUND.IF THE OVEN HAS A BARE COPPER WIRE AND THE HOUSEHOLD WIRING ONLY HAS THREE WIRES, COMBINE THE WHITE WIRE AND THE COPPER WIRE TOGETHER AND ATTACH TO THE HOUSEHOLD NEUTRAL / GROUND .
UNLESS YOU ARE SURE ABOUT THE HOOKUP IN THE BREAKER/FUSE BOX, DO NOT GO SIMPLY BY THE COLOR OF THE WIRES.
Posted on Apr 10, 2008
  • 3 Answers
SOURCE: Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
Posted on Jul 10, 2009
  • 19 Answers
SOURCE: Jenn-air expressions wall oven clock went dim, now out completely
If you haven't already, replace the capacitors on the clock module. I had the same problem with a similar oven. See this link for more info:
http://www.badcaps.net/forum/showthread.php?t=7902
Posted on Feb 04, 2010
SOURCE: 7 yr old jenn-air wall oven locked shut, shut down
It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
Posted on Feb 13, 2010
Wall ovens
This Usually indicates a shorted keypad. Turn off at the breaker. Unplug membrane strip connected to the clock from the clock, turn breaker on. If code comes back replace the clock, if no code you need the touchpad replaced
Let me know how this goes, thanks
May 11, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Sabbath mode on display. oven not working
Press and hold 'clock' pad, under keypad, for five seconds. 'sab' should blink for a few seconds and then clear.
lp
Dec 30, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Some selections on the touch pad on my Jenn-air oven aren't working
Hi, There is a way to replace the keypad. Sometimes you need to replace the clock assembly. I could let you know for sure if I had the Model #
May 08, 2009 | Ovens
Clock readability
The problem is very likely a bad capacitor on the clock module. See this link for more info:
May 03, 2009 | Jenn-Air JJW8230D Electric Double Oven
Electronic touch panel unresponsive. Clock blinks, but no other commands produce any activity. Model#:JMW8330DAS Serial #:13679516JN Jenn-Air oven. About 2 years old.
Unplug and let sit for 5 min. Replug and set clock time first. Then see if the other buttons work. Electronics sometime need to reboot if it freezes like your computer does sometimes.
Apr 29, 2009 | Jenn-Air JMW8330DAS Stainless Steel...
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Apr 10, 2008 | Jenn-Air JGW8130A Electric Single Oven
Ovens Logo
42 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
