Question about Kitchen Ranges
B1601X Wall oven, will not reach thermostat temp on Bake and Fan Bake Mode.I set Temp to 180 deg FAN Bake, it only gets to 104 deg. I set Temp to 180 deg BAKE, it only gets to 153 deg. Could this be the control unit. I have replaced the lower element in the oven.The ploblem is still there.
  • 3 Answers
Your forum doen't look like you can help.
Posted on Jun 29, 2008
The fan wont work car does not get hot shut off
cooling fan works on a temp sensor in the engine block. it only turns on when the temp reaches a set limit and shuts off when it gets below a set limit.. cooling fan components are , fans, fan relay , and temp sensor . best way to test the fans would be to let the car set running and watch the temp till it goes up to 185 -195 deg. at this time the fans should turn on and the thermostat should open and cool the engine back down. also when ever the air conditioning is on so should the cooling fans be on. if the fans do not run the check all components till you find the broken one. fan relay and air conditioning relay are separate but work the same. and will interchange
Dec 18, 2013 | 2001 Dodge Neon
Intermittent colling in Samsung Window AC
so your reported figures show that the unit is operating as planned
the closer to ambient temp the shorter it runs for
the further away from ambient temp the longer it runs for
when the desired temp is reached , the compressor will stop but the fan will continue to run to circulate air past the thermostat so that it will switch back on when the room temp reaches too high temp
and that is why it is recommended to set the temp at 25 C as that is the most economical temp to run it at
Oct 30, 2017 | Heating & Cooling
I have a 95 Gran AM GT with 3.1 auto. The motor will run until it gets overheated and boils over, but the fan will not start.I have totally flushed the system,pulled and inspected the water pump, changed...
Fan operates when coolant temp reaches 226 deg.F and shuts off at 219eg.F
fan is controlled by the PCM infuts from Eng. coolent temp. sensor & Intake air temp. sensor
the yellow wire is the 5V reference and the black wire the is the PCM ground sensor
make sure your not using teflon tape on the threads of the temp sensor.
it sounds like the PCM wont turn it on. check the harness for continuity between temp. sensor and PCM harness
clear connecter - pin 17 black, pin 31 yellow
Sep 12, 2010 | Pontiac Grand Am Cars & Trucks
2001 Jeep Grand Cherokee Laredo Overheating
Three possible solutions:
1. Bad Thermostat
2. Fan Relay (most likely)
3. Bad Fan
When the GC reaches a temp of 180 Deg. F the fan relay sends a signal to the fan to turn on, once the temp lowers (around 155 Deg. F) the relay turns off the fan, and so the cycle continues. If the relay is bad there will be no signal to the fan to run. While you are driving your vehicle there is ambient air moving thru the radiator, cooling the engine, but once you encounter slow/heavy traffic or stop there is no air moving and the temp goes up, the fan will not kick in and the vehicle will overheat.
If the fan motor is not working the same will happen, but a more expensive fix, as the motor comes with the fan.
If the Thermostat is stuck in the open position, the water travels to fast in the engine and heat exchanging is not an efficient process, therefore the vehicle might overheat when stopped or in slow traffic.
Mar 31, 2009 | 2001 Jeep Grand Cherokee
Range will not hold a consistent temperature
Good chance your bake element is out. Could be the element or a terminal burned off.
When you set to bake, normally it preheats which uses the bake and broil element.
When it reaches "near" temp, the broil goes off and the bake takes over.
If the bake element, (the one in the bottom), is not working, the temp will decline.
Check:
Turn to 450 deg.
Watch the elements, assuming you have a door with a glass, and see if both elements, top and bottom, glow red.
MrBoo aka Gary
Nov 11, 2008 | KitchenAid KERC507 Electric Kitchen Range
2000 jeep radiator fan
Hi micro0711, the fan (which I assume is electric) works off of 3 corresponding pieces of equipment: the rad,the thermostat and the coolant temp sensor so if you have a 180 deg thermostat the coolant would circulate through the engine and generate heat once the coolant temp reaches approx 180 deg the thermostat opens the coolant temp sensor signals the fan to engage removing the heat from the radiator cooling surface maintaining a safe operating temp. If you find your temp is rising check to be certain there is power to the fan and also that the thermostsat is operating,hope this helps good luck
Nov 10, 2008 | 2003 Jeep Liberty
Bosch HBN 642 -- single oven cycles and doesn't get above 325
WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
May 28, 2008 | Ovens
Kitchen Ranges Logo
129 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
