Question about Canon PowerShot S50 Digital Camera
Canon s50 display problem
I have a problem with my canon s50 display; i opened it from inside part by part then gather it again put it together and close the whole box; the reason i did that cause i have a problem E18, i read on the internet how to solve it and it seems that it needs cleaning so i did that and after i did it seems to open very well even better than befor BUT the LCD screen is viewing black screen now, just the same problem as the guys having on their camers,i checked the battery the display button and the CFs card but nothing is working, I mean that when i take pictures it takes black pictures and when i view them on my labtop it shows black image only and another thing here is when i press the (.web FUNC. and MF and MIC button) nothing seems to appear working on my camera, one more thing here my warrante is finished, i need urgent help plz
  • rund Jun 28, 2008
  • khamps Aug 29, 2008
    no view through LCD, pictures are black. pressed display, changed cards, battery, etc.,
    President:
  • 1,566 Answers
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Posted on Apr 06, 2010
?why do only a few keys work on the remote
Some remote as they live on around your house area, they gather up dirt, or any debris laying around the house
I found some steps while searching around, here they are-
1 . Remove any batteries out of your remote control.
2 . Check over the remote control and remove any screws keeping the remote together.
3. Once you have it open, make a note of any switches or loose pieces so you will know where they go when you put the remote back together.
4. Clean the circuit board and keypad to remove any dirt and oil. An old toothbrush works. Check, after cleaning, if the remote is working again; dirt could be the only problem.
5. Clean the buttons, blow off any dirt inside the remote.
Feb 21, 2015 | Televison & Video
The lcd screen is broken, I want to get it repaired. Where do I send it, and or what is a cost estimate?
They don't really repair it. They charge you more than $150 and send you a factory-refurbished replacement.
Feb 21, 2011 | Canon PowerShot S50 Digital Camera
How do I get my Canon powershot s50 to display the date and time on the picture
The date/time stamp only works in "Postcard" resolution. Press the "Func Set" button, then scroll down to the bottom to select postcard resolution.
Then press the menu button. Select the "Camera" menu, then scroll down to the the Date Time Stamp selection to turn it on.
Mar 11, 2010 | Canon PowerShot S50 Digital Camera
Canon powershot S50: Sliding door stuck.
this can happen,gently tap the door(GENTLY) may loosen it works on my a70
Aug 18, 2009 | Canon PowerShot S50 Digital Camera
Please explain how to use the flash card with the camera
Manuals fo rthe S50 alavailable on the Canon support site.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=322&modelid=8778
May 19, 2009 | Canon PowerShot S50 Digital Camera
Sliding Lens Door Problem -- Canon S50
I had the same problem with a S50, where the lens door would not operate properly and would not open enough to cause the camera to activate. I took it apart and found that there are two small gears that keep the door on track, one had split in half and jammed the mechanism. They were white plastic, perhaps nylon? I found another S50 on ebay with broken electronics but a working lens door and took parts from it to fix my system. Getting the tiny gear in place was tricky as there are several springs used to activate the camera on switch.
Jan 18, 2009 | Canon PowerShot S50 Digital Camera
I have a canon Power Shot S50. The mechanical slider that covers the lens is loose. When I open it, it doesn't power up the camera. I suspect there is a switch underneath the cover is broken.
The open door button on a circuit board is usually micro. A loose cover will likely not make contact with this small switch. Take the cover off and tighten the screws on the inside. Try to locate the switch to inspect if it has been wore off, broken, or missing even.
Nov 13, 2008 | Canon Cameras
Canon s50 lid and lens atuck in part open position e18 displayed
I am a superspecialist surgeon. My email id is drspsbagga@gmail.com .Recently i changed my password and unfortunatel y have forgotten the new password. I donot remember the old details also. My cell number is 09814141850 .please help.
May 31, 2008 | Canon PowerShot S50 Digital Camera
Canon S50 Not working
Kgiangus and others....
Try using some canned air around the lens housing and lens door.
Dec 02, 2007 | Canon PowerShot S50 Digital Camera
Pentaxs50 turns on lense does not extend memory full displays on Lcd then it turns off.
throw it in the garbage and get a less expensive Samsung digimax s500 for less with better quality and features.. What a mistake in purchasing a Pentax. I wrote to Pentax for I had the same problem. Answer, send it in for repairs with a cost if it is not undaer warranty. Not even a hint as to what may be the problem from them! Pentax, No thanks!
Oct 22, 2006 | Pentax Optio S50 Digital Camera
Canon PowerShot S50 Digital Camera Logo
123 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
